Roomie Remote - Page 64 - AVS Forum | Home Theater Discussions And Reviews
 44Likes
post #1891 of 2071 Old 12-12-2015, 06:45 AM
lflorack's Avatar
Quoted: 70 Post(s)
Liked: 59
Originally Posted by ChadA View Post
I don't have an Oppo but I had a similar problem with my Sony BDP. I was using the PowerOn command but I should have been using the "Wake On Lan" command in my power-on macro. When I switched to "Wake On LAN", it worked like a champ. Maybe something to try?
IIRC, I had to set Roomie Remote (Simple Control) to power up my Oppo 93 using IR and then everything else could be done via IP - because the Oppo 93 can't power up via IP.
Link: System Pix
Klipsch: (2) RF-83, (1) RC-64, (2) RVX-54, (2) RSX-5, SVS: (1) SB13-Ultra
Yamaha: Aventage RX-A2010, CDC-685, Oppo: BDP-93, JVC: Procision DLA-X550R
DragonFly: 16:9 133" High Contrast Screen, Apple: AppleTV, Roku: Roku4
Amazon: FireTV Stick, SimpleControl: IP Remote, Logitech: Harmony One
ACP: J15BLK 1.5 kVA Power Conditioner/UPS
lflorack is offline
post #1892 of 2071 Old 12-12-2015, 09:59 AM
bmock17's Avatar
Quoted: 118 Post(s)
Thanks for the suggestion. I just tried it but that didn't work. This is getting pretty frustrating.
bmock17 is offline
post #1893 of 2071 Old 12-12-2015, 12:15 PM
thrang's Avatar
Quoted: 1617 Post(s)
Liked: 1388
If you're looking to turn the new Oppo on via IP, ain't gonna happen. For some odd reason, their IP control protocol, or the HW design itself, doesn't feature power on via ip.
Has to be IR, or serial control.
lflorack likes this.
thrang is offline
post #1894 of 2071 Old 12-12-2015, 12:48 PM
HockeyoAJB's Avatar
Quoted: 974 Post(s)
Liked: 808
Can it be woken up via. HDMI CEC if you power on the device connected to its HDMI input? I know some people use this as a means to power on their TV/AVR when the TV/AVR doesn't support Wake on LAN or power on via. IP.
HockeyoAJB is online now
post #1895 of 2071 Old 12-12-2015, 03:07 PM
bmock17's Avatar
Quoted: 118 Post(s)
I bought the wifi blaster to use for my cable box. Do you think if I use one of the ir emitters and put it over the ir in input on the back of the oppo that would work to control it via ir?
bmock17 is offline
post #1896 of 2071 Old 12-14-2015, 02:01 PM
bmock17's Avatar
Quoted: 118 Post(s)
Currently my setup consists of my projector, oppo 103d blu ray player, and receiver. When i watch tv i have the cable go through the oppo to use the darbee processor. I cannot seem to figure out how to program a command into the "watch tv" activity to have the oppo switch to the proper output. I have tried adding an activity through the oppo but all i can find is input scroll, nothing to actually change the input to "hdmi back", like it needs to be. Anyone have any experience with this?
bmock17 is offline
post #1897 of 2071 Old 12-16-2015, 09:24 AM
TeeBo's Avatar
I have just been informed by simple control support that OTA program listings fail to provide extended show info due to an issue with the listing provider not supporting the decimal point in the channel number. Is this a known issue in the community and are there any work-arounds short of getting a cable or satellite subscription?
Thanks, Tim
TeeBo is offline
post #1898 of 2071 Old 12-16-2015, 02:15 PM
ChadA's Avatar
Quoted: 83 Post(s)
Liked: 88
New Apple TV now sypported!
Finally, Apple added IP support to its Remote app for the new Apple TV 4. That allowed Simple Control to add support, which they did fairly quickly.
ChadA is offline
post #1899 of 2071 Old 12-16-2015, 09:58 PM
Murilo's Avatar
Quoted: 131 Post(s)
Liked: 31
Can anyone using a newer denon with ip control can you tell me does roomie/simple provide a "play pad" play pause ect... on the default remote. For listening to pandora, spotify, ect... i use it all the time on my yamaha, but before i purchased a denon i tried to just setup a fake denon device and it didnt look like roomie provided a play pad.
