Harmony 1100 or 900? Or wait for something new? - AVS Forum | Home Theater Discussions And Reviews
Old 08-01-2011, 04:30 PM - Thread Starter
HiSoC8Y's Avatar
Hello
I'm in the process of deciding which remote to buy.
I currently don't have any, and I'm planning to buy it for my living room (tv, projector, PC, two sat receivers...etc.)
I know that 1100 doesn't come with the RF devices, that's ok, I believe I have some from my old remote (which i had 3-4 years ago).
What will be the top differences between these two? What is your experience?
Appreciate your feedback
HiSoC8Y is offline
Old 08-01-2011, 05:25 PM
shadestreet's Avatar
I am going to suggest you skip Harmony Remotes. My 900 just died on me after only 4 months of careful use. Previously had two 890's die as well. Both crash and go to white screen.
I just made a thread about this, seems other people are not thrilled with Harmony either. It is a shame, because when the remotes work, they work fantastic. But shelling out a few hundred dollars every 18 months for a new remote is insane, so after my 4th Harmony dies (the replacement they will ship for current 900), which I expect to happen a few days after the warranty expires, I am going to get another brand.
shadestreet is offline
Old 08-01-2011, 05:50 PM - Thread Starter
HiSoC8Y's Avatar
thanks for the feedback.
what will be the alternative?
HiSoC8Y is offline
Old 08-01-2011, 06:29 PM
c-not-k's Avatar
Well, I just bought a 900 to replace my still-working 5-year old 890. I've configured the 900, but haven't tested it yet. (Tonight, perhaps.)
I purchased a Harmony One two months ago to replace an 880 I spilled a soda on.
The differences will be mostly using one hand or two to control your system. I have not used a 1000 or 1100, so I can't say how much of a difference that makes.
I really liked the 880/890, so I wasn't sure how the new style would be, but I quite like it. (So much so, I picked up a pair of similarly styled 700's for the bedroom and kid's room.)
It takes just a few minutes to get your devices set up. (I recommend you glance through the appropriate threads for tips.) It takes considerably longer to dial your configuration in. I've found it helps greatly to write everything down on a sheet of paper before using the software. For example, in my theater I have 7 devices; Projector, AVR, Media Streamer, Laserdisc Player, Scaler, Lights, and Curtains. When you set up activities, such as "Watch Movie", you'll need to know what state your devices need to be in, such as "AVR set to DVD".
For consistency, I set up my additional soft buttons to be the same in all activities. In my case, the second page of soft buttons on all my activities are for lighting.
I will miss the sequences, or macros as everyone else calls them, that are on my older 890, but not on the newer 900. Currently I have a sequence called "Pause Movie", which pauses the movie and brings up the lights with one button press. It will be two with the 900.
As I haven't set up the RF for the 900 yet I can't comment. The older 890 had stick-on emitters and 3.5 mm jacks. The newer 900 uses mini-blasters (small IR repeaters) instead, and 2.5 mm jacks. I don't know the particulars of the 1100. I know it doesn't ship with an RF-to-IR base station, but I'm not sure which ones it's compatible with.
I hope I don't come off like a Harmony fanboy - I'm not. I think they shouldn't have dropped sequences. Also, I could rarely get the charger to work for any of my 8xx remotes.
Now the Philips is out of the market, perhaps URC might be an alternative. I have no experience with them, however.
Hope this helps. Let us know what you decide.
c-not-k is offline
Old 08-01-2011, 06:41 PM
Durandal's Avatar
My experience has been that Harmony remotes work well for about 18 months, and then some buttons stop working or they die altogether (which seems like ashort life for a $200-$400 remote). Logitech support leaves quite a bit to be desired (non-english native speaking, they only give you phone support for the first 60 days last I checked, and troubleshooting complicated remote issues often takes quite a bit of back-and-fourth which makes 24+ hr response ridiculous), and their warranty is insufficient (since it seems there products don't live much past the end of the warranty).
