iRule - Page 373 - AVS Forum | Home Theater Discussions And Reviews
 96Likes
post #11161 of 11186 Old 12-31-2016, 11:17 AM
DougUSMC's Avatar
Quoted: 274 Post(s)
Liked: 197
Originally Posted by thebland View Post
I don't see the issue. Kramer was already a share holder and bought out the other shareholders (including myself). Now they have it all.
iRule still runs my theater and other TVs around the house. I don't see that changing.
Still ultra flexible for a low, low cost.
Can we take that to mean that in your discussions/negotiations with Kramer you spoke of the future of the product, and they agreed to continue to support their DIY customer base?
DougUSMC is offline
post #11162 of 11186 Old 12-31-2016, 11:55 AM
jimim's Avatar
Quoted: 470 Post(s)
Liked: 141
I just can't see Itai giving up on the residential side and DIY side when this is the world he came from when he left his past job to start this full-time and for the future. he would be abandoning his complete past where it started, but then again money talks, but from what i know of him this seemed like it was his baby.
i still think all is good. i know the one supply house i buy from does a lot less with them over the years and have moving into other product. i can't even get global cache pieces from them anymore, but they are just as easy to get on amazon.
jim
thepainter likes this.
jimim is online now
post #11163 of 11186 Old 12-31-2016, 02:49 PM
thebland's Avatar
Quoted: 1499 Post(s)
Liked: 852
Not at all. I was simply an investor from when the company first started. I have no knowledge of residential plans as I'm officially out of the loop now. I personally don't see nor have I heard any plans scale it back. Business as usual. Kramer is a huge company and I expect they will support residential as they move to more commercial. I certainly don't have plans on dropping it. Still the best deal in town for the best, most flexible remote!
thebland is online now
post #11164 of 11186 Old 01-08-2017, 03:28 PM
BrolicBeast's Avatar
Quoted: 1111 Post(s)
Liked: 1159
Greetings, all! If anyone is interested in picking up some Global Cache Gateways, let me know. I own 11 of them and only use 5, so I'm selling the remaining 6.
Link Here: Global Cache Gateways: RS-232 and IR
BrolicBeast is online now
post #11165 of 11186 Old 01-20-2017, 01:45 PM
drtechno's Avatar
Quoted: 30 Post(s)
Hi .. Quick question for everyone.
Do you guys know how to create semi transparent buttons ??
If you take a look at this remote from another thread, it looks like it has transparent buttons.
Or are they simply a background image over which you just place a dummy button in iRule?
Also, do you guys have info on what image formats are supported by iRule and how you set transparency ? If I want to create a button with just the letter 'X' how do I get transparency around the actual letter.
drtechno is offline
post #11166 of 11186 Old 01-20-2017, 01:56 PM
Steve Goff's Avatar
Quoted: 323 Post(s)
Liked: 152
Most buttons are PNG files, which can contain transparency.
Steve Goff
Steve Goff is offline
post #11167 of 11186 Old 01-20-2017, 02:13 PM
drtechno's Avatar
Quoted: 30 Post(s)
So I can just create any PNG file, set transparency according to the image format rules, and I should be able to import it into iRule as a button, correct?
As an example (using the above image), I would create a PNG black box with 50% transparency and add text on top of it? Then just create the exact same image with the text 'highlighted' for the 'button pressed' state?
drtechno is offline
post #11168 of 11186 Old 01-20-2017, 03:21 PM
Steve Goff's Avatar
Quoted: 323 Post(s)
Liked: 152
Yes, that would work.
