iRule - Page 368 - AVS Forum | Home Theater Discussions And Reviews
 67Likes
post #11011 of 11025 Old 07-05-2016, 04:54 AM
RandyFinVA's Avatar
In the Community tab, Select Type as "lighting" and scroll down (the search doesn't work for me) to "RGB LED-strip." Import that device. The Pronto Hex codes will send the right commands to the Global Cache IR module.
Thanks Matt, much appreciated! Didn't think to look in the Community tab for these.
RandyFinVA is offline
post #11012 of 11025 Old 07-05-2016, 07:23 AM
BrolicBeast's Avatar
Quoted: 993 Post(s)
Liked: 940
No problem!
Sent from my SAMSUNG-SM-G935A using Tapatalk
BrolicBeast is offline
post #11013 of 11025 Old 07-05-2016, 09:54 AM
dalto's Avatar
Quoted: 1224 Post(s)
Liked: 629
Originally Posted by MichiganTim View Post
Universal remote app for Zigbee RF4CE - Comcast X1. iRule?
Is there a Universal remote app for Zigbee RF4CE - Comcast X1?
Does iRule work with Zigbee RF4CE - Comcast X1?
Does iRule work with Vizio 2016 P series/ Smart control?
Does iRule have bluetooth support?
I am not an expert in irule but as far as I know irule is IP control only so if you want to talk to a device using Zigbee you need a device that can accept IP commands and transmit Zigbee.
Originally Posted by jimim View Post
hey guys. i have a friend who changed providers. the modem/router now has a diff IP address so the itaches can't connect cause their ip address is a x.x.254.x the new router is a x.x.0.x what is the best way to get them back online?
the itaches all have manual ip's. should i hook my computer directly up to them to access them and change the ip and then deploy or is their a better way? if i reset them they will still to match the router ip cause they go back to default which might not match the .0. ip if i do hook directly to the computer i set a manual address to the computer of say x.x.0.90 or higher and i should be able to see them again.
was looking for some direction so i'm not up there forever today.
thanks!
jim
There are a lot of options here.
First, the easiest solution would be to change the router to use the old internal IP scheme. Than everything will just work the same way it used to. You won't have to change the itachs or the gateways on all the devices.
If you want to instead change the itachs then you just need to connect your computer to the network and give it a static IP address on the old network scheme. This will allow you to connect to all the itachs on the old IP scheme assuming the network is flat which it probably is.
In either scenario you are going to have to go into the router and find or set an IP range that is excluded from the DHCP scope so you don't have IP conflicts.
jimim and BrolicBeast like this.
dalto is online now
post #11014 of 11025 Old 07-05-2016, 12:04 PM
Axel's Avatar
Quoted: 64 Post(s)
According to the Google PlayStore the Vizio tablet that comes with the P series TV "isn't compatible with this version" of iRule.
Kind of surprising, as it seems to be a pretty standard android tablet.
With the P series popularity, I hope that iRule implements the necessary compatibility tweaks very soon.
I would also like to use (iRule) IP commands to control the Vizio, but I don't think Vizio has released an IP command protocol/documentation (yet).
_____
Axel
Axel is offline
post #11015 of 11025 Old 07-05-2016, 05:15 PM
jimim's Avatar
Quoted: 268 Post(s)
Liked: 81
ok so i did all the ip changes. all good. question. you can't use the legacy logins anymore can you? they won't work? i have to have him use the google plus logins right, but that isn't working though?
so i can't synch devices?
jim
jimim is online now
post #11016 of 11025 Unread 07-26-2016, 11:28 AM
ChldsPlay's Avatar
Quoted: 573 Post(s)
Liked: 303
Does anyone have a suggestion for which device to use for a Phillips blu-ray player. Specifically, the BDP-7501 (UHD blu-ray player). I see some phillips blu-ray player devices, but I'm not sure which would be best. They also all appear to be IR, are there any that are IP?
