Roomie Remote - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 42Likes
post #631 of 2052 Old 12-15-2012, 11:25 AM
fight4yu's Avatar
Liked: 43
Originally Posted by aztecf View Post
It's a BDP-93, can I turn it on without the itach serial?
Just in case, you can always turn on with IR.
fight4yu is offline
post #632 of 2052 Old 12-15-2012, 01:56 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Hey guys I just found Roomie this morning and started playing with it. A few quick questions:
My Integra 80.2 processor works with every command I give it, except power on. Does it support that with Roomie?
I cannot get RadioRa2 to operate with it. I give it the IP of my controller, but it tells me that 1) it wants a username and password for RadioRa, which I have never set up, and dont see where to, and 2) Once it has a Lutron device showing, clicking on that just brings me to a screen with a simple light on / light off, that doesnt work. How do I get it to see all my different Lutron dimmers, etc? Do I have to have the Lutron lighting IOS app as well for some reason? Right now my Lutron set up is very basic with 4 dimmers and a single keypad for the theater only. I set it up myself with the RadioRa essentials software.
hifiaudio2 is offline
post #633 of 2052 Old 12-15-2012, 02:03 PM
thrang's Avatar
Quoted: 1605 Post(s)
Liked: 1381
For the Imtegra, make sure Network Control is enabled in the network settings - the default port should be working since everything else seems to be.
thrang is online now
post #634 of 2052 Old 12-15-2012, 02:07 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
post #635 of 2052 Old 12-15-2012, 02:09 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Does anyone know if the Oppo BDP-93 should work if I have NOT updated the firmware (which I won't do because of ISO removal) ? Roomie finds it, but no controls work. Since I dont have the Oppo hooked to a tv currently I cant go into its menus and see if there is any "network control" settings there.
post #636 of 2052 Old 12-15-2012, 02:20 PM
Jano18's Avatar
As far as I know you don't need to update the firmware but I could be wrong. I would try it first without updating it. You need to select Oppo IP series in Roomie & you can not power it on via IP.
Jano18 is offline
post #637 of 2052 Old 12-15-2012, 02:26 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Well I powered it on manually but nothing works. Roomie found it and I installed it as a device and it says BDP-93 automatically and also "all models IP". But no controls work. Maybe that firmware is necessary.
post #638 of 2052 Old 12-15-2012, 02:31 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
I just downloaded the official Oppo IOS remote and it didnt find the player on the network at all, so given that Roomie finds it, there may just be some setting that isnt set right that is keeping it from working.
post #639 of 2052 Old 12-15-2012, 02:34 PM
adidino's Avatar
Quoted: 318 Post(s)
Liked: 245
I think the 93 is ir and rs232 only so you will need a separate controller. I do not believe the 93 supports IP control. The 103 and 105 do.
adidino is offline
post #640 of 2052 Old 12-15-2012, 02:36 PM
adidino's Avatar
Quoted: 318 Post(s)
Liked: 245
Didnt even know that existed. So the IOS app works for the 93 via IP?
adidino is offline
post #641 of 2052 Old 12-15-2012, 02:37 PM
Jano18's Avatar
It's possible that the latest firmware enables IP control. Oppo hasn't said much about it every time I've contacted them about IP control they just keep telling me they are working on the protocols and will post them to their website when they are finalized. Try adding the Oppo manually using the IP address & port 19999, then select IP models.
Jano18 is offline
post #642 of 2052 Old 12-15-2012, 02:37 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Yeah says it does...
Description
Control your OPPO Blu-ray Player from any iOS device!
This is the first version of the OPPO Remote app for OPPO Blu-ray Disc Players. It works with the OPPO BDP-93, BDP-95 and later player models. (BDP-83, BDP-80 and DVD players are not supported.) The controlling iOS device must be connected to the same network as the Blu-ray player. Requires that the latest firmware is installed on the Blu-ray player. To obtain the latest player firmware, please visit OPPO Digital's web site.
Known limitation:
- The player must be turned on and connected to the network before it can be controlled by this app. The app can turn off the player but once the player is off, it cannot be turned on from the app since the player is disconnected from the network when it is off.
https://itunes.apple.com/us/app/oppo-remote/id584701552
post #643 of 2052 Old 12-15-2012, 02:38 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Yeah no big deal if I just need to get the serial adapter to make it work. Much better than removing my ISO support!
post #644 of 2052 Old 12-15-2012, 02:39 PM
Jano18's Avatar
T
Yes, Oppo released the iOS app the day before Roomie released v1.7.
