iRule - Page 378 - AVS Forum | Home Theater Discussions And Reviews
 105Likes
post #11311 of 11319 Old 07-20-2017, 02:51 PM
24Changer's Avatar
Quoted: 116 Post(s)
Liked: 124
Originally Posted by jjwinterberg View Post
I'm looking over your right shoulder. I think iRule has been great. Even now my remote works fine and I'm able to update it no problem. I agree that the next OS update may change my mind but I'm giving iRule/Kramer the benefit of the doubt.
I also think that the real problem with iRule was their business model. I think that it's too tough to keep quality on-going support without some continuous revenue stream. Sure if programmable universal remotes were ubiquitous and there was a constant stream of new customers then maybe their one time license would work but in reality I think that we are a limited market. An annual subscription might have been workable.
Just my $0.02
I would agree. I would have paid a small annual fee, I think it was great product for what it was and the DIY crowd. As far as the OS update, don't update your device, I am not going to take the chance of an OS update screwing things. I also have a dedicated ipad that runs my system and that is all I use it for so I am not concerned about apps not working and the device not being current.. It works great right now I'm not messing with it.
Creekside Stone Cinema
24Changer is online now
post #11312 of 11319 Old 07-21-2017, 04:30 AM
mborner's Avatar
Quoted: 59 Post(s)
Liked: 26
Anybody using Tivo?
Hi, I'm trying to set up a Tivo T6 DVR and I'm only finding one set of ir codes in the database. Unfortunately, the code set is missing a few codes. I can't find the code for "on demand" or "menu" and also the command "Tivo" (the big Tivo button at the top of every Tivo remote.
mborner is offline
post #11313 of 11319 Old 07-22-2017, 07:54 AM
heffneil's Avatar
Quoted: 13 Post(s)
Just my $0.02
I agree there wasn't a revenue stream. I know for instance I have used a product like 1password which wasn't cheap in terms of other app pricing and at every new revision 2.x to 3.x they have an upgrade fee. Of course I am getting greater features with that expense so it is a win-win and we get continue development. This product didn't have it but if better skills and programming capabilities came along with a new version I would re-up but not idea what might happen and doesn't look positive.
heffneil is offline
post #11314 of 11319 Old 07-24-2017, 05:58 PM
razevents's Avatar
Quoted: 73 Post(s)
Liked: 26
So what's the next gen of the iRule concept? Harmony too simple, iRule will eventually dry up and it's other end of spectrum for level of complication.
razevents is online now
post #11315 of 11319 Old 07-25-2017, 08:37 PM
wnl
wnl's Avatar
Quoted: 14 Post(s)
Originally Posted by mdavej View Post
I'm talking about folks who are considering replacing iRule and Global Cache hardware with Kramer software and hardware. I wouldn't give them any new business myself.
Okay, gotcha! I misunderstood your comments. Thanks for clarifying.
If Kramer requires me to buy a proprietary and expensive controller then that's a definite "no" for me.
wnl is offline
post #11316 of 11319 Old 07-26-2017, 05:41 AM
Bulldogger's Avatar
Quoted: 229 Post(s)
Liked: 55
Going through the modules and speaking to Kramer they have told me the SL-280 is the one that is needed too work.
I contacted them. The Sl-240 is the minimum needed. You may have a larger system and need the SL-280. SL-240 retails for $900 but can be found on internet at lower price.
Never become so involved with something that it blinds you.
Bulldogger is offline
post #11317 of 11319 Old 07-26-2017, 05:55 AM
Bulldogger's Avatar
Quoted: 229 Post(s)
Liked: 55
Using the SL-240 and getting 4 RS232, and 4 IR, as well as 4 relay controls is cheaper than going the Global Cache route if you need more than 2 RS232 outputs like I do.
post #11318 of 11319 Old 07-27-2017, 05:47 PM
wnl
wnl's Avatar
Quoted: 14 Post(s)
I needed 4 RS232 outputs. Fortunately I had a linux server sitting in the corner doing nothing, and a 4-port USB serial hub left over from my previous automation setup. Linux socat makes a perfectly usable converter.
From what I can determine the SL-240 isn't cheap.
Doing a quick bit of research it seems to me that two GC-100-12 units (for a total of 4 serial outputs, 6 relay controls, and 12 IR outputs) is still less than a SL-240, and they can be used with anything that communicates over TCP.
wnl is offline
post #11319 of 11319 Old 07-28-2017, 11:13 AM
jjwinterberg's Avatar
Quoted: 67 Post(s)
Liked: 39
I use these for my rs-232 ports:
http://www.ebay.com/itm/MOXA-NPort-5...kAAOSwNnRYiC1y
If your equipment is arraigned fortuitously then perhaps an IR blaster will hit all the pieces?
jjwinterberg is offline
Reply Remote Control Area
Denon , Denon Avr 3311ci Receiver , Sharp Aquos , Lcd Hdtv , Receivers Amplifiers , Philips Pronto Tsu7000 The Intelligent Remote Control For Home Theater
