iRule - Page 210 - AVS Forum | Home Theater Discussions And Reviews
 106Likes
post #6271 of 11353 Old 03-30-2012, 01:47 PM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 985
I got an email from iRule support this morning (those guys are great) and they said the same thing. The device is a Runco LS-5 projector. They offered to contact Runco for me, but I'm going to try using iLearn first.
Thanks for your help!
Sure thing. I see in the manual it says it uses the NEC protocol and custom code 0x06F9. Looks like the first byte is the complement of the second. Converting to decimal, you get 6 and 249, then enter into the MakeHex program plus 1 for ON and 9 for OFF to generate the pronto hex, then import into iRule. I think learning would be easier.
mdavej is offline
post #6272 of 11353 Old 03-30-2012, 02:36 PM
John V.'s Avatar
@Jimim
Nice looking setup, and thanks for giving us some more ideas.
Looks like we had a similar design layout in mind for our home screens
John V. is offline
post #6273 of 11353 Old 03-30-2012, 02:41 PM
jimim's Avatar
Quoted: 496 Post(s)
Liked: 143
Originally Posted by John V. View Post
@Jimim
Lol. R those ur buttons. I grabbed those the other day. Those r the few I didn't make myself that aren't in irules default. I liked those pics with the words. Thought they were nice.
jimim is offline
post #6274 of 11353 Old 03-30-2012, 03:00 PM
John V.'s Avatar
No, I don't have those kind of skills, unfortunately...I think those were made specifically for the iPhone, but thought they looked nice to signify the different rooms.
John V. is offline
post #6275 of 11353 Old 03-30-2012, 03:24 PM
jimim's Avatar
Quoted: 496 Post(s)
Liked: 143
Lol me neither! I liked em too. I got to get my master bedroom setup going next.
jimim is offline
post #6276 of 11353 Old 03-30-2012, 04:20 PM
phy88's Avatar
Originally Posted by mborner View Post
In the page properties of each page, select "enable motions" = "yes"
That setting enables page motions (commands that execute when you move the ipad left, right, up or down), not navigational transitions between different panels...
Originally Posted by absolootbs View Post
are you sure this is correct? i haven't tinkered with it, so i can't say it's not... but i thought the enable motions (which has been there since before this update) enabled the use of the accelerometer for executing commands (the commands that you assign in the "motions" section of the panel), just as the "enable gestures" is what enables the use of swiping and tapping for executing the commands that you assign in the "gestures" section of the panel.
Yup, that's not it. It looks like they just removed the slide transition between panels without giving users the option.
phy88 is offline
post #6277 of 11353 Old 03-30-2012, 06:58 PM
ekkoville's Avatar
@Jimim,
I noticed the sliding volume control you had. I wasn't aware that was available. How does that get integrated?
ekkoville is offline
post #6278 of 11353 Old 03-30-2012, 07:46 PM
mborner's Avatar
Quoted: 59 Post(s)
Liked: 26
That's interesting. My page transitions with swipe still work like they always did from day one. Swipe left or right and the page slides with it. However, the new fade transitions seemed to work only after I changed "enable motions" to "yes", although, I cannot say for certain, that's what did it. Linking from page to page eliminates the slide transition but the slide transition is still available if you swipe. I'm on my iPad (1st Gen.) as we speak and I'm currently using swipe/slide transition as well as the new fade transition at the same time.
mborner is offline
post #6279 of 11353 Old 03-31-2012, 09:21 AM
jimim's Avatar
Quoted: 496 Post(s)
Liked: 143
Originally Posted by ekkoville View Post
@Jimim,
That's part of the iTunes module. it slides for vol control of iTunes.
jim
jimim is offline
post #6280 of 11353 Old 03-31-2012, 09:23 AM
jimim's Avatar
Quoted: 496 Post(s)
Liked: 143
feedback question:
for those who use feedback on a devon or onkyo or similar. how is pandora? i know u will be able to see what's playing on pandora but what about scrolling through ur list of artists to select which channel u want? is it possible if so what's it look like?
thanks,
jim
jimim is offline
post #6281 of 11353 Old 03-31-2012, 11:50 PM
krichter1's Avatar
Quoted: 2048 Post(s)
Liked: 2293
This would be one of my most desired features in iRule.
So I've decided after many trial and errors with multiple pages to support all my devices to start from scratch and redesign the stainless button in PS to a smaller version which now can support up to ten devices on one page.
One question though... how are you guys posting the whole source page images on this thread? My version of builder is too big to see the whole page and I don't see a 'right click' option to save the image.
Attached is a rudimentary 'Grab' from my Mac to see what you guys think of the design (I also created some blanks ON & OFF if anyone needs them).
Kevin
You only live once, but if you live it right, once is enough.
==> Our 4K/3D Immersive Theater
krichter1 is offline
post #6282 of 11353 Old 04-01-2012, 05:04 AM
jimim's Avatar
Quoted: 496 Post(s)
Liked: 143
Attached is a rudimentary 'Grab' from my Mac to see what you guys think of the design (I also created some blanks ON & OFF if anyone needs them.
I take screen shots on the iPad and then upload em.
jimim is offline
post #6283 of 11353 Old 04-01-2012, 05:39 AM
mborner's Avatar
Quoted: 59 Post(s)
Liked: 26
Looks good, Kevin.
mborner is offline
post #6284 of 11353 Old 04-01-2012, 08:28 AM
krichter1's Avatar
Liked: 2293
Looks good, Kevin.
Ahh... thanks... much better!
