Roomie Remote - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 51Likes
post #361 of 2153 Old 03-22-2012, 07:02 PM
tclinch's Avatar
Originally Posted by lesliew View Post
Hi Guys
Purchased Roomie and a iTach Ethernet to IR this week, still waiting for the iTach to arrive.
Anyhow in the meantime I have been setting up some of my equipment that I can control over the LAN.
Not sure if this question has already been asked but does Roomie support Wake on Lan. Particularly interested in being able to wake my Mac Mini, which runs XBMC.
BTW, was very interested in the comments above about serial control of Epson projectors so might need to invest in the iTach to serial soon. I have the Epson 8700UB.
I control my Epsom 8700ub via serial using gc-100. Works great!
tclinch is offline
post #362 of 2153 Old 03-22-2012, 07:46 PM
DGF
DGF's Avatar
Liked: 39
Originally Posted by MasterC77 View Post
I've been using J River for many years now, and I find it to be by far the best media centre/program out there. If you are at all serious about getting the best SQ possible from your music, this is it.
I have not looked at other solutions as I am perfectly happy with J River. The amount of control that you can have over it using HTTP commands via the Webservice controls is staggering. My next step would be to integrate some sort of two way feedback, but I'm not sure that's possible at this time...
What is your setup for music playback using Roomie?
Thanks for the extra details. To answer your question, my own setup is still evolving - I've been focusing on control of my home theater, but my approach for music playback (currently dictated by a distinct lack of free time) is to gather all the jigsaw pieces before putting the full puzzle together. I anticipate using Pandora (or similar) from my iTouch, to an AppleTV puck, and then doing a D/A conversion to my B&K CT600 whole-house controller.
I used to run JRiver on an HTPC into the CT600 (and to a dedicated audio rig), but ultimately became tired with the overhead and relative inconvenience of having a Windows box in the chain. I've used JRiver's Media Center since version 7, and, IIRC, have a version 15 license currently. I hadn't really thought about using MC in my latest setup, but your comments about sound quality resonated with me (and awoke old demons!).
DGF is offline
post #363 of 2153 Old 03-22-2012, 08:17 PM
vincentfox's Avatar
Hi Guys
Serial control is the way to go with projectors! At least until IP control becomes standard.
vincentfox is offline
post #364 of 2153 Old 03-23-2012, 10:59 AM
hgmobile's Avatar
Quoted: 16 Post(s)
I have several different models of Motorola DC cable boxes in my home. Roomie Remote does an excellent job of controlling them except for the use of channel selection from the program guide. This happens on an iPhone 4 and an iPad 2.
When selecting channels or for that matter any command from the virtual controller I am not having any issues. It is only selecting a channel from the guide which gives me issues. On 3 digit channel numbers I sometimes get a smooth transmission of numbers to the cable box and everything works or I get a choppy transmission of the numbers and the cable box will only recognize a subset and switch based on that. (the way the sent numbers/commands display in blue on top of Roomie screen as well as numbers rec'd appear on TV screen)
eg: selecting the guide for channel 201 will sometimes give me channel 20, channel 1 or even switch to 20 and then to 1. Sometimes it will give me 201. No consistency. I have played with delays from 100 to 1000ms without any significant change. Have also played with re-transmit settings. Multiple combos & variations of same as well.
In all cases commands, numbers etc. sent from the virtual controller always work and channel selection from the guide is erratic. I am using the blaster on port 3 of the itach units.
Anyone else having this issue. Any solutions?
Update: Problem is resolved. Issue was a flaky DLink wireless router - seemed to rapidly reset connections. Changed to a new airport extreme and all switching seems fine as well as giving me better house coverage than the DIR655
Other than that I must say that Roomie has been great.
hgmobile is offline
post #365 of 2153 Old 03-23-2012, 01:35 PM
Andrew Wolfe's Avatar
I couldn't get the DC6416 to work reliably on channel change with any regular IR emitter. When I switched to the iTach IR blaster on output 3 - it got 99% reliable.
Make sure to set the iTach to IR blaster mode.
Andrew Wolfe is offline
post #366 of 2153 Old 03-23-2012, 06:56 PM
MasterC77's Avatar
Originally Posted by DGF View Post
I have a slightly outdated J River license and always perceived them to offer well-thought-out solutions, so I'd be interested to hear your approach and opinions on the outcome.
Did you look at any other options for tighter music integration with Roomie?
I should add that I use JRemote on my Ipad alongside Roomie when initially selecting which media I want to start playing be it audio or video. I would highly suggest to any J River users with an Ipad throw down the $10 now and grab this app. It is simply fantastic!
MasterC77 is offline
post #367 of 2153 Old 03-27-2012, 11:49 AM
Sodbuster's Avatar
Any recommendations?