Murilo is offline
post #1900 of 2071 Old 12-18-2015, 11:30 AM
dgeffs's Avatar
Simple Control with Apple Watch
Seems like a few people are having good success controlling SC with the watch. In my case I have a fairly large Insteon environment with a ton of feedback. SC has tried everything they can think of to assist - their support has been pretty good. My question is for those who have this working is your installation large and are you using the ISY 994i as the hub? Or are you just controlling AV equipment and no lighting?
dgeffs is offline
post #1901 of 2071 Old 12-18-2015, 12:26 PM
ChadA's Avatar
Quoted: 83 Post(s)
Liked: 88
What problem are you having?
ChadA is offline
post #1902 of 2071 Old 12-28-2015, 12:16 PM
dgeffs's Avatar
Very little control, very slow and absolutely no feedback from the ISY hub on Insteon devices. A typical session might allow me to actually turn on my system but that is as far as I can get. I can't control anything past that and can't turn the system off even though it was turned on from the watch. I've tried all the suggestions about resintalling, restarting the watch etc. and always end up with the same issues.
dgeffs is offline
post #1903 of 2071 Old 01-03-2016, 07:36 PM
Quoted: 40 Post(s)
Liked: 6
Have you tried going into the activity and change the power on commands to include switching the input? You can setup multiple commands for when you enter and exit an activity.
IE Watch TV.
Power On if necessary
Switch to Cable on Marantz
Power off lights
Coreyavs is offline
post #1904 of 2071 Old 01-03-2016, 07:39 PM
Quoted: 40 Post(s)
Liked: 6
You may need to slow down the commands.
FWIW you have to have the watch near the iPhone anyways why not just use the iphone
Coreyavs is offline
post #1905 of 2071 Old 01-03-2016, 08:12 PM
bmock17's Avatar
Quoted: 118 Post(s)
IE Watch TV.
Power off lights
Yeah, I have tried. I added the oppo remote to the app so when I "watch tv", I then go into the oppo remote and press the input scroll button and select the right one. I cannot figure out any other way to do it.
bmock17 is offline
post #1906 of 2071 Old 01-04-2016, 12:11 AM
Murilo's Avatar
Quoted: 131 Post(s)
Liked: 31
Wow the hub is expensive, in canada that is 375 dollars, the price of a harmony elite system.
I was on the fence switching over to harmony and still am but the price of that hub for what it does is quite expensive. I am a windows user unfortunately so the hub was my only option but wow thats a big chunk of change for what it does.
Murilo is offline
post #1907 of 2071 Old 01-04-2016, 02:27 AM
peptalk1's Avatar
Liked: 1
Just buy an Android tablet or phone and Symple Sync.
peptalk1 is offline
post #1908 of 2071 Old 01-04-2016, 11:26 AM
dgeffs's Avatar
IE Watch TV.
Power off lights
Yes, I don't use any of the automatic commands so every button normally has many commands associated with it and I increase the delay as needed.
I think the watch is too slow and my Roomie configuration too complex to ever work well together. Perhaps the Watch 2.0 will fix the speed issue. For now Mobilinc works amazingly well for the Insteon lights since that is all it's doing.
I normally don't use the phone for Roomie control anyway. I have dedicated iPads for that. I just thought it would be nice to be able to control some of the AV stuff with the watch like volume and the lighting. I'll wait for the next releases and try again.
dgeffs is offline
post #1909 of 2071 Old 01-10-2016, 12:46 PM
bmock17's Avatar
Quoted: 118 Post(s)
Is it possible to add scenes from the Phillips hue tap to simple control? I added the hue hub to simple control and am able to control the lights with the sliders but I want to add actual scenes. Is it possible?
bmock17 is offline
post #1910 of 2071 Old 01-12-2016, 05:01 PM
peptalk1's Avatar
Liked: 1
Yes, you can create (for example) a button in the remote which activates a scene.
peptalk1 is offline
post #1911 of 2071 Old 01-15-2016, 03:20 PM
Applemike68's Avatar
Quoted: 123 Post(s)
Is anyone using simple and a JVC RS500/600 projector ? Simple found my projector but when I add it to an activity nothing happens, will not turn off or on.
Thank you
Applemike68 is online now
post #1912 of 2071 Old 01-15-2016, 05:36 PM
Quoted: 123 Post(s)
Thank you
post #1913 of 2071 Old 01-26-2016, 11:34 AM
kingwiggi's Avatar
Quoted: 236 Post(s)
Liked: 124
I'm trying to assign a simplecontrol trigger to an unused button on a Insteon 4 scene switch (mini-remote) the trigger will run an activity that turns on the projector/avr/oppo in my HT room.
