Weird problem with Harmony Adapter for PS3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-17-2011, 08:31 AM - Thread Starter
siglr's Avatar
Hello
I've had the Logitech Harmony Adapter for Playstation 3 for more than a year now and it always worked without a hitch.
However, now the unit continuously shuts itself down. The green light indicator, which is always supposed to be on, is now off. I unplug the device power, wait for a few minutes, then replug it. The adapter then works for around 15-30 minutes and then shuts down again. I repeat the process all the time, with the same results.
Anybody experiencing a similar issue with the adapter? What's wrong?
Guy
SETUP: Sony VPL-HW40ES at 12'6" from 100" GrandView fixed white 1.0 Gain screen - Central home theater receiver Denon 4311ci - Playstation 4 - Apple TV - Bell Fibe TV PVR - Dedicated Home Theater fully light controlled.
siglr is offline
post #2 of 2 Old 04-15-2012, 03:22 PM
ejm1017's Avatar
My PS3 adapter just started having the same problem - same symptoms. I saw
your posting from last Fall, and was wondering if you ever found a remedy ?
Ed
ejm1017 is offline
Reply Remote Control Area
