iRule - Page 349 - AVS | Home Theater Discussions And Reviews
post #10441 of 10453 Old 02-27-2015, 07:09 AM
Gator99's Avatar
Quoted: 50 Post(s)
Originally Posted by Ryan Rosser Byorick View Post
Can anyone point me to an earlier post or provided some advise regarding using iRule with a Grafik Eye QSGRJ-6P and QSE-CI-NWK-E. I have been using iRule successfully for several months on regular devices (via GC-100). I just bought my Grafik Eye and the Ethernet adapter. Using the Lutron IPConfig tool, it is recognizing that the Grafik Eye is connected on my network. In iRule though, when I go to try to configure the device it only seems to allow me to assign it to the GC-100 which it isn't directly connected to. How do I get thing working?
Ryan - I just installed this same setup for a friend, but we didn't use iRule for the control, after looking at the iRule builder, there seems to be NO IP commands available so that is your first and real problem. Have you submitted this question over at the iRule forums?
I am not saying I know how to do this, but in the past I needed a IP code that wasn't in their database and I used Wireshark to "sniff" the packets sent and after alot of work found what I needed although the admins at iRule were very helpful.
Sorry I can't be more helpful.
Jeff
Gator99 is online now
post #10442 of 10453 Old 02-27-2015, 08:00 AM
SeldomSeen31's Avatar
Originally Posted by thebland View Post
GARAGE DOOR OPENERS: Contact Closure? Do garage doors open and close using contact closure when using the wall mounted, wired switch in the garage? I have Genie doors and would like to control them.
Would iRule using the ITACH IP2CC, specifically designed for contact closure switching?
ALSO, can the i-Tach be set up to give me feedback to know if the doors are open or closed?
I use a gc-100-12 with contact closure to control my garage doors. I ran a cat5 cable from my equipment rack and used 4 of the wires to wire in to my 2 garage door buttons on the wall. Works great. The global cache relay device in the builder is what I am using. I've found that sending the ON command followed by a .8 second delay and then the OFF command and then another .8 delay and the OFF command again ensures that all works well. A few times before adding that second OFF command the contact closure stuck ON, which was like holding the garage door button down, this prevented my garage door from functioning with my regular RF remote in my car. Haven't had a problem since adding it.
Feedback isn't possible. There is a query command, but I believe it will only tell you if the contact closure is ON or OFF which doesn't really tell you if your garage door is open or closed.
I use Tasker on my Android phone to launch iRule when within range of my home WiFi. When I'm walking back home from the park with my kids I just pull out my phone and there is my iRule garage door home panel, press the number 1 button and up goes the door. It's great only having to take my phone with me going places, no more keys or spare garage door opener.
I have no experience with it, but I do use other insteon devices with iRule, they have a garage door kit that would provide feedback if I it works as their other devices do. If you have other lighting and automation needs that might be something to look in to. You could also add a cheap IP camera which is something I've thought of doing and get visual confirmation that the door is open or closed.
Good luck with your project.
PSN ID: Seldom_Seen
SeldomSeen31 is online now
post #10443 of 10453 Old 02-27-2015, 08:28 AM
Quoted: 79 Post(s)
Liked: 4
In your installation did you wire the GC in series to the wall buttons ?
triplejs15 is online now
post #10444 of 10453 Old 02-27-2015, 08:52 AM
I am far from an electrician so instead of saying yes or no here I will tell you exactly how I wired it. If I had to guess, I would say conceptually that it is wired in parallel. From GC-100 I have the orange and orange striped wires from the cat5 wire run to garage door button 1. I pulled it off the wall and added the orange and orange striped wires to the wires that were already there running from the garage door motor to the wall button. I used the green and green striped wires to do the same on my second garage door button. At the gc-100, I used the included wire terminals to connect the orange set to relay 1 and the green set to relay 2. I have 2 buttons on my "Garage" panel and each triggers the desired relay, the button on the wall of the garage blinks just as if I pressed it by hand.
PSN ID: Seldom_Seen
post #10445 of 10453 Old 02-27-2015, 09:01 AM
mdavej's Avatar
Quoted: 906 Post(s)
Liked: 519
Feedback?
Hmm, I guess I would install my own limit switch at the top of travel on one side rail. I did something like that for a laser parking system in mine (high-tech hanging tennis ball replacement). I don't know if you can get up/down status from the motor or not. Would have to see the drawings.
mdavej is offline
post #10446 of 10453 Old 02-27-2015, 11:34 AM
Liked: 0
Gator99 - what software were you using to control the Grafik Eye? Good idea on the Wireshark, I've used that at work - just not sure if I have the time to go that crazy with it. Seems like controlling via IR might be my least time intensive.
Ryan Rosser Byorick is offline
post #10447 of 10453 Old 02-27-2015, 12:13 PM
Gator99's Avatar
Quoted: 50 Post(s)
Ryan I used IR with a harmony ultimate remote works great
Sent from my Nexus 5 using Tapatalk
Jeff
post #10448 of 10453 Old 02-27-2015, 12:15 PM
Glimmie's Avatar
Quoted: 253 Post(s)
Liked: 288
Most garage door openers use a simple contact closure, a door bell button. If yours has two wires going to the button, that's probably the case. If you have some fancy keypad, it may be more sophisticated.
For a two wire button system, just wire the Itach relay in parallel with the manual button. It doesn't matter which wire is which. The Itach is a dry relay.
The Itach shown will work with a contact closure based system. As for feedback, the GC100 has a way of getting feedback through an IR port. I don't know if this Itach can accept a contact closure input?
NOTE: Feedback or door position is possible and cheap to implement!
If you can't directly interface to the opener, you can always mount a magnetic alarm switch on the garage door and jamb and just wire that sensor to an Itach input.
I would call the Itach people and ask how they do contact closure input (sensing) on the newer models. They do have good tech support.
FWEIW, I do my contact closure sensing through a DIY box that sits on the house network. IOW, my own version of the Itach.
Glimmie's HT Page
Being redone - comming soon!
Glimmie is offline
post #10449 of 10453 Old 02-27-2015, 07:57 PM
pc8888's Avatar
Is it just me that irule iphone app now showing banner ads at the bottom after today's update?
I am very upset that a paid app doing that.
pc8888 is offline
post #10450 of 10453 Old 02-28-2015, 06:21 AM
Gator99's Avatar
Quoted: 50 Post(s)
Checked their forums, try logging out and back in that seems to fix for some but not all.
Jeff
post #10451 of 10453 Old 02-28-2015, 06:53 AM
Liked: 0
Yes!!! Me too, just started today. I thought maybe I had some kind of pop up virus on my Samsung Tab.
post #10452 of 10453 Old Today, 05:03 AM
mborner's Avatar
Yes, me too. Logging out, then back in, seemed to have worked.
mborner is online now
post #10453 of 10453 Old Today, 09:00 AM
d_c
d_c's Avatar
Quoted: 237 Post(s)
Liked: 203
I was unable to sync with the new update along with a lot of other people from what I read over a the iRule help desk - most of whom are pissed! Won't sync even with the less secure settings enabled in Google, updated version on phone in app, and restarts. The only way to get it to work is to log in to GooglePlus and share your "circle of friends" and email addresses with Google. Lame.
d_c is online now
Reply Remote Control Area
Denon , Denon Avr 3311ci Receiver , Sharp Aquos , Lcd Hdtv , Receivers Amplifiers , Philips Pronto Tsu7000 The Intelligent Remote Control For Home Theater
