iRule - Page 331 - AVS Forum | Home Theater Discussions And Reviews
 68Likes
post #9901 of 11048 Old 06-12-2014, 05:09 PM
rysmithjr's Avatar
Anyone here intimately familiar with iRule and want to build a custom remote setup for me? I poked around but realized I just don't have the time to really dig into all the intricacies to get it running, but would do better seeing a working version and modifying it over time.
More of a meeting room setup, with a projector & motorized screen, a home theatre amp & a monoprice 6 zone amp, 2 lcd tv's, a pc with webex & ip softphone (for conference calls) with a pa system being the audio source, global cache itach flex for IP & serial control. More details if anyone is interested in a paying gig, of course.
rysmithjr is offline
post #9902 of 11048 Old 06-13-2014, 12:19 PM
s.bradford's Avatar
For those of you with Macs, you might want to check this out.
s.bradford is offline
post #9903 of 11048 Old 06-14-2014, 05:01 AM
Mark P's Avatar
Liked: 30
Wait.......what, I wish I was better at this stuff!
Mark P is offline
post #9904 of 11048 Old 06-17-2014, 01:49 PM
jidelite's Avatar
Quoted: 41 Post(s)
VPL-HW55ES RS232 codes for Sony projector
Derived from some of the existing HW30ES/HW50ES RS232 Device/feedback codes and Sony Protocol doc, sharing code in the User Community database (not sure if this applies to all SONY VPL projectors):
-Device codes w/Queries = Sony VPL-HW55ES RS-232_0614
-Associated tokenized Feedback = Sony HW55ES-Feedback-Tokenized_0614
Lots of commands with specific values I didn't do (too time consuming and toggling was easier) but I guess I could provide sample code if nec.
jidelite
Done Deal DR likes this.
jidelite is offline
post #9905 of 11048 Old 06-18-2014, 08:43 AM
CIH USER
Franin's Avatar
Quoted: 2012 Post(s)
Liked: 1162
Hi all
I'm looking at changing over from a pronto tsu 9800 to irule.
I've been looking at the GC 100-12 and if I had to buy more than one for the same room ( mainly use for Rs232, some ir and relay ) will that work?
The reason I ask is they will be sharing the same router.
Franin is online now
post #9906 of 11048 Old 06-18-2014, 10:04 AM
DGF
DGF's Avatar
Liked: 39
Hi all
Not sure I fully understand your question, but the primary reason for needing a second GC100 would be if you don't have enough serial or relay 'ports' - an IR emitter or blaster can obviously communicate with multiple devices, so depending on device placement, IR wouldn't be the trigger to buy another Global Cache unit.
The GC100 is a dated unit (replaced by a range of iTach devices), but I've used one for several years very successfully. You can now pick them up at pretty decent price points, but you need to make sure that you use the latest firmware (updating is a 'factory only' procedure, but GC turn things around quickly and IIRC only charge $45US - not show how this would play out with you being located in Australia though). The main limitation of using a GC100 versus something like an iTach is that the '100 can only process one command from one device at a time, whereas the iTach can handle multiple simultaneous sessions - for some people this is a show-stopper, but I have never found it to be an issue. IMO you can't beat the GC100 for connectivity and price - to replicate the functionality with iTachs would cost many hundreds of dollars more.
Just shout if I've misunderstood your question and I'll make another attempt at answering!
Dave
[All work just stopped in our office to watch the Holland/Australia game - currently 2:2 - all very exciting!!!!]
DGF is offline
post #9907 of 11048 Old 06-18-2014, 12:16 PM
JVoth's Avatar
Quoted: 228 Post(s)
Liked: 109
Hi all
If you are trying to get a GC-100-12 to work with IR and RS-232 you're going to have a really hard time. I was told by the IRule staff that the GC-100 are out dated hardware and can only accept 1 connection at a time. I was having a really hard time controlling my Lumagen. It would work one out of 10 times after I would restart it and even then I could never get the feedbacks to work correctly. They refunded almost all of my money and sent me the ITach's to replace the GC-100. I've never had an issue since. The feedacks show up everytime and everything is being controlled perfectly. I would highly recommend not buying a GC-100.