Steve Goff
post #11169 of 11186 Old 01-23-2017, 11:35 AM
acmcool's Avatar
Quoted: 21 Post(s)
Liked: 37
Is anyone here using irule to control DLA-RS500U? Are you using IP,IR or Serial control?
acmcool is offline
post #11170 of 11186 Old 01-26-2017, 07:54 PM
SJHT's Avatar
Quoted: 247 Post(s)
Liked: 124
They all work fine. IP is a little different as you have to issue a request to connect to the projector prior to executing a command but it works fine. SJ
SJHT is online now
post #11171 of 11186 Old 01-27-2017, 11:49 PM
thepainter's Avatar
Just got a Xantech MRC88 on the cheap. Looking to control via GC-100 Serial. Can't seem to get it going, I downloaded their software and have tested source/Zone and everything seems just fine, however no love via serial. Is there anyone out there that has experience with the Xantech MRC88 that might be able to point me in the right direction. I have checked Baud rate. Tried straight through and Null cables - no joy. Thanks in advance.
thepainter is offline
post #11172 of 11186 Old 02-10-2017, 04:07 AM
CIH USER
Franin's Avatar
Quoted: 2196 Post(s)
Liked: 1319
Im aware that irule has been bought by Kramer but its been very quiet. Haven't seen any newly added features nor and App updates that keeps up with the Apple Software updates. Hopefully the haven't forgotten about us.
_________________________
Franin is offline
post #11173 of 11186 Old 02-10-2017, 05:45 AM
thepainter's Avatar
UPDATE, finally got it going. Seems to have been a problem with serial commands via my GC-100-06. Swapped with an itach and is now working with the codes found on site. Nothing added (no carriage return).
post #11174 of 11186 Old 02-14-2017, 04:35 PM
thebland's Avatar
Liked: 852
Any way to convert a larger iPhone remote (e.g. iPhone 6 Plus / 7 Plus) to a smaller iPhone 7??
When opening up my remote that was designed for the larger iPhone only new, smaller iPhone 7, the resolution and size of the smaller phone causes the remote to be unusable.
Any easy way to make it work in the smaller phone?
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
post #11175 of 11186 Old 02-17-2017, 12:50 PM
heffneil's Avatar
Not to be too off topic but I have a Kramer Matrix switch for my home theater and I have had a few issues with the box. Every time I reached out to them they have been great to deal with and have replaced the box now two times no questions asked!
I think their support for their customers is great. I do feel like this community has been quiet as well as the development from iRule. I hope some new cool stuff comes out but I will say that iRule does quite a bit of what I want it to do so that is great!
heffneil is offline
post #11176 of 11186 Old 02-17-2017, 06:48 PM
CIH USER
Franin's Avatar
Liked: 1319
I think irule is awesome, using it to its full potential, but it's good to read that Kramer has good customer service so let's hope there will be new cool stuff coming out soon.
Franin is offline
post #11177 of 11186 Old 02-21-2017, 09:04 AM
No Clue's Avatar
Quoted: 17 Post(s)
I have been unsuccessful trying to control my oppo 203 via rs-232 gateway. I am using the Poe global cache gateway. I already have an oppo 93 in the rack using rs-232 successfully.
When I press any button in irule for the 203, the icon in the lower left corner of my iPad shows in red. Does this mean it isn't communicating with the gateway or the oppo? I can connect via MacBook to the global cache when I type in the ip address and I have double checked the baud rate (9600) and other parameters. They are exactly the same as my oppo 93. I have even used the same rs 232 cable swapped from the 93 to the 203. I'm starting to run out of ideas.
I have also used several of the different oppo devices in irule builder.
No Clue is offline
post #11178 of 11186 Old 02-21-2017, 10:32 AM
sonoftumble's Avatar
Quoted: 184 Post(s)
Liked: 45
The red icon in the lower corner indicates that you are having a communication problem from the iPad to the actual iTach as opposed to the device that you are trying to control. With serial control, you have two stages of communication: The first stage is between the iPad and the iTach via an IP address that you assign to the iTach and match in the Gateways tab in the iRule/On Controls app. The second stage is the communication between the iTach and the device ( i.e. Oppo ) which only requires setting the correct baud rate using the web interface.
To that extent you can have a green gateway icon, but still not successfully control the serial device because the baud rate is wrong.
Your issue is strange since you are able to configure the iTach with its web interface. My opinion- there are four options to try:
1) Make sure to backup your gateways in the sync tab as you may need to restore them if #2 , #3 , and #4 don't help.
