iRule - Page 369 - AVS Forum | Home Theater Discussions And Reviews
 70Likes
post #11041 of 11057 Old 08-16-2016, 05:03 AM
CIH USER
Franin's Avatar
Quoted: 2015 Post(s)
Liked: 1170
Originally Posted by thebland View Post
No problem. Thanks for the info. I will delete off the one Apple TV from my iPad (which I'm not using on that de ice) and add the one I want. Hopefully that does it.
Stay tuned. Thanks!
Hope it works out cause it's a pain in the ass.
________________
Frank
_________________________
Franin is offline
post #11042 of 11057 Old 08-16-2016, 03:47 PM
thebland's Avatar
Quoted: 1275 Post(s)
Liked: 670
________________
Frank
Fail!
Any other suggestions?
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
post #11043 of 11057 Old 08-16-2016, 04:02 PM
CIH USER
Franin's Avatar
Liked: 1170
Fail!
Just trying to make sure the basics are checked:
- Apple TV and iPad are on the same wifi router
- did you end up entering the code for the Apple TV ( the one you want to control ) and it showed successful
________________
Frank
Franin is offline
post #11044 of 11057 Old 08-16-2016, 04:18 PM
SJHT's Avatar
Quoted: 124 Post(s)
Liked: 67
I use IR (iTach) with the Apple TV and it works perfectly. Since I already had it for another component.... SJ
SJHT is offline
post #11045 of 11057 Old 08-16-2016, 04:21 PM
CIH USER
Franin's Avatar
Liked: 1170
That works as well only issue no feedback
________________
Frank
Franin is offline
post #11046 of 11057 Old 08-16-2016, 04:21 PM
thebland's Avatar
Liked: 670
________________
Frank
1. I'm using Ethernet. But yes, Ethernet to APPLE TV is coming from router same router providing wifi to iPad.
2. Yes, I go through the protocol and pair the iPad to the Apple TV and iPad says that it was 'successful'.
Gotta be something I'm missing. Maybe I'll try wifi rather than Ethernet with my Apple TV.
Thanks for the help.
post #11047 of 11057 Old 08-16-2016, 04:22 PM
CIH USER
Franin's Avatar
Liked: 1170
The new Apple remote app works well. Similar to Irule one.
________________
Frank
Franin is offline
post #11048 of 11057 Old 08-16-2016, 04:28 PM
CIH USER
Franin's Avatar
Liked: 1170
Happened to me too I got successful nothing I factory reset the unit and successful and still no go. Kept trying ( that close in giving up ) and then it worked. I found it takes a number of attempts. Like you I've always updated my Irule and Apple TV.
For my theatre I have a 11" Mac air connected by Ethernet ( bought one of those Apple USB Ethernet thingy mijigs ) Apple TV by Ethernet and download all my rentals and it works great. It's Dolby digital but it works great.
________________
Frank
Franin is offline
post #11049 of 11057 Old 08-18-2016, 08:34 PM
CIH USER
Franin's Avatar
Liked: 1170
How did you go Jeff?
________________
Frank
Franin is offline
post #11050 of 11057 Old 08-19-2016, 05:22 AM
thebland's Avatar
Liked: 670
________________
Frank
I'll try it again.
Funny thing is the iRule support page does not say to 'add a device'.
Yet, on my one working Apple TV, I've added a device (as we discussed).
post #11051 of 11057 Old 08-19-2016, 05:44 AM
CIH USER
Franin's Avatar
Liked: 1170
I'll try it again.
I find the support page not much help at times.
________________
Frank
Gator99 and 24Changer like this.
Franin is offline
post #11052 of 11057 Old Yesterday, 08:10 AM
roxiedog13's Avatar
Quoted: 783 Post(s)
Liked: 275
Harmony remote or go iRule
I already have the Harmony Ultimate running, works and simple but I'm not fond of the little screen which is too sensitive , small and seems to hang/pause too long for my liking.
I have a spare iPad kicking around and thought this would be a great addition to my theater but I'm not in the mood for a major setup and learning curve again. All opinions welcome.
Will use for home theater only , I have Insteon ISY994 controller and lighting in the theater already for Insteon.
Equipment list: JCV RS600 projector, Denon7200Wa, Samsung UB8500 4K player( Oppo coming), Oppo 103D
Lumagen 4440 Pro 4K, HD Fury Integral , Beringer 2 channel amp ( no remote control) , Panamorph DC1 A-lens with electric slide( IR remote) .
Dedicated Theater: JVC X950R/RS600 , Panamorph DC1 Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 132" diagonal curved 36FT radius, Denon X7200WA , 7.2.4 Atmos, Paradigm Monitor 11 fronts, Monitor 3 Center, Monitor V7 Rear, SA-ADP In-wall Surround, Niles DS-7 In-Ceiling, Subwoofers: (4000 watts peak) Klipsch RW-12 + SVS PC13-Ultra
roxiedog13 is online now
post #11053 of 11057 Old Yesterday, 07:02 PM
24Changer's Avatar
Quoted: 110 Post(s)
Liked: 122
Go iRule.
I was in a similar position; in my case I was using a Pronto 3500 that just wasn't cutting it more and I put off doing something because of the learning curve. Now I wished I had made the move to iRule sooner. I iRule isn't that difficult in my opinion and their support staff was very helpful with any questions I had. I am controlling all my devices over IP and using an ISY for my Insteon lighting. All is working great.
Creekside Stone Cinema
24Changer is offline
post #11054 of 11057 Old Yesterday, 07:37 PM
roxiedog13's Avatar
Quoted: 783 Post(s)
Liked: 275
Originally Posted by 24Changer View Post
Go iRule.
So your iRule controls the Insteon lighting using your ISY controller like the ISY994 that I have ? I'm actually surprised as I thought iRule only worked with Zwave controllers. I've seen ISY controllers that link to Zwave
recently, that looked even more complicated.
post #11055 of 11057 Old Today, 10:09 AM
24Changer's Avatar
Quoted: 110 Post(s)
Liked: 122
So your iRule controls the Insteon lighting using your ISY controller like the ISY994 that I have?
I am using a ISY994 w/PLM in conjunction with iRule.
post #11056 of 11057 Old Today, 11:00 AM
Axel's Avatar
Quoted: 67 Post(s)
Same here. It works very well.
_____
Axel
Axel is offline
post #11057 of 11057 Old Today, 02:45 PM
roxiedog13's Avatar
Quoted: 783 Post(s)
Liked: 275
Hate to ask but what is PLM?
Reply Remote Control Area
Denon , Denon Avr 3311ci Receiver , Sharp Aquos , Lcd Hdtv , Receivers Amplifiers , Philips Pronto Tsu7000 The Intelligent Remote Control For Home Theater