JVoth is offline
post #9908 of 11048 Old 06-18-2014, 02:48 PM
Liked: 0
Is there a tutorial on how to find and create gateways and ultimately setup the control? I'm running the trial now and having difficult.
Here are our devices:
- Samsung LED TV BN68-02543F-02
- Sharp LCD TV
- Harman Kardon AVR247
- JVC RX-8030V
- Motorola QIP7232
- Etekcity 6x2 HDMI Matrix Switch/Splitter
- Samsung BD-D6500 Blu-ray
- Apple TV
- Smartlabs RemoteLinc #2440 Lighting System
We want to use IP where we can and WIFI2IR from GC.
a12en is offline
post #9909 of 11048 Old 06-18-2014, 04:16 PM
kriktsemaj99's Avatar
Quoted: 609 Post(s)
Liked: 336
The GC-100 accepts one connection for each RS-232 port and another for IR. It's not as bad a limitation as it sounds. What you describe sounds like a defective unit.
kriktsemaj99 is offline
post #9910 of 11048 Old 06-18-2014, 04:36 PM
JVoth's Avatar
Quoted: 228 Post(s)
Liked: 109
It very well could have been. I'm just relaying what the IRule guys told me on their website and going off of my own experience. It's outdated hardware and the ITach's are better. That's their words not mine. I do think their support sucks and they may not know what they are talking about but I'm still suggesting ITach's.
JVoth is offline
post #9911 of 11048 Old 06-18-2014, 07:31 PM
jidelite's Avatar
Quoted: 41 Post(s)
Using a GC-100 for RS232 purchased off ebay (old firmware) and its been working ok. To cover themselves, I'm sure iRule 'will push' the iTach due to less complications...If you are only using a single device to control and you space out macro commands (with delays) the GC-100 should work well. BUT - I did run into a situation with the old firmware that made me purchase an iTach IP2SL (didn't feel like sending in my GC-100 for repairs):
1) My max baud rate is 19200. I guess most devices use a baud rate < 19200 but I needed a baud rate of 38400 for my Sony HW55ES.
2) Had trouble updating the config file for the GC-100 with Internet Explorer 10. Weeks later I found something that said try putting the browser in IE8 compatibility mode - that did work...
jidelite
jidelite is offline
post #9912 of 11048 Old 06-18-2014, 07:43 PM
jidelite's Avatar
Quoted: 41 Post(s)
- Sharp LCD TV
- JVC RX-8030V
- Motorola QIP7232
- Apple TV
Probably won't answer all your questions but there is a video tutorial (Gateway Setup in Version 3 - NEW for v3!) on their site to get you started...the iRule support staff can probably get you through your setup (and this forum will get you through the rest)...
jidelite
jidelite is offline
post #9913 of 11048 Old 06-18-2014, 11:10 PM
CIH USER
Franin's Avatar
Liked: 1162
Dave
Hi Dave
I have a minimum of 6 components that require rs232. But checking the prices over here the GC-100-12 is $500AU. I'll have to reconsider the best way for me too go.
[ we lost in World Cup ]
post #9914 of 11048 Old 06-18-2014, 11:13 PM
CIH USER
Franin's Avatar
Liked: 1162
Thank you for your reply I'm glad I asked here first. I'll have to see which is the best way to go. I wish irule was able to communicate with my philips extenders, have plenty of them.
post #9915 of 11048 Old 06-19-2014, 04:22 AM
Axel's Avatar
Quoted: 67 Post(s)
Hi Dave
Hi Franin;
I use like several others here a Digi PortServer TS. They are IP to RS232 converters. Used ones can be found on eBay. There are different h/w flavors out there, so you have to look a bit for what you are buying. I remember quite a bit of conversation and information here in the thread. A search should turn it up.
