Roomie Remote - Page 57 - AVS | Home Theater Discussions And Reviews
post #1681 of 1692 Old 05-14-2015, 01:20 PM
mdavej's Avatar
Quoted: 1207 Post(s)
Liked: 625
Originally Posted by rramacha View Post
I have been a long term Harmony user and switched over to iRule recently...
Thanks for sharing. But what does this have to do with Roomie?
mdavej is offline
post #1682 of 1692 Old 05-14-2015, 01:52 PM
Wdawg1000's Avatar
Quoted: 14 Post(s)
Bugs I have:
  1. 1. Oppo 105D Power on does not work. I am using IP Control and may have to go RS232 route and check.
Hello rramacha
I have a 103D and have been wondering about this also. Mine will only show up on my network after I manually/IR power on my unit. After that it will power on and off with IP control. I've wondered if it is a bug or design of the 103D?
Bob
Wdawg1000 is offline
post #1683 of 1692 Old 05-14-2015, 02:27 PM
rramacha's Avatar
Quoted: 56 Post(s)
Sorry I meant Roomie Remote
rramacha is offline
post #1684 of 1692 Old 05-14-2015, 02:29 PM
rramacha's Avatar
Quoted: 56 Post(s)
Originally Posted by Wdawg1000 View Post
Hello rramacha
Bob
Power Toggle works over ip. So I turn on using that. I would like discreet power to work.
Cheers
rramacha is offline
post #1685 of 1692 Old 05-15-2015, 07:49 AM
rramacha's Avatar
Quoted: 56 Post(s)
Hello All
Bugs I have:
  2. 2. When using Oppo 105D optical in as source from my bluesound, cannot automate command Source 6 to happen when starting up the activity. I need to do this after activity starts.
Cheers
Raj
I was able to resolve Issue #2 by setting delays. I set delay after power toggle to 20 seconds. I then sent Source Command. I then set delay to 2 seconds and sent command 6. It now worked. Now my oppo goes to optical in.
Cheers
Raj
rramacha is offline
post #1686 of 1692 Old 05-16-2015, 06:35 PM
Wdawg1000's Avatar
Quoted: 14 Post(s)
I'm sorry I can only confirm what you already know. On my 103D the Power on Button does nothing. The Power Off Button toggles the power. The Toggle Power button functions normally.
Bob
post #1687 of 1692 Old 05-17-2015, 07:54 AM
rramacha's Avatar
Quoted: 56 Post(s)
Hello All
I have been a long term Harmony user and switched over to Roomie recently. My experience so far has been good. I currently have only few bugs to iron out.
Features I love:
  1. 1. Two way feed back to show volume level and Surround Mode.
  2. 2. Large screen real estate, where I can have buttons dedicated to different Audyysey Modes.
  3. 3. While watching DVR content ability to use slider to go anywhere, rather that use forward or fast forward button.
  4. 4. Ability to type on search field using regular key board.
Bugs I have:
Things to explore:
  1. 1.Pop Up Activty and
  2. 2. Toggle Activity.
I have no idea what they do.
Cheers
Raj
Bob
Bob
Today If time permits, I will try and set up Oppo to control via RS232 and see if that works. If it is, then some thing else is the issue. I also noticed following two important buttons missing on remote rendered by Roomie.
It lacks button for Pure Audio and Darbee On/Off
rramacha is offline
post #1688 of 1692 Old 05-17-2015, 07:40 PM
rramacha's Avatar
Quoted: 56 Post(s)
I am facing annoyance with roomie remote while watching Dish TV. I keep getting request to enter Pairing Code appearing on screen on my iPad. Once I do I can click settings on dish hopper and save it. Unfortunately this repeats every half hour to an hour. Do any one know of this issue.
Cheers
Raj
rramacha is offline
post #1689 of 1692 Old 05-18-2015, 06:47 AM
Wdawg1000's Avatar
Quoted: 14 Post(s)
Hello Raj
I had that problem and turning off Blue Tooth in the Dish receiver Settings cured it.
By the way I sent an email to RoomieSupport about support for discrete power on/off codes on the 103D. I'll let you know if I get a response.
Bob
post #1690 of 1692 Old 05-18-2015, 08:05 AM
rramacha's Avatar
Quoted: 56 Post(s)
Thanks Bob. I will try that. I will mostly do RS232 set up for Oppo in a day or two. I will keep you posted how rock solid that is.
Cheers
Raj
rramacha is offline
post #1691 of 1692 Old 05-18-2015, 11:39 AM
rramacha's Avatar
Quoted: 56 Post(s)
Hello Raj
Bob
Bob
I did not try turning off bluetooth yet, but tried controlling Oppo using RS232. It is rock solid. Everything works and also I can see all commands like Pure Audio/ Darbee etc. Discreet ON/OFF works as well. Looking at how rock solid it is, I may switch even my Marantz AV 8802 and Epson Projector to RS232.
Cheers
rramacha is offline
post #1692 of 1692 Old Today, 03:36 PM
Liked: 0
reverse engineering...
Originally Posted by Chris Carter View Post
I don't normally answer my own questions, but I figured a couple of things out and thought they might be helpful to others, so I'll share just in case.
The Amazon command may not have been implemented in my TV. I have no way to check this. According to support, "Only a full reverse engineering of the network commands to your model from that app would be able to answer that." I have no idea how to do that, but I built a workaround using key presses sent to the Sony TV to launch the menu system, and the Amazon app.
I figured this out by sending a combination of "HOME" and "RETURN" commands to the Sony TV. Stops a video from playing, and exits whatever app is running.
Yes, sometimes, a simple reverse engineering (network sniff) is needed to resolve your problem, if no spec found on web.
Your software support should give you some tips to do that.
We, at newmote kickstarter project, will do that for our customers, so i think roomie will help you so
regards,
ari.
nono6792 is online now
Reply Remote Control Area
Yamaha Rx V2065 Receiver , Tivo , Pioneer Vsx 1021 K 7 1 Home Theater Receiver , Denon Avr 1912 Receiver
Gear in this thread - V2065 by PriceGrabber.com
