iRule - Page 341 - AVS Forum
post #10201 of 10224 Old 11-19-2014, 09:57 AM
Kazuya (FR)'s Avatar
Originally Posted by RDHolmes View Post
Hard to try the codes since I don't have an OPPO!
Of course ! lol
Can you share it ? Maybe we can try.
Now on AVS, discover a plug and play setup for HTPC, with amazing video quality: the Config Kaz 7 !
Kazuya (FR) is offline
post #10202 of 10224 Old 11-19-2014, 03:16 PM
jidelite's Avatar
Quoted: 12 Post(s)
Originally Posted by Ediddy View Post
Is there anybody out there running an OPPO 103 that uses IRule? I just got the pro license and I'm trying to figure out what hardware I'll need. I am also running a Sony VPL ES55 with an integra 80.3. iRule support said I might be able to control the projector via Hdmi through my integra. Anybody out there have any luck?
Don't think I would use HDMI CEC with my 55ES but the manual says you can use HDMI control for Power off/on (but I think to control other devices to power on/off). I use RS232 (have a GC-100-12 (from ebay) and a iTach ip2SL) to control my 55ES and OPPO 93 - works great and with feedback it makes iRule that more powerful.
jidelite
jidelite is offline
post #10203 of 10224 Old 11-19-2014, 07:49 PM
d_c
d_c's Avatar
Quoted: 118 Post(s)
Liked: 117
Are there ANY clear tutorials, videos, instruction, links, or discussion on implementing any of my hardware below? The iRule tutorials have 75% of the info (I have been through all of them at least twice, PDF and videos) and the forum discussion is all over the place. I need to follow at least one part START TO FINISH to get the programming down, ie, Insteon scenes (which I have ready) linked to the ISY module to buttons on the remote connected to my device (iPhones). I understand some parts of each tutorial but cannot link them together to get much of anything to happen. I really want to make this work because I have seen it work the way I need it to, but am very frustrated over the 16 hours or more I have put in to this with almost nothing. There seems to be people who understand this right away that are on a level so far ahead and others like me drowning. I have the next 4 days off and am determined to get this going. Here's what I am using below:
iPhone 4 handsets
Insteon lighting
ISY994i (scenes configured, Mobilic app controlled for now, gateway connects)
GC 100-16 (configured, gateway connected)
ISY Module
Onkyo/Integra Module (this one was easy, the tutorial explained it)
Vizeo LCD display
AT&T Uverse (Motorola)
Win7 HTPC / JRiver
Sony BD player
Would starting an "iRule for Dummies" thread be appropriate for those that are left with their wheels spinning like myself after reading the tutorials?
Doug
d_c is offline
post #10204 of 10224 Old 11-19-2014, 08:01 PM
jafterdark's Avatar
Can the newer model samsung tv be control over Ip
I decompile the Samsung apk don't know what I'm looking for in side of it anybody help
jafterdark is offline
post #10205 of 10224 Old 11-21-2014, 02:18 PM
d_c
d_c's Avatar
Quoted: 118 Post(s)
Liked: 117
I have a functioning iRule handset thanks to Gator99!!
Now I need to get a switch controlled with Insteon. My handset is linked to my ISY Gateway and is connected, but I'm not sure I'm coding them right. I'm following this example to build my device code for a Dual-band dimmer switch to control an LED light:
I entered this in the "NAME" field in Properties: Device ID 10:A7:50
(I entered this n the "data" filed of Properties: rest/nodes/10%20A7%2050%201/cmd/DON/255
I dropped this into my "light-on" macro
saved
synced
nothin'. What am I missing?
d_c is offline
post #10206 of 10224 Old 11-21-2014, 02:18 PM
d_c
d_c's Avatar
Quoted: 118 Post(s)
Liked: 117
I entered this in the "data" filed of Properties: rest/nodes/10%20A7%2050%201/cmd/DON/255
saved it
saved
synced
d_c is offline
post #10207 of 10224 Old 11-21-2014, 02:19 PM
ChldsPlay's Avatar
Quoted: 93 Post(s)
Those with more experience with iRule, would you recommend a 7" or 10" tablet? A 7" would be much easier to handle and cheaper, but I think the 10" might give me make creating panels less cramped?