Prices seem vary quite a bit, but I would not pay more than $50-$100 for an 8 port model.
____
Axel
Axel is offline
post #9916 of 11048 Old 06-19-2014, 06:54 AM
CIH USER
Franin's Avatar
Liked: 1162
Originally Posted by Axel View Post
Hi Franin;
____
Axel
Thanks for the info Axel. So how does for instance an Oppo BDP 103 connect to one of these controlled by serial using the Rs232 port? How does Irule recognise this in there Irule app? I only see network, http, itach and the GC-100-12.
Sorry for the questions I want to make sure 100% before I get right into.
Thanks for your help
_________________________
post #9917 of 11048 Old 06-19-2014, 07:08 AM
Axel's Avatar
Quoted: 67 Post(s)
Hi Frank;
I have found that RS232 codes work the same as IP codes.
A digi has individual addressable RS232 ports. These can be addressed in iRule-Gateways through the digi's IP address and respective port number.
Example:
the digi's IP is 192.168.1.20
your Oppo is connected to digi's serial port #1
your projector is on digi's serial port #2
=> in the iRule-Gateway you configure each of the devices individually under NETWORK as:
192.168.1.20:2101 for the Oppo
192.168.1.20:2102 for the PJ
Hope this helps!
____
Axel
Axel is offline
post #9918 of 11048 Old 06-19-2014, 07:11 AM
Axel's Avatar
Quoted: 67 Post(s)
I forgot to mention that depending on the model / hardware / firmware revision the digi's allow for concurrent connections.
____
Axel
Axel is offline
post #9919 of 11048 Old 06-19-2014, 02:02 PM
osupike99's Avatar
Quoted: 107 Post(s)
Liked: 36
- Sharp LCD TV
- JVC RX-8030V
- Motorola QIP7232
- Apple TV
Also, don't automatically assume that if there is an app for your equipment, it is IP controllable by a third party app like iRule.
None of the Samsung equipment is IP controllable by iRule. AppleTV is also not IP controllable (by anything other than the Apple Remote app).
Alex
osupike99 is offline
post #9920 of 11048 Old 06-19-2014, 10:59 PM
CIH USER
Franin's Avatar
Liked: 1162
Hi Frank;
Example:
Hope this helps!
____
Axel
Hi Axel thanks for your response, I would like to know how would I plug to the oppo serial port?
I couldn't find any cables from they're website they all look like standard cat 5 cables.
post #9921 of 11048 Old 06-20-2014, 05:04 AM
Axel's Avatar
Quoted: 67 Post(s)
Ahhh, got it, Frank. You would need some DB9M/RJ-45 adapters, like this one:
http://www.monoprice.com/Product?c_i...seq=1&format=2
The DB9 part comes as male or female. You either plug it in directly in your oppo or in the serial cable that connects to the oppo.
The RJ-45 end of the adapter connects via a regular Ethernet cable to the digi.
____
Axel
Axel is offline
post #9922 of 11048 Old 06-20-2014, 05:43 AM
CIH USER
Franin's Avatar
Liked: 1162
____
Axel
Fantastic Axel. Thank you so much and thank you to all who replied. I will now endeavour to buy these items.
Frank
post #9923 of 11048 Old 06-20-2014, 05:55 AM
Axel's Avatar
Quoted: 67 Post(s)
Glad I could help, Frank!
_____
Axel
Franin likes this.
Axel is offline
post #9924 of 11048 Old 06-20-2014, 07:03 AM
RParkerMU's Avatar
Not sure if anyone replied to you, but it can be kind of challenging doing this remotely. Maybe there is a iRule integrator or someone on the forum local to you?
RParkerMU is offline
post #9925 of 11048 Old 06-20-2014, 10:05 PM
CIH USER
Franin's Avatar
Liked: 1162
Is Irule Builder down? Cannot seem to access with Safari and Chrome.
post #9926 of 11048 Old 06-21-2014, 09:03 AM
Axel's Avatar
Quoted: 67 Post(s)
Works for me here in the US. I just tried with Chrome and FF. FF has always been very slow for me, but Chrome was/is fine.