Jano18 is offline
post #645 of 2052 Old 12-15-2012, 02:46 PM
adidino's Avatar
Quoted: 318 Post(s)
Liked: 245
Gave that a try myself. Doesn't seem to work for IP. IR with controller works fine though. Is port 19999 also valid for the 103?
adidino is offline
post #646 of 2052 Old 12-15-2012, 02:48 PM
adidino's Avatar
Quoted: 318 Post(s)
Liked: 245
T
How did you find it in the store? Oppo website still says coming soon.
adidino is offline
post #647 of 2052 Old 12-15-2012, 02:57 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
There is also an Oppo "media control" app for android that allows navigating attached usb devices from a phone. But that app specifically does say firmware BDP9x-74-0908, not just "latest". So real IP control may very well require that. Too bad.
Control media playback on your OPPO Blu-ray player from your phone.
This is the first experimental version of the OPPO Media Control app for BDP-93/95 Blu-ray players. In addition to being used as a remote control, this app can navigate locally-attached and network-shared media files and control their playback.
Requires OPPO BDP-93 or BDP-95 Blu-ray Disc player with firmware version BDP9x-74-0908.
post #648 of 2052 Old 12-15-2012, 02:58 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
post #649 of 2052 Old 12-15-2012, 10:11 PM
Jano18's Avatar
Yes I have the 103 & am using port 19999, it will not auto discover my Oppo in Roomie.
Jano18 is offline
post #650 of 2052 Old 12-16-2012, 07:35 AM
aztecf's Avatar
Anyone know what the roomie command is for the onkyo nr-609 to turn on the zone 2 speakers?
aztecf is offline
post #651 of 2052 Old 12-16-2012, 08:10 AM
Jano18's Avatar
From what I figured out with my Pioneer SC-37 is that I had to create a new activity & select my AVR for Zone 2. Try this & report back.
Jano18 is offline
post #652 of 2052 Old 12-16-2012, 08:46 AM
adidino's Avatar
Quoted: 318 Post(s)
Liked: 245
I found it by clicking at the bottom of the BDP - 93 support page.
http://oppodigital.com/blu-ray-bdp-93/blu-ray-BDP-93-Support.aspx
I realized after taking a second look a that it's a an iphone/ipod app. I downloaded for ipad anyway but I hope the release an native ipad version at some point soon.
adidino is offline
post #653 of 2052 Old 12-16-2012, 09:38 AM
Jano18's Avatar
Were you able to get Roomie to work with your 93? I sold my 93 when I bought my 103 so I have not been able test it. Roomie is getting a 103 soon to test. I was the first to test & report back to them with info on using Roomie with the 103.
Jano18 is offline
post #654 of 2052 Old 12-16-2012, 10:29 AM
adidino's Avatar
Quoted: 318 Post(s)
Liked: 245
I didn't test it yet. I will later today but the auto-discovery did detect my 103 so suspect it should work.
adidino is offline
post #655 of 2052 Old 12-16-2012, 12:38 PM
aztecf's Avatar
I need to know what the command to add for the Onkyo to switch it to zone 2, its not obvious.
aztecf is offline
post #656 of 2052 Old 12-16-2012, 12:44 PM
aztecf's Avatar
My Oppo BDP-93 everything works IP execpt turning it on, need either the serial interface or ir to turn it on.
aztecf is offline
post #657 of 2052 Old 12-16-2012, 02:30 PM
Jano18's Avatar
Correct, only the 103 can be powered on via IP from standby.
Jano18 is offline
post #658 of 2052 Old 12-17-2012, 02:22 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Are you at the latest firmware or getting it to work with an older one?
post #659 of 2052 Old 12-17-2012, 05:35 PM
aztecf's Avatar
I'm running firmware version BDP9x-74-0908
aztecf is offline
post #660 of 2052 Old 12-17-2012, 06:53 PM
Jano18's Avatar
Version 1.7.1 was released today, which was supposed to fix some bugs. I was hoping it would fix Roomie not auto detecting my Oppo, but no such luck. No big deal, because it still works manually.
Jano18 is offline
Reply Remote Control Area
Yamaha Rx V2065 Receiver , Tivo , Pioneer Vsx 1021 K 7 1 Home Theater Receiver , Denon Avr 1912 Receiver