The only trigger status I have on SimpleControl is 'Brightness' so whilst it works if I assign the trigger to one of the buttons that turn the lights on, I cant get it to function with an empty button.
Does anyone know how I might go about getting this to work (tricks or workarounds).
My insteon devices are controlled by an ISY99 controller, I have a mac-mini running the trigger agent
Denon AVR-X7200WA (preamp mode) + DUAL DDRC-88A's, 9.2.4, Emotiva XPA-5 G2*2, UPA-700,
Onkyo DAC-1000s, Onkyo DP-X1 DAP, Darbee DVP5000, Xbox One, 8TB Tivo Roamio Pro
JVC RS600 + ISCO IIIL, 158" 2.40:1 DIY AT screen, Calman 5 Enthusiast, i1 Pro 2, i1 Display Pro, Spyder 5, eeColor 3D LUT Box
Oppo UDP-203, Oppo BDP-105, Samsung UBD-K8500,
Mac Mni 2012 + JRiver MC 20, QNAP TVS-871 NAS
kingwiggi is offline
post #1914 of 2071 Old 01-29-2016, 04:14 PM
sjackson's Avatar
Quoted: 91 Post(s)
Liked: 37
Anyone any difficulty adding commands to the IR?
I have an IP2IR and SC app found it very quickly but it can't seem to pick up commands for my TV. The TV is only 2 or 3 years old (Sony 46HX853) so I would expect the commands to be easily found. When I set SC to learn the commands it just does not learn the power toggle for example. I'm pointing the remote at the rear of the IP2IR and pressing the power button. In the background the TV is switching on and off but the iTach is not detecting a thing.
Note - it's learning some commands like the numbers 0-9 but not the power. Also if I test the soft remote and press a digit it will send but I can't send another command directly after it. Wait 30 seconds maybe and it will work.
Any ideas?
__________________________________________
DIY Sound Group 893 & Volt 8's Build Thread
sjackson is offline
post #1915 of 2071 Old 01-29-2016, 07:34 PM
Scott Greczkowski's Avatar
Quoted: 58 Post(s)
Liked: 101
I purchased the app, however it is not controling either of my TV's when the TV's are listed on the compatibility list.
Both TV's are Samsungs - One is a 55HU8550 and the other one is a 55JS7000
On both if I try adding them to the app they are found on my network, if I select the TV it asks me for the access number on the screen I enter it in and the code goes away on the TV screen, however I can not control the TVs.
Any ideas?
Scott
SatelliteGuys.US / MultiChannel News
Scott Greczkowski is offline
post #1916 of 2071 Old 01-30-2016, 09:10 AM
ChadA's Avatar
Quoted: 83 Post(s)
Liked: 88
Any ideas?
Have you tried the Sony TV commands from the Simple Control library? I just added a Samsung TV via IP2IR and was able to use the built in command library for all Samsung TVs.
ChadA is offline
post #1917 of 2071 Old 01-30-2016, 04:22 PM
hgmobile's Avatar
Any ideas?
you may need to play with the infrared retransmit counts. Some TV's require a setting of 2 or 3
see paragraph 5 at https://www.simplecontrol.com/knowle...i-diagnose-it/
hgmobile is offline
post #1918 of 2071 Old 02-02-2016, 11:35 PM
nowknown's Avatar
Quoted: 183 Post(s)
Liked: 152
So can you just grab a cheap Fire tablet off Amazon and SS and you're good to go?
nowknown is offline
post #1919 of 2071 Old 02-03-2016, 11:57 AM
peptalk1's Avatar
Liked: 1
As far as I can understand from their website: Yes if you also buy their sync app.
nowknown likes this.
peptalk1 is offline
post #1920 of 2071 Old 02-12-2016, 01:45 PM
nowknown's Avatar
Quoted: 183 Post(s)
Liked: 152
So, I got a cheap Proscan ('Lolipop' OS) tablet (going from an ipad to this is like jumping out of a Lexus and landing on a skateboard) downloaded Simple Sync onto it AND bought a $50 SS license (you have to do both.) 'Not a happy camper. After a lot of buying/passwords/syncing/resettings/emails to support and talking more to this b' Alexa than I do to my wife , I only get a crapload of either "you must have a Simple acount" or "I can't find an activity called TV in your profile". By the time I get this s' to work we will all be watching hover TVs (and they will probably not be in my 'profile' either!)
nowknown is offline
Reply Remote Control Area
Yamaha Rx V2065 Receiver , Tivo , Pioneer Vsx 1021 K 7 1 Home Theater Receiver , Denon Avr 1912 Receiver