Kevin
post #6285 of 11353 Old 04-01-2012, 12:06 PM
jimim's Avatar
Quoted: 496 Post(s)
Liked: 143
looks real nice and clean. did u just change the pixel size in ps?
jim
jimim is offline
post #6286 of 11353 Old 04-01-2012, 12:52 PM
Glimmie's Avatar
Quoted: 761 Post(s)
Liked: 634
Originally Posted by kriktsemaj99 View Post
You can drag buttons or other images and save them as files, but not after you import them into Builder. You have to do it while browsing the image libraries. Preview the images in a library by pressing on the "eye" symbol, then drag an image from there to a folder.
(I never would have guessed that either, but someone posted the recipe here some time ago.)
This doesn't seem to work anymore? Has something changed in Irule Builder or with Chrome? I was able to do this a year ago.
Glimmie is offline
post #6287 of 11353 Old 04-01-2012, 01:43 PM
osupike99's Avatar
Quoted: 122 Post(s)
Liked: 38
I think you can now only do it in Internet Explorer.
Alex
osupike99 is online now
post #6288 of 11353 Old 04-01-2012, 02:49 PM
Glimmie's Avatar
Quoted: 761 Post(s)
Liked: 634
Alex
But Irule isn't compatible with IE. When you got to it, a message comes up first warning you that IE is not compatible with Irule. If you ignore it and continue you next get the "script is not responding" message. Killing that stops all further Irule Builder page activity.
What changed with Chrome? This was an important feature for building buttons.
Glimmie is offline
post #6289 of 11353 Old 04-01-2012, 07:20 PM
osupike99's Avatar
Quoted: 122 Post(s)
Liked: 38
IE9 is compatible.
No idea what changed. I just know what still works.
Alex
post #6290 of 11353 Old 04-02-2012, 03:47 AM
mborner's Avatar
Quoted: 59 Post(s)
Liked: 26
It won't work for me in Chrome or IE. Don't know why they changed it, to me that feature was c r i t a c a l.
mborner is offline
post #6291 of 11353 Old 04-02-2012, 05:52 AM
coffeeguy57's Avatar
I am having the same issue, have you emailed tech support?
coffeeguy57 is offline
post #6292 of 11353 Old 04-02-2012, 06:12 AM
jimim's Avatar
Quoted: 496 Post(s)
Liked: 143
My biggest problem right now is chrome loading time. It takes a good 1 min to load the page to get going and wen I save it takes 2 to 3 mins anymore?
jimim is offline
post #6293 of 11353 Old 04-02-2012, 06:20 AM
Jim Clamage's Avatar
Kev,
Looks great for guys like us to use...but when your wife sits down by herself, what button(s) does she press to watch TV? That's why I designed my around activities. Adds 1 step but makes it idiot proof, still allows me to have access to all the source tweaking I want to do.
Jim Clamage is offline
post #6294 of 11353 Old 04-02-2012, 06:38 AM
robdek's Avatar
I recently added my Epson 8350 to iRule and used the "All Epson Projectors" shared device for codes, however, I have a concern over the power off code.
When I use the remote and press the power button, I am prompted on screen to confirm shutdown. I am then required to press the power button one more time. When using iRule the device shuts down immediately. This is no big deal, but I also think the projector fan would continue to run for a period when shutting down with the remote, which is not happening with iRule.
Has anyone else experienced something similar? Am I possibly using the wrong code?
Rob
robdek is offline
post #6295 of 11353 Old 04-02-2012, 09:44 AM
nosdude's Avatar
Quoted: 13 Post(s)
I need help with Feedback "starts with" and "ends with" commands; and any Query commands for Denon Receivers please.
nosdude is offline
post #6296 of 11353 Old 04-02-2012, 11:21 AM
Dragging buttons from user library - broken?
Using Chrome last night: 1) Browse image library. 2) Click on "eye" to open up a view of the images. 3) Ctrl+click and drag an image to the desktop. 4) Open that file in PS. 5) Change and save 6) Open builder, image library, import image.
Jim
post #6297 of 11353 Old 04-02-2012, 11:28 AM
My "starts with/ends with" is blank.
Jim
post #6298 of 11353 Old 04-02-2012, 11:35 AM
absolootbs's Avatar
Quoted: 18 Post(s)
Liked: 27
Jim
hmm, sure enough, this does work (chrome 17.0.963.83). never used to have to use ctrl before. now it appears to be necessary. whatever... as long as the functionality is there one way or another, thats all i care about.
absolootbs is offline
post #6299 of 11353 Old 04-02-2012, 12:14 PM
nosdude's Avatar
Quoted: 13 Post(s)
Originally Posted by Jhair View Post
Can someone provide me a really simple step-by-step on how to setup feedback for Denon AVRs? I have always controlled my AVR via tcp/ip. I just added iRule's feedback for Denon TCP/RS-232 and connected it to the device. Control still works just fine, but all of the feedbacks come back blank. I saw the tutorial on the iRule site but it wasn't really helpful. Based on that I've tried inserting 0x0D in the ends with and suffix areas of a bunch of the feedback config screens, but that didn't work either. I feel like I'm missing something basic here. HELP! :-)
EDIT: More tweaking (basically reverted everything to defaults) and I've finally figured out the problem (I think). Nothing is displayed until i make a change. In other words, I load up the page and until I turn the volume up or down, nothing is displayed for volume level. Until I change the source, nothing is displayed for source. Is this right???
Can you please tell me what command you have in your Entrance query. For example I had tv/getTuned for my DirecTV query as shown below:
nosdude is offline
post #6300 of 11353 Old 04-02-2012, 02:49 PM
Glimmie's Avatar
Quoted: 761 Post(s)
Liked: 634
Yes, using Ctrl works for me too.
Glimmie is offline
Reply Remote Control Area
Denon , Denon Avr 3311ci Receiver , Sharp Aquos , Lcd Hdtv , Receivers Amplifiers , Philips Pronto Tsu7000 The Intelligent Remote Control For Home Theater