____
Axel
Axel is offline
post #9927 of 11048 Old 06-21-2014, 09:59 AM
CIH USER
Franin's Avatar
Liked: 1162
____
Axel
Thanks Axel I found out what it was, I had to sign out from my google account and then log in again which irule asked for permission to access ( something in those lines ). But all good know
post #9928 of 11048 Old 06-23-2014, 05:38 AM
Graham N's Avatar
Hi,
It must have been ages since I last posted on here. I haven't caught up with what's been going on but I have searched on line and looked at the irulebuilder without success.
I have changed some of my gear and it is about time I brought my irule settings uo to date. I believe I am using some modified versions of Steves backgrounds at the moment with the wood grained side panels and black centre. I have decided to redo everything in retina resolution. I was shocked at the limited amount of retina backgrounds and buttons available.
I couldn't find any similar backgrounds to the ones I am using in either the community or irule sections. In the irule section there are plain backgrounds in portrait and landscape mode with or without navigation bar but no retina buttons. It is a long time since I used the builder so perhaps I am doing something wrong.
Has anyone got any links to any retina backgrounds and buttons or method on making my own
thanks in advance
Graham
Graham N is offline
post #9929 of 11048 Old 06-23-2014, 08:37 PM
ellisr63's Avatar
Quoted: 920 Post(s)
Liked: 395
I am thinking of moving from CQC to iRule, and I am getting real frustrated trying to find out what can and can't be done with iRule.
Before I do I need to know if these devices would be good with it...
Denon 4520ci
ELK M1 gold
AprilAire thermostats
XBMC
JRiver
Panasonic AE8000
BenQ w1070
ISY 9941
Irrigation Caddy
Can I get it up and running on a PC to see if I like it, and if I do can I use a win 7 tablet to control everything or do I need to go the Apple, or Android route?
If so what do I need to get it to work on my PC?
How hard is it to get it up and running?
Are the graphics easily designed or are there a selection to use?
tia,
Ron
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #9930 of 11048 Old 06-24-2014, 03:30 AM
Done Deal DR's Avatar
Quoted: 92 Post(s)
Liked: 141
Denon 4520ci - Yes
ELK M1 gold - Don't know what this is
AprilAire thermostats - Don't know, this would be dependent upon the ISY system I'd think
XBMC - Not sure, probably
JRiver - Yes
Panasonic AE8000 - Yes
BenQ w1070 - Yes
ISY 9941 Yes - There is also a module available
Irrigation Caddy - Dont Know, I would think this would tie into the ISY system
tia,
Ron
Some answers above in bold.
You can't operate iRule on a PC, you can only create the design and functionality on the PC but from there the configuration must be pushed to a mobile device to use it. You will need some global cache gear in order for iRule to work on all of that equipment as well. Some can be controlled via IP with no additional gear (I'm sure you Denon and likely a couple others such as ISY), but others will need RS-232 or IR equipment to control it. I don't think Windows tablets are supported either, currently just Android and Apple products I believe. There is pre-made graphics to use for various buttons, they are somewhat limited but you can also search for user provided artwork to use as well. If you can program home automation, I'm sure you could do this as well.
All in, it's usually only $200-$400 for most people to get iRule going with everything, including the global cache gear and iRule licenses.
I'm far from an expert but have been using iRule for over a year now, though I haven't jumped into home automation yet.
Home Theater Build in Progress (Contemporary living room, Klipsch RF-7 II 5.2 audio, Sony VPL-HW50ES Projector, Da-Lite 16:9 159" HP, recessed Mid Atlantic rack, etc)
Done Deal DR is offline
Reply Remote Control Area
Denon , Denon Avr 3311ci Receiver , Sharp Aquos , Lcd Hdtv , Receivers Amplifiers , Philips Pronto Tsu7000 The Intelligent Remote Control For Home Theater