I used EditRocket until my 30-day trial ran out, and I don't wish to pay $50 for such a limited need.
When I installed three different free editors, none would open the plist file created on EditRocket. I am completely clueless about this stuff and just slavishly plug the IR commands into the template furnished by Roomie.
Consequently I need to be able to add new commands for control of an HDMI matrix switcher without disrupting what's already in my plist file.
Bill Bunker
Sodbuster is offline
post #368 of 2153 Old 03-27-2012, 01:23 PM
SaulP's Avatar
I'm still enjoying my Roomie Remote and love the updates.
I just added an HTPC w/ a Ceton USB device to one of my rooms. I see that Roomie can control Windows Media Center either directly through IP or through IR. I was hoping that those of you who are using Roomie to control WMC could chime in on your experience and recommendations. I'm obviously leaning toward direct IP control but am curious about how "laggy" it is.
SaulP is offline
post #369 of 2153 Old 03-27-2012, 02:49 PM
Sodbuster's Avatar
Patience is not my long suit, so I forged ahead and paid for EditRocket. Then I was not able to correctly follow the formatting to add the switch to the RommieCodes plist. In the process of trying repeatedly, I noticed that there are codes already in the library for a Monoprice 4 x 2 HDMI switch. Thinking the JTech switch I had purchased and the Monoprice came from the same factory, so they probably use the same IR codes...and they do!
So I'm very pleased to have Roomie controlling everything so nicely that I expect my wife may no longer be intimidated, but very annoyed to have paid for an XML editor.
Bill Bunker
post #370 of 2153 Old 03-29-2012, 12:14 PM
SaulP's Avatar
Well, I went ahead and loaded MCE Controller and added direct IP control through Roomie. It seems to work very well. Not surprisingly, the MCE Controller application has to be running on your PC for it to work. However, if it is executing, there seems to be little lag.
The only problem is that MCE Controller cannot "wake" a computer from sleep or hibernation. Thus, the question I have (and that someone else posed a few days ago) is this: Does Roomie support Wake On Lan (specifically, can Roomie send a WOL "magic packet")? It should be simple enough to do. In fact, I'm currently using a free iPad app (Mocha) to wake my HTPC. It would be awesome if I could do it in Roomie.
SaulP is offline
post #371 of 2153 Old 03-29-2012, 03:39 PM
jbn008's Avatar
Quoted: 121 Post(s)
Liked: 56
I do have to ask 1 question. Can anybody get the .VOLUME SET activity control to work? I've tried many times, but the activity doesn't change the volume in any way. When you choose .VOLUME SET, the bottom volume says "(null).(null)". I have deleted the above and inputed -50 and it shows (-50.0) when I''m done. Is this wrong? Is there something I'm missing?
Headless Petie
jbn008 is offline
post #372 of 2153 Old 03-29-2012, 09:25 PM
hgmobile's Avatar
Quoted: 16 Post(s)
On a Denon 1912 as well as a Pioneer 1021, I can get the command to work. To get the sound at 38.5, I enter -38.5 in the space for volume at the bottom of the command parameters page.
I think the commands may appear differently for different brands/models.
hgmobile is offline
post #373 of 2153 Old 04-01-2012, 05:49 AM
scarr2k's Avatar
I have a Sony BP (bdp-s580) which is under the roomie remote IP compatible DVD BP. It does say its not able to be turned on via IP.
I would really Iike to have this power on without having to manually do it. Just wondering if some other member have a work around. Thx.
scarr2k is offline
post #374 of 2153 Old 04-01-2012, 06:27 AM
hgmobile's Avatar
Quoted: 16 Post(s)
If you have an Itach unit nearby you could use it to either blast or use an emitter on the Sony to power the unit up. Just add the player a second time as an ir device controlled by the Itach. Then you could use the ir based power toggle as part of a macro command sequence and/or custom map it to the power button of the ip-based virtual Sony remote that you use.
hgmobile is offline
post #375 of 2153 Old 04-01-2012, 11:53 AM
scarr2k's Avatar
Wow. Awesome idea. Thanks, worked perfectly.
scarr2k is offline
post #376 of 2153 Old 04-01-2012, 03:14 PM
APlear's Avatar
Hi All. Ive read most of this thread and decided to try roomie on the ipad for myself. Wow! What an awesome app. I got and Itach ir wired adapter and bought a new Denon avr-2112ci reciever to replace my old Yamaha reciever. Also have a dish vip922, PS3, Xbox, New Apple TV, and Roku. Took me about 2 days to get everything working the way I want it too but really was pretty easy. The SAT guide on the Ipad is very cool and even have zone 2 (outside speakers) working perfectly. My question is, since roomic can show the Dish Sat programming guide on screen, is it possible to get the Internet radio, pandora ect info from the 2112ci on the ipad as well? If it can do this I will be one happy person. Mainly want this so when Im outside listening to Pandora, internet raido ect, I can see and choose channels without having to look at the tv inside. Any help would be appreciated.