And please help d_c, I'm going to have to start working with iRule soon, and he's local, so I may want to pick his brain when I get there.
d_c likes this.
The Hodor Theater - In Progress
Projector - Panasonic PT-AE8000U
LCR speakers - JTR Noesis 228 HT
Surround/Back Speakers - Klipsch Pro Cinema KPT-8000M
Subwoofers - Dual Passive JTR Captivator Pros
Receiver - Onkyo TX-SR608
ChldsPlay is offline
post #10208 of 10224 Old 11-21-2014, 03:41 PM
bryansj's Avatar
Quoted: 97 Post(s)
Liked: 195
I've set up iRule on an iPad Mini (first gen) and a Nexus 7 (2013) as well as an HP Touchpad which is the same size and resolution as an old iPad. I prefer the mini tablets for remote use. If I was given both an iPad Mini and Nexus 7 I'm not sure what I would go with. For the price I'd pick the Nexus every time. The only reason I'd go with the iPad Mini is because iRule seems to focus on iOS first and then Android.
bryansj is offline
post #10209 of 10224 Old 11-21-2014, 04:12 PM
Axel's Avatar
Quoted: 20 Post(s)
For a dedicated remote, I think a 16 GB Apple refurb. iPad mini retina (1. gen) make an excellent choice:
1) holding a smaller (screen) size (7") is easier
2) retina screen for a crisper display, rather than the original low res. model
3) Apple refurb, because they can be had much cheaper than the 2. gen mini retina - apart from the finger print sensor, the h/w is the same. I do not need such a sensor on my remote
4) 16 GB, i.e. the entry level - it is a remote, so only minimal storage is needed
5) iRule seems to focus on iOS over Android
Hope this helps.
_____
Axel
johnsills1 likes this.
Axel is offline
post #10210 of 10224 Old 11-21-2014, 06:07 PM
Gator99's Avatar
Quoted: 22 Post(s)
saved
synced
Doug, to be clear in your example above for your ISY command, you need to make sure you replace the 10:A7:50 with the insteon address of your device, the example 10:A7:50 is just an example, each insteon has a unique address. Once you have found your unique address "xx:xx:xx", the data command would be .. rest/nodes/xx%20xx%20xx%201/cmd/DON/255
Jeff
Gator99 is offline
post #10211 of 10224 Old 11-21-2014, 07:18 PM
jafterdark's Avatar
has anybody tried this product
http://lightberry.eu/#page-8
post #10212 of 10224 Old 11-21-2014, 07:58 PM
d_c
d_c's Avatar
Quoted: 118 Post(s)
Liked: 117
Yes, this I did. I tried it for a couple of different switches too. There is an on, off, and 50% example that I found in the search within iRule. I swapped out the numbers of their device with my own. I will try it again with one you just posted above.
d_c is offline
post #10213 of 10224 Old Yesterday, 12:59 AM
michaelp2005's Avatar
Have you had any issues with your Nexus 7 freezing? I'm constantly having it freeze, or press the button multiple times.
michaelp2005 is offline
post #10214 of 10224 Old Yesterday, 06:40 AM
pm240sx's Avatar
Noob to the irule deal but I've read as much as I could. Does anyone use irule to fully automate security and heating? Can it even do that?
HTPC are awesome get one today!
pm240sx is offline
post #10215 of 10224 Old Yesterday, 06:49 AM
Gator99's Avatar
Quoted: 22 Post(s)
Something is happening to my nexus 7 (2013). As you indicated it freezes plus it crashes if I have conditionals in my main entrance support so far has not been able to figure it out.
Sent from my Nexus 5 using Tapatalk
Jeff
Gator99 is offline
post #10216 of 10224 Old Yesterday, 06:51 AM
Gator99's Avatar
Quoted: 22 Post(s)
Doug first things first are you able to control your switch from the isy PC interface or phone app?
Next have to ask but is the isy have a static IP as we discussed the other day? Or does the irule app show the gateway to the isy as connected?
