Roomie Remote - Page 55 - AVS Forum | Home Theater Discussions And Reviews
 44Likes
post #1621 of 2072 Old 02-26-2015, 09:34 PM
Danonano's Avatar
Quoted: 43 Post(s)
I'm getting roomie configured for my father and haven't been able to get 'wake on lan' to work with a Macmini. I've typed in the MAC address and even set the mac to a manual IP but still no luck. What step am I missing? thanks,
Dan
Danonano is offline
post #1622 of 2072 Old 02-27-2015, 07:28 AM
bdizzle's Avatar
For those have a FireTV, can you launch specific apps using Roomie, similar to what you can do on the Roku?
bdizzle is offline
post #1623 of 2072 Old 02-27-2015, 04:10 PM
Hootowls's Avatar
Dan
The FAQ for wake on LAN components on the Roomie support page makes it seem like all you need is the MAC address.
http://www.roomieremote.com/support/
Does the 'wake for network access' option in system preferences/energy saver also need to be enabled on the Mini?
Hootowls is online now
post #1624 of 2072 Old 03-01-2015, 05:59 PM
Danonano's Avatar
Quoted: 43 Post(s)
Ya I tried entering the MAC address and selecting 'wake for network access' but it didn't help. I did find a work around by scheduling the Macmini to start up every morning with an automatic login, never go to sleep, and then shutdown in the late evening. You can set this up under energy saver and then schedules, and the automatic login under user options in 'users and group.'
I've got everything set up great, except that Roomie refuses to completely pair with the Dish Hopper. I can type in the pairing code, and the roomie buttons will then work, but the pairing doesn't complete as after a few minutes it will ask me a code again. (on the tv the pairing que window doesn't go away unless I hit cancel.) Ironically, the RoomieSolo does pair correctly with the Hopper.
Has anyone paired successfully with the Dish Hopper?
thanks,
Dan
Danonano is offline
post #1625 of 2072 Old 03-02-2015, 05:44 AM
tcoble33's Avatar
Quoted: 13 Post(s)
Has anyone here done much experimenting with controlling Philips Hue lights from within Roomie? I've managed to get some basic functionality running (intermittently, at least), but I've only scratched the surface. In the absence of thorough documentation for the app's Hue configuration, the learning curve is proving to be pretty steep.
I'm mostly trying to set up lighting controls within existing activities like Plex, TiVo, Roku, Blu-Ray, etc. Basic things like turning scenes on and off in conjunction with play/pause commands, turning equipment on/off, etc. What I've accomplished so far is little more than a kludge, so I'm hoping somebody has figured out a nice, elegant approach.
Help???
tcoble33 is offline
post #1626 of 2072 Old 03-02-2015, 08:03 AM
Danonano's Avatar
Quoted: 43 Post(s)
I think you may be able to set up a separate activity in the 'popup activity' or 'toggle mode' to suit your purposes. Both options are available towards the bottom of the edit activity page. I set up a toggle mode activity for my hue lights, so that when I select the activity it turns on the lights in the appropriate color and brightness, and when i deselect it they turn off. I did have to go in and put individual commands for each light, so there might be an easier way using the .group command. Strangely enough it seems to work better than the native hue app once it's all set up. Maybe that's because it sends each command individually.
You do have a good idea with timing lights with play buttons etc, so I may try that too.
This page has more info in regards to hue, temperature, brightness etc. http://www.developers.meethue.com/do.../core-concepts
Danonano is offline
post #1627 of 2072 Old 03-02-2015, 08:34 AM
tcoble33's Avatar
Quoted: 13 Post(s)
Interesting approach. I haven't played too much with popup activities or toggle modes, but I can see how that could be a good approach for setting 'baseline' lighting when I fire up an activity. So far I've just been assigning basic "scene on"/"scene off" commands to the same buttons that control play/pause, but I've had limited success with that. I'm sure I'll figure it out eventually...
Thanks for the feedback!
tcoble33 is offline
post #1628 of 2072 Old 03-12-2015, 07:27 PM
chadcj7's Avatar
Quoted: 58 Post(s)
has anyone used the roomie agent 2.1 on the mac?
If so what is your experience with it? Also how many mac's can you put it on? Thanks
chadcj7 is offline
post #1629 of 2072 Old 03-13-2015, 08:36 AM
hgmobile's Avatar
i am only using it as a system time clock - to trigger events etc. I don't use any of the more advanced features so can't comment on those. As a time clock it works well.
