Roomie Remote - Page 59 - AVS Forum | Home Theater Discussions And Reviews
post #1741 of 1748 Old 07-28-2015, 12:23 PM
ChrisMc73's Avatar
Quoted: 153 Post(s)
Originally Posted by Sodbuster View Post
Roomie tracks the power status of each device. Hence I set up every activity as if it were to begin from a cold start. Say I'm watching TV using the cable box and I want to select my Apple TV device: just initiate the Apple TV request, and the selections for the cable box will be 'overwritten'. Note that the cable box will remain powered on, but that doesn't bother me. When I am done with the system, I select System Off into which I have programmed all the power off commands for every device. I usually have every control sequence 'confirmed' before execution. Roomie has made itself invaluable, and I know I'm not beginning to use all its features.
Bill
Thats how I'm starting to feel as I understand it more and more. So you leave all your components on as you use the system so when you switch from STB (TV) to AppleTV the STB stays up, thats not a bad idea, I guess I'm more anal and like having them or at least watching them go off, as I move away from one. So does the red power button automatically turn off all devices or can you edit it and program it to shut all off? The only one I couldn't get to turn off was the AppleTV, there is no command to send it to sleep or at least not one I'm aware of, know how I can do that?
ChrisMc73 is offline
post #1742 of 1748 Old 07-28-2015, 02:11 PM
Sodbuster's Avatar
When I looked at the commands issued by the System Off button, it looks like I programmed it to turn off every device one after the other. It's been a long time, and I don't remember what the default settings there looked like. I agree that what happens with the Apple TV is a mystery since there is no discrete on/off function. My assumption is that it wakes up when addressed and hibernates when ignored, but that's just a guess. It is the newest device in my system...been there for about a year. I also have a Roku player. These are the only items which are controlled directly via my wifi network...everything else needs an IR signal as provided by an iTach device. Most of my gear is much too old to have an IP address!
Bill Bunker
Sodbuster is offline
post #1743 of 1748 Old 07-29-2015, 07:49 AM
ChrisMc73's Avatar
Quoted: 153 Post(s)
So you can program the System Off button, guess I just haven't clicked it and looked at what its doing. Good to know.
post #1744 of 1748 Old 07-29-2015, 10:11 AM
Sodbuster's Avatar
Sorry, my experience goes back years and Roomie has evolved in the meantime. I just don't know how you should add more emitters, but it is surely possible. The iTach wifi2ir gizmo I use also has three ports. Before I ever started with Roomie, I needed multiple IR emitters, so I bought a device that takes an IR input, amplifies it, then outputs multiple copies on multiple ports (xantech gizmo). I don't lack for emitters!
Bill Bunker
post #1745 of 1748 Old 08-21-2015, 09:50 AM
hgmobile's Avatar
Help with VPN
I have set up a VPN connection in accordance with the roomieremote FAQ. I have no issue logging in etc but I am having issues getting roomie to fully function via VPN.
I can execute commands that go thru itach units that are relayed thru ir ports. e.g.: turn on TV sets or control cable boxes.
I cannot control ( or even power up) ip controlled devices like receivers from Denon or Pioneer, nor can I control Lutron Caseta.
I have forwarded the default ports that are mentioned in the Roomie ip compatibility charts as well as the required Ivpn ports for pptp connection.
Any help greatly appreciated.
hgmobile is offline
post #1746 of 1748 Unread Today, 11:08 AM
rramacha's Avatar
Quoted: 61 Post(s)
Hello All
I have been using Roomie Remote for a while and extremely happy with its performance. I am trying to add more complexity and also utilize my Marantz AV8802 streaming feature.
I have an activity set up to play music from my WDCloud Storage Device, but unable to navigate files from inside Roomie Remote. I have to leave Roomie Remote App and go to Marantz Remote App and select media files to play. Is there any way to do this natively like for example able to do with Kaleidescape Alto.
Cheers
Raj
rramacha is online now
post #1747 of 1748 Unread Today, 11:15 AM
wkearney99's Avatar
Quoted: 194 Post(s)
Liked: 86
I'd imagine it would require the device expose a programming interface for doing that. Then it would require the controlling program (roomie, in this case) have specific support for that. I don't know that the Marantz gear supports doing this kind of thing. Obviously a device can, if their own app has the ability. But it would then depend on a 3rd party app putting forth the effort to do the same thing.
wkearney99 is online now
post #1748 of 1748 Unread Today, 11:19 AM
rramacha's Avatar
Quoted: 61 Post(s)
Thank You. I want to see if Roomie supports this functionality or is there a place to ask them to explore supporting this.
Cheers
Raj
Reply Remote Control Area
Yamaha Rx V2065 Receiver , Tivo , Pioneer Vsx 1021 K 7 1 Home Theater Receiver , Denon Avr 1912 Receiver
Gear in this thread - V2065 by PriceGrabber.com