Jeff
Gator99 is offline
post #10217 of 10224 Old Yesterday, 11:08 AM
d_c
d_c's Avatar
Quoted: 118 Post(s)
Liked: 117
iRule
Yes and yes
ISY program works great, all devices connect
Mobilinc free app works, but is limited to 4 devices to control (Mobilinc app screenshot)
I have deselected DHCP in isy and entered the info manually. I am getting connection at the iPhone (iPhone screenshot below)
d_c is offline
post #10218 of 10224 Old Yesterday, 11:58 AM
Gator99's Avatar
Quoted: 22 Post(s)
Not sure if no one else chimes in here I would post on I rules forum. Sorry
Edit. Since I don't use the isy is it possible that you are using IR commands from your iRule devices. I am not even sure they exist but remember we changed your onkyo from IR to IP.
Jeff
Gator99 is offline
post #10219 of 10224 Old Yesterday, 12:13 PM
d_c
d_c's Avatar
Quoted: 118 Post(s)
Liked: 117
They are ip for sure. The connection indicator in the lower left of the iPhone signals when the button is depressed, stays green throughout. I think it's somewhere between how I made the button, the code, and isy
d_c is offline
post #10220 of 10224 Old Yesterday, 04:29 PM
petercw2's Avatar
Originally Posted by osupike99 View Post
As for Insteon.... You can control it in 3 ways...
2. Insteon Hub/Smartlinc. You can control these directly over their network connection. Commands are in the builder. Search for Type=Lighting + Vendor=Insteon
Hello again... finally getting around to attempting this.
I purchased the Hub and two Insteon dimmer switches.
It seems that the only way to pull this off in iRule is through a bit of a hack, but I think I'm not fully understanding how to use the RAW codes, has anyone here successfully integrated the Insteon Hub into iRule and care to share your learnings?
I've not installed anything yet as I want to understand how I'm going to accomplish this before I open boxes, do wiring/install, and screw around with my iRule setup.
In reading about this, it seems that the ISY box is the better solution but it's also about $150 more than the Hub (plus I got the Hub at Best Buy)...
thanks.
petercw2 is offline
post #10221 of 10224 Old Yesterday, 05:10 PM
osupike99's Avatar
Make sure in the app, you are creating a HTTP GATEWAY with port 80 (ISY default) and make sure you are populating username and password fields with the username and password you use for accessing ISY's web interface or Java console.
Alex
Gator99 likes this.
osupike99 is offline
post #10222 of 10224 Old Yesterday, 07:08 PM
Gator99's Avatar
Quoted: 22 Post(s)
thanks.
I wouldn't say I have fully integrated my hub and insteon equipment yet but I have simple commands that turn off and on my lights, from what I understand the isy module includes sliders for dimming and I am not sure but feedback might be easier as well but I haven't gotten fully engaged in the setup yet.
The sample commands in the builder will get you started. Is there something more specific you need?
Jeff
Gator99 is offline
post #10223 of 10224 Old Yesterday, 09:09 PM
jidelite's Avatar
Quoted: 12 Post(s)
thanks.
I had a Smartlinc 2412N die on me so I had to switch to the Hub. All I do for my lights is On, Off, and incremental Dim with feedback (is that full integration ). Once I got the Hub setup, my commands for iRule remained the same and the Hub has been stable. For what I use my lights for the ISY was overkill for me.
jidelite
jidelite is offline
post #10224 of 10224 Old Yesterday, 09:40 PM
petercw2's Avatar
Ok, this is very helpful. I only have two dimmer switches (theater room & hallway) and a plug module (LED rope lighting) that I want to be able to control in iRule. So maybe this is exactly what I need.
I guess where I'm getting lost is how you build it in iRule.
I'm guessing that you drop a network code from the Insteon RAW scenes, but I don't understand how
1) you adjust the "data" in the properties to address a specific light
2) where you find the address for each of the different lights
it appears that you set up each switch in the Insteon Hub app by simply "adding" them. Should I assume the app also gives me the IP or whatever address I need to point to that switch?
Is there a different set of codes I should be utilizing?
Can you still create macros with this setup?
thanks again.
petercw2 is offline
Reply Remote Control Area
Denon , Denon Avr 3311ci Receiver , Sharp Aquos , Lcd Hdtv , Receivers Amplifiers , Philips Pronto Tsu7000 The Intelligent Remote Control For Home Theater
