iRule - Page 338 - AVS Forum
post #10111 of 10139 Old 10-15-2014, 02:27 PM
mikenike88's Avatar
Originally Posted by RDHolmes View Post
To put this in different words, you don't really want to get rid of the basket of remotes next to your viewing chair. You want to replace them with a folder of APPs on you Smart Device.
No integration, just select the TV APP to turn on the TV and select the TV input, then select the AVR APP to turn on the AVR and select the Blu-Ray input, then select the Blu-Ray APP To control the Blu-Ray-Ray player. Then when you are done reverse the above process.
I would say that I would rather use a hard-buttoned remote for control of A/V gear, with maybe an app like Roomie or Logitech Harmony in place of iRule. Then, when I want to control my Thermostat switch to the Nest app, Lights switch to Smartthings/Staples Connect/Lutron, Camera switch to Dropcam, etc. iRule's modules system is clunky and way too overpriced. Frankly, the per module per handset pricing system is a ripoff in my opinion.
iRule provides the potential for seamless integration between an almost unlimited portfolio of devices. The user interface has the potential for almost unlimited customization. How much of this power is actually used for you system is completly up to you.
Is iRule perfect? No, it can't do everything. If you happen to have devices that are not in the database, it is possible to use the learning capability of the iTach device to build your own set of IR Codes. This gets iRule pretty close to be able to do whatever you want and provide an integrated approach to controlling pretty much everything in your House.
Disclaimer, I do not work for iRule nor do I have any financial interest in iRule. I am just a satisfied user that has been using iRule control my A/V devices for more than three years.
When my Blu-Ray player died recently it took me less that 15 minutes to update my iRule System to the new player from a different manufacturer.
I agree completely that you get out of iRule what you put into it. I have probably put 100+ hours into multiple interfaces over the years, but I'm sick of doing that and going forward I want an app that actually looks nice and is easy to use, not one I have to design myself.
mikenike88 is offline
post #10112 of 10139 Old 10-15-2014, 02:39 PM
mpg732's Avatar
Originally Posted by ChldsPlay View Post
I'm totally new to all of this, but I am looking to implement some control of my equipment and lighting in my theater. I was going to have some AV guy setup a system, but someone suggested I look into iRule, and Insteon lights. This looks like it might be a great way for me to save some money, but I'm not clear on exactly what I'll need to get started. I know I'll need the iRule software, and one of the global caches (not sure which though), but I'm not sure what I need from Insteon, and what I'd use to communicate between the two. Can anyone explain this to me and break down everything I'll need? I won't necessarily be in a rush to have everything perfect, so I can take the time to learn how to make it work right. I do want to make sure I understand the concept for it though and plan for any wiring I'd have to do before I start construction.
What hardware you will need to buy depends on what you need to control. You will need an IOS or Android device as a remote. You will also need a wireless router preferably connected to the internet. You create your layout with in the web builder and then DL them to your device. IR and RS232 controlled devices will need a global cache device. IP control does not need any additional hardware. Amusing those devices are connected to your network.
mpg732 is online now
post #10113 of 10139 Old 10-15-2014, 03:17 PM
thebland's Avatar
Quoted: 289 Post(s)
Liked: 157
I now have iRule controlling:
My whole (very sophisticated ) theater,
My family room TV,
A smaller TV in the kitchen
Master Bath.
It's pretty coool that anywhere I want to watch TV (or comandeer control), I just pull out my phone (or ipad) and I'm in command!
My Home Theater of the Month- Le Petit Trianon
There are more than a handful of [op amps] that sound so good that most designers want to be using them as opposed to discreet transistors. Dave Reich, Theta 2009
thebland is offline
post #10114 of 10139 Old 10-16-2014, 04:49 PM
thebland's Avatar
Quoted: 289 Post(s)
Liked: 157
One thing. Why can't I get IR control to work with my APPLE TV.
I've tried all codes
My GC is sending the codes but no response.
Cannot figure his out.
Any ideas?!
thebland is offline
post #10115 of 10139 Old 10-16-2014, 05:25 PM
mpg732's Avatar
Any ideas?!
Should work but may be take a look at this.
http://support.apple.com/kb/ht3296
post #10116 of 10139 Old 10-17-2014, 06:30 AM
therockhr's Avatar
Any ideas?!