APlear is offline
post #377 of 2153 Old 04-01-2012, 06:10 PM
Slitman's Avatar
Just downloaded Roomie Remote and ordered the Itach controllers. So far I've managed to set up a couple of devices. So far I love what I'm seeing. Although it is simple to set up, is there a manual or "how to" document anywhere ??
_____________
Its Only Money
Slitman is offline
post #378 of 2153 Old 04-02-2012, 03:03 PM
With the avr-2112ci, can't you just run Pandora on the iPad and airplay it to the AVR. Then you get the full Pandora UI.
post #379 of 2153 Old 04-02-2012, 03:07 PM
Biggest weakness. There are online video tutorials - but they are very basic.
They either need a good manual or a good Wiki.
I've been using it about a month and I'm hooked. I've figured out what I need by trial/error/google and received excellent email support on the two instances where I needed device mods. I set up my own device file for my Sony projector (I only needed on and off to work - I don't change the settings).
post #380 of 2153 Old 04-02-2012, 04:50 PM
APlear's Avatar
Well sure you can AirPlay but I would like to be able to choose channels within roomie app, and AirPlay won't help with the Denon Internet radio. Would love to find a way to add them in the roomie app so I don't have to go inside to view tv to look for a channel. Kind of like the dish guide shows up on the watch tv activity.
APlear is offline
post #381 of 2153 Old 04-03-2012, 06:32 AM
Trevorsplace's Avatar
The Pandora app on the iPad can not use AirPlay as far as I know, at least I don't see any airplay icon in the app.
Trevorsplace is offline
post #382 of 2153 Old 04-03-2012, 07:00 AM
hgmobile's Avatar
Quoted: 16 Post(s)
If you expose the running applications (dble tap home button or 4 finger swipe up), scroll to the very left most position and you will find the music controls and the airplay icon there.
Pandora is a bit odd that way.
hgmobile is offline
post #383 of 2153 Old 04-03-2012, 07:10 AM
Thanks I would never have thought of that... I never use the iPad to play music iPod style so never use the audio on controls..
post #384 of 2153 Old 04-03-2012, 11:36 AM
I don't think the Denon has the ability to report any of this info. (I'm using a bit older Denon 5308CI so this may have been fixed in newer models)
I actually just added small Bluetooth receivers Belkin BT receiver to each of my stereos. That allows me to run whatever music app I want (or even youtube music videos) on the ipad and listen on the stereo. Works great.
Airplay is even better if you have it on the receiver since you have the greater range of wifi and less compression.
post #385 of 2153 Old 04-03-2012, 03:07 PM
hgmobile's Avatar
Quoted: 16 Post(s)
It would be great if there was a way to integrate pandora and other music services into Roomie without having to page in/out.
To Aplear - If you want to control internet radio without going back to the house, why not download one of the internet radio apps and you could airplay stream from your iPad/iphone without using the Denon to control the station.
hgmobile is offline
post #386 of 2153 Old 04-04-2012, 09:13 AM
remoteshoppe's Avatar
I'm no Spielberg but I posted a YouTube clip of my iPad screen programming Roomie Remote with a basic home theater set-up of IP devices in less than 2 minutes
Jim
remoteshoppe is offline
post #387 of 2153 Old 04-04-2012, 05:43 PM
DGF
DGF's Avatar
Liked: 39
Very cool - and consistent with my own experiences with creating configs for existing IR/IP controlled devices. Thanks for taking the time to capture and post the clip.
Dave
DGF is offline
post #388 of 2153 Old 04-07-2012, 04:55 AM
rjruby's Avatar
Quoted: 26 Post(s)
Liked: 26
I am considering buying a refurbed iPad to use as a dedicated Roomie Remote on my home theater system (TV, amp, PS3, laser disc, VCR & satellite receiver)
Is 16GB memory size sufficient?
Bob
rjruby is offline
post #389 of 2153 Old 04-07-2012, 05:07 AM
Rew452's Avatar
Quoted: 113 Post(s)
Liked: 65
Bob
More than enough. Roomie is very small
Rew
Rew
Vizio P75-C1 | OPPO UDP-203 | Samsung UBD-K8500
Denon AVR-X4300H00 | Nvidia Shield Android TV | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS4 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 |Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is offline
post #390 of 2153 Old 04-07-2012, 05:12 AM
rjruby's Avatar
Quoted: 26 Post(s)
Liked: 26
Rew
Thanks for the prompt response.
rjruby is offline
Reply Remote Control Area
Yamaha Rx V2065 Receiver , Tivo , Pioneer Vsx 1021 K 7 1 Home Theater Receiver , Denon Avr 1912 Receiver