I spoke with customer support and you can use Agent on as many macs as you like. It is tied to your email address - not the machine.
hgmobile is offline
post #1630 of 2072 Old 03-13-2015, 08:55 AM
chadcj7's Avatar
Quoted: 58 Post(s)
Thanks for the information. How are you using it exactly to trigger events?
chadcj7 is offline
post #1631 of 2072 Old 03-13-2015, 09:00 AM
hgmobile's Avatar
checkout the Roomie Supplied documentation on the latest release.
triggers are discussed starting at page 5.
http://www.roomieremote.com/wp-conte...w-Features.pdf
hgmobile is offline
post #1632 of 2072 Old 03-23-2015, 10:07 PM
Danonano's Avatar
Quoted: 43 Post(s)
I'm running a macmini with agent and using 2 ipads to control roomie. It works well now that I have things configured. I set the mini to start up every morning, shut down every night, and to not go to sleep while its on. That way I ensure that agent is working during the day. I'm not sure how many macs you can put on it.
Danonano is offline
post #1633 of 2072 Old 04-01-2015, 11:48 AM
JustBusiness's Avatar
Quoted: 43 Post(s)
I'm moving in to a new house, and my roomie set up is going to get a lot more confusing. I'd like to buy a 32", 40", and 55" IP controllable TV for a few places with occasional viewing (kitchen, master bath, and outdoor patio). It looks like Sharp is the best bet, but I'm not familiar enough with their naming syntax to know what is compatible. Can anyone suggest 2013/2014/2015 models for me to look for that are completely IP controllable by Roomie?
Any help is greatly appreciated.
Best regards,
Justin
JustBusiness is offline
post #1634 of 2072 Old 04-01-2015, 12:06 PM
mdavej's Avatar
Quoted: 2161 Post(s)
Liked: 950
Best regards,
Justin
Here's the list:
http://www.roomieremote.com/device-compatibility/
Beyond that, you'll have to ask Roomie. Sharp support likely won't have any idea.
mdavej is online now
post #1635 of 2072 Old 04-01-2015, 12:09 PM
thrang's Avatar
Quoted: 1688 Post(s)
Liked: 1427
Originally Posted by mdavej View Post
Here's the list:
Also note that many sets do not support power via ip - Seems most if not all Sharps listed do, as do later model Sony's
thrang is offline
post #1636 of 2072 Old 04-01-2015, 12:12 PM
tcoble33's Avatar
Quoted: 13 Post(s)
I'm using the Roomie Agent on two Mac Minis and syncing with an iPad Mini and an iPhone 5s. Not exactly a large, high-demand implementation, but it's been rock solid and has yet to miss a beat.
tcoble33 is offline
post #1637 of 2072 Old 04-01-2015, 12:30 PM
Quoted: 43 Post(s)
I'm not seeing any 32" TVs that are completely IP controllable, except the Sony KDL-32W650A, which is not available for sale anywhere. I guess I'll just go IR Control for now.
Anyone else see a 32" with IP control?
post #1638 of 2072 Old 04-01-2015, 12:42 PM
mdavej's Avatar
Liked: 950
Check iRule's compatibility list as well.
post #1639 of 2072 Old 04-02-2015, 07:57 AM
Quoted: 43 Post(s)
Ok, going to just control those displays via IR.
Does the roomie RS-232 Adapter allow for feedback, or just one way communication? http://www.roomieremote.com/store/bl...es/serial.html
For feedback, do I need to go with an iTach IP2SL?
post #1640 of 2072 Old 04-02-2015, 08:28 AM
HockeyoAJB's Avatar
Quoted: 975 Post(s)
Liked: 809
It should allow for feedback over serial. However, what types of feedback you can get over serial (or IP for that matter) depend on the equipment.
HockeyoAJB is online now
post #1641 of 2072 Old 04-03-2015, 04:47 AM
tommyboy1970's Avatar
Chromebox
Hey guys
Just got a chromebox setup running plex with Openelec and read many times that people were using roomie to control it( although it was Kodi indstead of plex)
Has anyone got it working with Plex, it won't auto discover it.
I am very new to roomie so i am pretty clueless
thanks
tommyboy1970 is offline
post #1642 of 2072 Old 04-04-2015, 03:42 PM
cyphers72's Avatar
Quoted: 13 Post(s)
This new 32 looks like it has a pretty good chance it will have IP control:
http://www.sharpusa.com/ForHome/Home...C32LE653U.aspx
But we don't list it yet as it's not quite available and untested. There are more options in the 39-43 range. That Sony model is/was wonderful if you can find it.
cyphers72 is offline
post #1643 of 2072 Old 04-06-2015, 11:21 AM
Quoted: 43 Post(s)
IP Control is listed as a " - " on the tech specs, but you think there may be compatibility still?