I know that when Roomie used to use IR and Global Cache for Apple TV you had to unpair the existing remote.
therockhr is offline
post #10117 of 10139 Old 10-17-2014, 07:12 AM
thebland's Avatar
Quoted: 289 Post(s)
Liked: 157
I'll try that. I tried the suggestion above but had a hard time getting commands copied. I did a few and then they still didn't work.
For now I am using 'launch' but will give this a go.
thebland is offline
post #10118 of 10139 Old 10-18-2014, 06:21 AM
thebland's Avatar
Quoted: 289 Post(s)
Liked: 157
For iRule, is there really any advantage in using the Mini with Retina over the Standard Mini?
I have a remote for my Ipad Air and one on my iPhone 6+ to control my theater.
If I buy an newly discounted Ipad MINI or MINI w/ Retina, will both remotes translate well to either new device and work and look correctly?
thebland is offline
post #10119 of 10139 Old 10-20-2014, 06:26 AM
jkosharek's Avatar
Liked: 0
Go with Mini with Retina
I would suggest the iPad Mini Retina, because it shares the same screen size as your iPad Air so you could use your current iPad Air remote. If you bought the non retina iPad Mini you would need to create an entire new handset/remote for the device.
jkosharek is offline
post #10120 of 10139 Old 10-20-2014, 05:34 PM
lchiu7's Avatar
Originally Posted by Done Deal DR View Post
.. Compared to iRule where I'm scouring for codes and looking through the awful search feature, there's just so much room for growth here. Well over a year later and I'm still missing crucial commands for some of my devices. I made adjustments here and there and overall my remote gets a bit better with each revision. I would also like to see more iRule provided buttons.
I can echo those comments. My devices were not particularly strange (well perhaps a HDMI switch and Asian streaming media player) but I could not find remote codes for them.
I spend ages trying to use the iLearn program for the iTach Global Cache device to no avail. The design and location of the IR receiver in that device is pretty poor.
In the luckily, because from another system setup, I have a USB-UIRT device, I was able to use a free utility I found which uses that device to learn codes from the remotes I could not find. And the utility also has a feature to test the code learnt so I could blast the learnt command back to make sure it was learnt correctly before pasting it into iRule.
To be fair, Global Cache have a large database of IR codes which they referred me to where I found IR codes for one my devices.
lchiu7 is offline
post #10121 of 10139 Old 10-20-2014, 05:55 PM
Done Deal DR's Avatar
Quoted: 22 Post(s)
Liked: 96
Where is the database?
Home Theater Build in Progress (Contemporary living room, Klipsch RF-7 II 5.2 audio, Sony VPL-HW50ES Projector, Da-Lite 16:9 159" HP, recessed Mid Atlantic rack, etc)
Done Deal DR is offline
post #10122 of 10139 Old 10-20-2014, 06:06 PM
lchiu7's Avatar
I guess they won't mind my sharing since the page says available to partners and hardware owners
http://irdb.globalcache.com/
lchiu7 is offline
post #10123 of 10139 Old 10-20-2014, 06:17 PM
Quoted: 22 Post(s)
Liked: 96
I agree, and I'd have to think most everyone here owns their hardware. Unfortunately I only use IR on a couple devices and they are all set, I'm missing codes for RS232 devices and it doesn't look like they have a database for that.
Thank you nonetheless for posting the database link.
post #10124 of 10139 Old 10-22-2014, 10:43 AM
ChldsPlay's Avatar
Quoted: 84 Post(s)
I'm trying to figure out how I would control my Crown XLS 5000 amp with iRule. My receiver doesn't have a trigger that can turn it one when it comes on. Are there any IP/IR/Serial controlled outlets or anything that can be used (fyi, the amp is 20A)?
The Hodor Theater - In Progress
Projector - Panasonic PT-AE8000U
LCR speakers - JTR Noesis 228 HT
Surround/Back Speakers - Klipsch Pro Cinema KPT-8000M
Subwoofers - Dual Passive JTR Captivator Pros
Receiver - Onkyo TX-SR608
ChldsPlay is online now
post #10125 of 10139 Old 10-22-2014, 12:48 PM
fumoffu's Avatar
I use the GC-100's Contact Closure Relays to trigger a Furman PS-8R power sequencer. The sequencer turns on my amps an equalizers in the right order prevent any popping and too quick of an inrush of power all at once. Furman also has a single relay box too.
fumoffu is online now
post #10126 of 10139 Old 10-22-2014, 04:42 PM
michaelp2005's Avatar
I'm hoping this is a dumb question
Anyway, I've just added a handset for a nexus7 with 1920x1200 resolution. When I'm in the builder is there a way to "shrink" the page image so I can see the full page in my browser, and not have to scroll right/left up/down? This would make it easier for button placement etc.