Also, does anyone happen to know where the IR sensor is exactly on this device? It is not visibly apparent to me (EDIT: Nevermind on this part, I see in the manual where it is located).
The Hodor Theater - Now with Atmos
Projector - Panasonic PT-AE8000U
LCR speakers - JTR Noesis 228 HT (3)
Surr./Back - Klipsch Pro Cinema KPT-8000M (4); Atmos In-ceiling - Niles DS8HD (4)
Subwoofers - Passive JTR Captivator Pro (2) - Powered by Crown XLS 5000.
Receiver - Yamaha Adventage A3050
ChldsPlay is online now
post #11017 of 11025 Unread Yesterday, 12:35 PM
ChldsPlay's Avatar
Quoted: 573 Post(s)
Liked: 303
Another thing I am having issues with is Feedback with my Yamaha A3050. I am pretty sure I am doing it right, but I have never bothered with feedback in the past since my Receiver was the only thing I would want it for and until recently what I had wasn't capable of feedback.
I have the feedback: Yamaha AVR HTTP - Zone 1 and I have set the device to Yamaha AVR HTTP Control - Zone 1.
I've added a query command to my buttons for volume, and I've dragged the feedback onto the pages that I want it on, and even tried setting it as an entrance on one page.
When I use the app, nothing shows up on any pages that should have the feedback. I can see that iRule is sending the query command (GET VOLUME LEVEL) when I use my volume buttons and when I enter the one panel, but still I see nothing.
I noticed the "hide after (sec)" is set to -1.0 by default, but I figured this is just so that it remains visible at all times?
I'm pretty sure this particular feedback is a bar, not just text, so shouldn't I at least see something, even if it's not updating the info?
post #11018 of 11025 Unread Yesterday, 12:49 PM
Quoted: 993 Post(s)
Liked: 940
What's your control device? I've found that feedbacks work really well on iPad, but not very well (or at all) on android devices (at least in my experience).
--Posted via Tapatalk, which actually is pretty cool.
post #11019 of 11025 Unread Yesterday, 01:00 PM
ChldsPlay's Avatar
Quoted: 573 Post(s)
Liked: 303
It's a Samsung Galaxy Tab 4.
post #11020 of 11025 Unread Yesterday, 01:05 PM
Quoted: 993 Post(s)
Liked: 940
I have a Galaxy Tab 3 and have never been able to do volume feedbacks on it. They work on my iPad though.
post #11021 of 11025 Unread Yesterday, 01:18 PM
ChldsPlay's Avatar
Quoted: 573 Post(s)
Liked: 303
That figures. Oh well, it's not a big deal to me. I was only trying it now because I was planning to help someone out with their iRule and figured I should brush up on it before I went over there. Pretty sure they have an iPad.
post #11022 of 11025 Unread Today, 01:09 PM
dalto's Avatar
Liked: 629
In order to get feedbacks working with my A2050 I had to send KEEP ALIVE commands.
dalto is online now
post #11023 of 11025 Unread Today, 01:44 PM
ChldsPlay's Avatar
Quoted: 573 Post(s)
Liked: 303
Were you using IP?
post #11024 of 11025 Unread Today, 01:48 PM
dalto's Avatar
Liked: 629
Were you using IP?
Yes. I am using the "Yamaha RX-A and RX-V Series TCP/RS232" device over IP.
dalto is online now
post #11025 of 11025 Unread Today, 07:26 PM
ChldsPlay's Avatar
Quoted: 573 Post(s)
Liked: 303
I tried that, but it didn't work. I did find another feedback someone had uploaded and it did end up working (without the need to keep alive). Didn't get the other text feedbacks to work though, but I'm not sure I'm querying the right thing (I'm only worried about the surround mode).
Reply Remote Control Area
Denon , Denon Avr 3311ci Receiver , Sharp Aquos , Lcd Hdtv , Receivers Amplifiers , Philips Pronto Tsu7000 The Intelligent Remote Control For Home Theater