Durandal is offline
Old 08-02-2011, 06:54 AM - Thread Starter
HiSoC8Y's Avatar
thanks all for the collaborations/feedbacks
from the readings, I believe the only difference between 900 and 1100 is that 900 is an actual traditional remote, and 1100 is square shaped, touch screen.
I think I'll go with the 900
For logitech, I believe they are by far better than any other products, ...true that their devices might die after a while..but what to do....
it's easy to setup, they have a huge database of devices....they made it for consumers....
HiSoC8Y is offline
Old 08-02-2011, 07:28 AM
bryansj's Avatar
Quoted: 1130 Post(s)
Liked: 560
Who said that?
bryansj is offline
Old 08-02-2011, 07:30 AM - Thread Starter
HiSoC8Y's Avatar
what i meant is that they are widely used, it's commercial, you can find it on the shelves on bestbuy and other venues.
while others, sold online, doesn't support as many devices as logitech....etc.
Again, I understand that harmony products are not the best, but they are the easiest, and widely available.
it's like microsoft vs. linux
HiSoC8Y is offline
Old 08-02-2011, 08:56 AM
bryansj's Avatar
Liked: 560
More like Fisher Price vs. BMW.
bryansj is offline
Old 08-07-2011, 01:44 PM
dafish721's Avatar
Quoted: 16 Post(s)
bryansj,
if you don't the Harmony line of remotes what would you say is a good alternative in the same price level that also includes RF?
Samsung UN75JU6500, Denon AVR-X2200w, Monitor Audio Silver 5i speakers, HSU VTF-15H, OSD RS690 outdoor speakers, Panamax Max 1500 line conditioner
dafish721 is offline
Old 08-07-2011, 01:48 PM - Thread Starter
HiSoC8Y's Avatar
i ordered my harmony 900.
HiSoC8Y is offline
Old 08-07-2011, 01:55 PM
joebloggs13's Avatar
Nice choice! I would also take the 900 over the 1100. I prefer the look and feel of a traditional remote.
joebloggs13 is offline
Old 08-07-2011, 09:51 PM
jrwhite's Avatar
Originally Posted by dafish721 View Post
bryansj,
The Acoustic Research Xsignt touch and Xsight RF base are similar to the 900, and considerably less expensive. The Xsight has PC/Wizard style programming similar to the Harmony. I've never used one, so I can't attest to the build quality or software. Search threads here for more info.
The URC-MX450 / MRF-260 can be had online for around the same price as the H900.
Much superior build quality compared to Harmony offerings. On remote programming via menus, not a PC Wizard based programming paradigm like the Harmony. No 'activities', but they can be emulated with macros. No state tracking like the Harmony, but you can use discrete IR codes to get around this. IR code base can be updated via USB, and your configuration can be uploaded and stored locally on your PC. Uses AA cells instead of a rechargeable battery, but, I consider this a plus. I also have several rechargeable harmonys and am often left with a dead remote because I either forgot to put it in the charger, or, it didn't seat correctly and didn't charge.
I use an MX-450 as my main remote in my livingroom setup, and am quite happy with it. After nearly 4 years of rigerous use, and many drops onto a hardwood floor, it still functions perfectly.
Jonathan
jrwhite is offline
Old 03-25-2013, 05:44 PM
Brad Levine's Avatar
I just got the 1100 and i am absolutely LOVING IT!!!! If it were a woman i would make love to it. In fact, i have used it many times since to get myself off. Thats how sexy this mother effer is!!!!
I was a little skeptical because i like the feel of a traditional remote. Well my friends, let me just say this... All concerns were quickly chucked aside. If you are looking for a sleek, sexy remote that you would like to, on occasion, make sweet love to, and the other times use as an incredible universal remote, this is for you. Enjoy this remote as it freaking ROCKS!!!!! Don't listen to any of the haters out there. This remote is the real deal. it is the Fshiinitz, the bomb, the mac daddy of all remotes. Trust me. I personally guarantee you will enjoy this remote....OR YOUR MONEY BACK!!!! LMAO biggrin.gif
Dark Knight
Brad Levine is offline
Harmony 1100 Remcontrol