My existing handset was also a 7" tab, but smaller resolution. I would simply maximise my browser and the whole page was visible without any scrolling needed.
Michael
michaelp2005 is offline
post #10127 of 10139 Old 10-22-2014, 08:04 PM
osupike99's Avatar
Michael
Try zooming out your browser. Typically View=>Zoom Out.
Alex
osupike99 is offline
post #10128 of 10139 Old 10-22-2014, 09:04 PM
Thanks that worked, (went to 75%) but does make the menu trees on each side much smaller, can't have everything I suppose.......
Gator99 likes this.
post #10129 of 10139 Old Yesterday, 08:20 AM
Gator99's Avatar
That has always bothered me about their web interface.
Sent from my Nexus 5 using Tapatalk
Jeff
Gator99 is offline
post #10130 of 10139 Old Yesterday, 09:13 AM
ChldsPlay's Avatar
Quoted: 84 Post(s)
Would you happen to have a link to the single relay box?
post #10131 of 10139 Old Yesterday, 12:35 PM
magicj1's Avatar
Quoted: 35 Post(s)
Hi.
I wish to make a button to control a program on my HTPC. I simply want that button to use 'CTRL & E' from a keyboard.
Is this possible?
magicj1 is online now
post #10132 of 10139 Old Yesterday, 12:53 PM
ChldsPlay's Avatar
Quoted: 84 Post(s)
Would something like this http://www.insteon.com/2475SDB-In-LineLinc-Relay.html allow me to control a 20 Amp outlet my Amp was plugged into using iRule?
post #10133 of 10139 Old Yesterday, 01:20 PM
fumoffu's Avatar
This is the Power Port I was thinking of. Looking on Amazon it seems over priced, but it does include some type of "power filtering" or protection:
http://www.furmansound.com/product.p...=01&id=PWRPORT
This MP-20Q seems reasonable priced, but is a 2 gang outlet receptacle so it may be the wrong form factor:
http://www.furmansound.com/product.php?div=01&id=MP-20Q
I don't know if this is your best option, just helping with the posibilities.
post #10134 of 10139 Old Yesterday, 02:35 PM
Steve Goff's Avatar
Originally Posted by magicj1 View Post
Hi.
Is this possible?
Yes, you can do this using MCE Controller, as discussed many times. There is a tutorial on how to set this up. MCE Controller will simulate key presses, and does otter useful things like start programs and shut down the PC. You can download it and read the help materials to get started.
Steve Goff
Steve Goff is offline
post #10135 of 10139 Old Yesterday, 03:50 PM
Axel's Avatar
Quoted: 18 Post(s)
I believe so. I use Insteon outdoor plugin modules to control a couple of space heaters. Works fine.
____
Axel
Axel is offline
post #10136 of 10139 Old Yesterday, 10:53 PM
magicj1's Avatar
Quoted: 35 Post(s)
Great stuff. Cheers Goff.
post #10137 of 10139 Old Today, 08:16 AM
Gator99's Avatar
Steve I have been searching for a way to get feedback to work for my HTPC WMC 7, but MCE CONTROLLER doesn't do it nor will the developer be adding this feature soon or ever. Have you or anyone else found a solution for this?
I have found VMCController but can't seem to get it installed to test and it hasn't been updated since 2009.
Jeff
Gator99 is offline
post #10138 of 10139 Old Today, 11:05 AM
Steve Goff's Avatar
MCE Controller was meant to work as a remote control for Windows Media Center. It can't do things like feedback. For that you would need something like Eventghost, I would think. MCE Controller can be extended by adding to the commands file. I've done this to add programs that it can start and key presses I needed. It is very useful, but will never be updated to include new functionality.
Steve Goff
post #10139 of 10139 Old Today, 11:13 AM
Gator99's Avatar
Thanks, I have not tried Eventghost in a very long while as I don't want any IR used in my system. Can you tell me if Eventghost can be controlled only via IP control?
Jeff
Gator99 is offline
Reply Remote Control Area
Denon , Denon Avr 3311ci Receiver , Sharp Aquos , Lcd Hdtv , Receivers Amplifiers , Philips Pronto Tsu7000 The Intelligent Remote Control For Home Theater