I need it to be 32" for the space under the counter.
post #1644 of 2072 Old 04-14-2015, 10:30 PM
nowknown's Avatar
Quoted: 183 Post(s)
Liked: 152
So, I see the newly released Roomie update has Roomie for Apple Watch - very interesting...
nowknown is offline
post #1645 of 2072 Old 04-24-2015, 11:25 AM
dlambermont's Avatar
Multi Zone Volume Control?
Just getting started with Roomie, and I really like it so far. One final thing to figure out, and I'll be all set...
I've got a theater/bar room driven by a 2 zone Yamaha receiver. I have a projector and 5.1 speakers in the theater (zone 1) and a TV and stereo speakers behind the bar (zone 2). Right now, I have created activities for "Watch TV Theater" or "Watch TV Bar" and they work great. The one I'm having trouble with is a "Watch TV Both". Everything works, except I can't figure out how to have separate volume controls for the two zones (they would be running in Party Mode). I have the main volume set to zone 1, and I can't figure out how to add another volume control for zone 2. I've tried adding a slider, select the zone 2 receiver as the device, but then I only have the option of defining feedback. Feedback from the zone 2 volume allows me to move the volume around, but when I release the slider the volume just stays where it was.
Maybe I just don't know what kind of button to add, but I'm not seeing anything. Ideally, I'd like a volume control and a mute button for zone 2.
dlambermont is offline
post #1646 of 2072 Old 04-24-2015, 11:43 AM
HockeyoAJB's Avatar
Quoted: 975 Post(s)
Liked: 809
Does the second receiver support IP control or are you using IR control for it? Is whatever method you are using to control that receiver actually working when you use the default remote for that specific device? If everything works correctly for that device when using an activity that brings up its default remote then the problem is likely in the creation of the custom volume slider that you are trying to add to the remote used by another activity.
I'm not terribly familiar with the process of creating custom remotes, but one thing that jumped out at me was that you were trying to use a slider to control volume when the default volume controls are separate volume up and volume down buttons. Are you certain that the slider is set to control volume and not a scrubber bar for controlling position within a track (which wouldn't do anything if the receiver is playing audio from an external source)?
post #1647 of 2072 Old 04-24-2015, 12:23 PM
Turns out I'm a moron... I had copied the "Watch TV Theater" activity, and inadvertently left the command to power off zone 2 in. So, the slider didn't work because the zone was OFF. Duh. Fixed that up, and all is well now.
Really liking this thing. I had previously programmed all of this stuff into a Harmony One remote, but certain things were not possible (or wife friendly). All of my devices are IP controllable, with the exception of the TV and Projector, which I'll turn on or off manually.
post #1648 of 2072 Old 04-26-2015, 07:12 AM
erichoya's Avatar
Consider adding the gc itach flex or the roomie version to control your ir devices. Wired is the way to go vs wifi if you can get a network cable to the area. I ran a stereo cable to extend the ir emitter to the projector although the ir blaster does work well.
erichoya is offline
post #1649 of 2072 Old 04-26-2015, 12:28 PM
rramacha's Avatar
Quoted: 120 Post(s)
Liked: 33
Switching Activities
Hello All
I am experimenting with Roomie Remote in my Bedroom AV Set up before moving to my main media room.
My Bedroom set up has the following:
Samsung TV
Sonos Play Bar
Dish Joey Receiver
Apple TV
Oppo HM-31 Switcher
Samsung Blu Ray Player.
I have three activities created:
Watch Dish
Watch Apple TV
Watch Blu Ray
I can individually start and use each activity and at the end shut down after watching either one of the three activities.
My only issue is when watching tv, if i decide to watch apple tv and hit watch apple tv button, then everything turns on correctly except apple tv. Basically while watching one activity if i shut down and start another activity all works well. If I try to switch with out shutting down, my tv is powered off. How can I avoid this?
Cheers
Raj
rramacha is offline
post #1650 of 2072 Old 04-26-2015, 06:48 PM
Thxtheater's Avatar
Quoted: 146 Post(s)
Liked: 111
Raj if the issue is your TV powering down then try using the discreet power on and power off commands as opposed to power toggle. Most TVs have a separate command for situations just like yours.
In my very complex multi room setup I manage all my TVs with discrete power on then only have the TV power off with the final system power down. Never use TV toggle as it can mess up things.
This is how I understood your question but I'm not sure if this is exactly what you were asking about.
Thxtheater is online now
Reply Remote Control Area
Yamaha Rx V2065 Receiver , Tivo , Pioneer Vsx 1021 K 7 1 Home Theater Receiver , Denon Avr 1912 Receiver