2) Force quit the iRule / On Controls app by quitting the app with the round home button on the bottom of the iPad, then double clicking that same button so you get the thumbnails of all the apps running in the background; and then swipe up the iRule / On Controls thumbnail to fully quit the app. Relaunch iRule / On Controls and see it that clears it up. Sometimes a config file needs to be rebuilt to clear out the cobwebs. Force quitting causes a new, clean file to be created. It will not impact your handset or coding.
Still have a problem?
3) Sync and restore gateways and give it a spin.
4) Download "Fing" to your iPad from the app store. It is a free network scanner. Scan your network. You may have more than one device; i.e. a computer and the iTach "sharing" the same IP address. IP address conflicts will cause red gateways.
Still have a problem? The nuclear solution . . .
5) Delete your iRule / On Controls app and re-install from the app store. At that point you will need to sign-in again, sync and restore gateways. This is why you backed up your gateways in step #1. This will blow out the entire project and give you a fresh version of everything.
After that, if you are still having an issue, I would point the finger at a faulty iTach.
Let me know.
sonoftumble is online now
post #11179 of 11186 Old 02-21-2017, 10:33 AM
thepainter's Avatar
Check the connection setting for the global cache that it's "multiple"
post #11180 of 11186 Old 02-21-2017, 11:12 AM
Quoted: 184 Post(s)
Liked: 45
I use Photoshop to set transparency levels depending on the effect I'm trying to pull off. The best image format to use is png. High quality but small. I've created semi-transparent drawers so that when you open them, they look like heavily tinted sliding glass doors. Kinda cool. Still can see what's underneath but not distracting.
post #11181 of 11186 Old 02-21-2017, 11:57 AM
thepainter's Avatar
Just got home, under the serial setting check multiports is enabled.
post #11182 of 11186 Old 02-21-2017, 12:12 PM
No Clue's Avatar
Quoted: 17 Post(s)
Is that referring to Enable multiple ports option?
No Clue is offline
post #11183 of 11186 Old 02-21-2017, 12:13 PM
thepainter's Avatar
Yes
post #11184 of 11186 Old 02-21-2017, 12:44 PM
No Clue's Avatar
Quoted: 17 Post(s)
Let me know.
#5 fixed it. Thanks!
sonoftumble likes this.
No Clue is offline
post #11185 of 11186 Old Today, 08:53 AM
dancjodanc's Avatar
Quoted: 110 Post(s)
I've been an iRule user for years. I currently have a Theta CBIV, which with a serial connection iRule controls and has all the feedbacks. I'm thinking of selling the CBIV, and moving to Emotiva. They have a new pre/pro coming that seems to have it all. But I noticed that the codes in the builder of iRule are few, and I see no feedbacks for Emotiva? I can't image using my system with the feedbacks from the pre/pro telling me what's going on. Any suggestions?
dancjodanc is online now
post #11186 of 11186 Old Today, 10:24 AM
Quoted: 184 Post(s)
Liked: 45
I hear you when it comes to feedbacks. I can't live without them.
You will need to call Emotiva and find out if they have a document which lists the control and feedback codes for using a network attached remote control system. If yes to both, then you, ( or someone who knows how to do it ), will need to build from scratch or augment the existing device driver, and build from scratch the feedback driver. The Emotiva's use IP ( RJ-45 ethernet ) rather than serial for control. The IP commands for the XMC-1 in the iRule library may be the same as the new unit you are interested in, or they ( Emotiva ) may have changed them. Hopefully the command list ( if it exists ) will be more extensive. You can add additional device commands to an existing driver within the iRule builder.
There are a lot of great boxes out there that support IP control, but their engineers never bothered to program feedbacks; or never bothered to publish them. ( NAD comes to mind in that regard ). Best of luck with your research. Let us know what you find out.
Reply Remote Control Area
Denon , Denon Avr 3311ci Receiver , Sharp Aquos , Lcd Hdtv , Receivers Amplifiers , Philips Pronto Tsu7000 The Intelligent Remote Control For Home Theater
