iRule - Page 363 - AVS Forum | Home Theater Discussions And Reviews
 55Likes
post #10861 of 10868 Old 01-30-2016, 10:31 AM
osupike99's Avatar
Quoted: 95 Post(s)
Liked: 34
Originally Posted by Mwickham25 View Post
Hello, I want to control five Vizio TV's on the same wall. Is the Irule something that can do that? How would I get the signal to each tv separately so I can turn them on individually and control the volume on each individually? I will just be using the TV's speakers. Is there a hub with IR extenders that can go to each tv?
Can I control multiple apple TV's via IP while using IR boosters to the TV's at the same time?
Very new to this. Thank you for the help. Looking for a remote or app that can help me with this.
You will need to use 2 iTach IP2IR or WF2IR gateway and put each TV device driver that you import in the builder to a separate IR port on the back of the gateway. That way you have discrete control of each TV. IR emitter from each port will be run to each of the TVs.
osupike99 is offline
post #10862 of 10868 Old 01-30-2016, 02:49 PM
Mwickham25's Avatar
Thank you! Will check this out.
Mwickham25 is offline
post #10863 of 10868 Old 01-31-2016, 01:19 PM
Kazuya (FR)'s Avatar
Yamaha 2040 control by IP
Hi,
I have a problem with the Yamaha 2040, I succeed to make iRule controls a few commands but a lot them doesn't work !
Here what actually works with Yamaha AVR HTTP Control - Zone 1 list :
_ volume up
_ volume down
_ mute
_ adventure mode
_ straight mode
_ power off
But power on, options, on screen menu, input 1 and a lot of other doesn't...
Do you have any suggestion ?
I tried several lists on iRule database (dealer and community too), but nothing better.
Now on AVS, discover a plug and play setup for HTPC, with amazing video quality: the Config Kaz 7 !
Kazuya (FR) is offline
post #10864 of 10868 Old 01-31-2016, 07:33 PM
Mwickham25's Avatar
Will the Itach Flex (the newer version of the IP2IR) work n the same way as the IP2IR.
post #10865 of 10868 Old 01-31-2016, 08:56 PM
osupike99's Avatar
Quoted: 95 Post(s)
Liked: 34
Yes, it works in the same manner when used with triple IR emitters.
Gator99 likes this.
post #10866 of 10868 Old Yesterday, 05:36 PM
impmonkey's Avatar
Is anyone else really disappointed in the lack if improvement in iRule in the last year or so?
The modules are extremely limited, ugly and have not really changed since they were introduced.
Android is still really buggy and the get satisfaction site has less and less employee involvement. Heck half the questions go without any input from anyone involved with irule.
Maybe all the improvements are things I dont use, but I have been rather disappointed in the stalemate of my remote.
impmonkey is offline
post #10867 of 10868 Old Yesterday, 05:39 PM
ERuiz's Avatar
Quoted: 457 Post(s)
Liked: 144
iRule
One of my biggest worries is the fact that it is all web-operated. If one day iRule tanks and bites the dust, what will happen? We won't be able to continue developing our remotes?
Efrain "AviatorBimmer" Ruiz
ERuiz is online now
post #10868 of 10868 Old Today, 04:39 AM
mborner's Avatar
iPhone 6 Background
Does anyone know the background image size for an iPhone 6, with and without the navigation bar? I can't find it anywhere on iRule's website or in this thread.
mborner is online now
Reply Remote Control Area
Denon , Denon Avr 3311ci Receiver , Sharp Aquos , Lcd Hdtv , Receivers Amplifiers , Philips Pronto Tsu7000 The Intelligent Remote Control For Home Theater
