Demopad for Ipad & Iphone - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 466 Old 01-05-2013, 01:54 PM
DKAudio's Avatar
I've been messing with Demopad for a few hours, plan to put it on my 32gb iPad Mini. Creating the screens and graphics is coming easy to me. I also understand the IR codes (for the most part). I have the following equipment:
Emotiva UMC-1 processor (fortunataly Emo publishes remote codes so I think I'm ok on these)
PS3 using a Nyko BluWave USB IR dongle (no idea how to get IR codes)
LG TV 50PA5500 (no idea how to get IR codes)
Dish Network PVR ViP722k (no idea how to get IR codes)
Lutron Maestro IR Dimming Light Switch (no idea how to get IR codes)
Insten iPod dock DAPPiPODCRA9 (no idea how to get IR codes)
How do I get codes for the above equipment? I read about Pronto Edit and downloaded the software but have no idea how to continue and searching did not help.
When do you and when do you not push Hex Convert button in Demopad?
I ordered a WF2IR unit but it has not come yet. I plan on putting it on a shelf, I could probably hit all my rack equipment with one IR blaster but the Lutron switch is on the opposite side of the room. Could I order a TIVO 2 IR blaster cord and have one pointing in each direction since the WF2IR only has one IR Blaster port?
Thanks for any help!
Samsung PN58C550
UMC-1
XPA-5
(2) AV123 Onix Rocket 760's
AV123 Onix Rocket RSC200 (Bigfoot)
(2) AV123 Onix Rocket RS250
(2) SI 18 HT D2 8ft^3 18hz Ported 1" MDF, Granite Tops
DKAudio is offline
post #452 of 466 Old 01-08-2013, 12:05 AM
Ratik Mehra's Avatar
i have a lutron ir codes hope this will help you
lutron light (1).txt 1k .txt file
File Type: txt lutron light (1).txt (636 Bytes, 156 views)
Ratik Mehra is offline
post #453 of 466 Old 01-08-2013, 12:23 AM
pls send me the denon ip command if you can do for me my email id is ratik.shinu@gmail.com
post #454 of 466 Old 01-08-2013, 10:44 AM
DKAudio's Avatar
Thanks, I just found those at remotecentral actually. I created a thread over at Demopad since this once has slowed down.
Samsung PN58C550
UMC-1
XPA-5
DKAudio is offline
post #455 of 466 Old 01-09-2013, 08:25 PM
have you tried ip commands in demopad if you did that than can you pls tell me how you do that.It really help me
post #456 of 466 Old 01-10-2013, 07:06 AM
DKAudio's Avatar
Sorry, I don't have any IP equipment. I would suggest creating a thread at DemoPad forum.
Samsung PN58C550
UMC-1
XPA-5
DKAudio is offline
post #457 of 466 Old 03-18-2013, 04:11 PM
itchy_balls's Avatar
Anyone have IP commands for Yamaha RX-V671 ?
Ive tried the codes from Demopad forum but I can't get it to work using port 50000 and the default command suffix.
itchy_balls is offline
post #458 of 466 Old 03-18-2013, 05:52 PM
awake33's Avatar
Are you able to ping the receiver's IP?
awake33 is offline
post #459 of 466 Old 03-18-2013, 09:14 PM
Yes I can ping the device. BTW we are neighbors, I live in Kent.
post #460 of 466 Old 03-20-2013, 02:30 PM
awake33's Avatar
That's cool, small world, although your handle makes me a bit nervous. Lol, j/k biggrin.gif
Try these docs, you'll find the codes in there.
Out of curiosity, what else are you controlling with Demopad?
I'm using it for a Dune HD MAX, JVC RS-45, Yamaha RX-A2010, Z-wave lights via Veralite and Panasonic BDT-210.
My experience with the RS-45 after a year is that it's rather flaky when being controlled from Demopad. It powers on and off faithfully, but other commands, such as changing CMD or adjusting the iris, either don't work at all or work one out of every 10 tries. Yet a LUA script run on the Vera to do the same things, and activated as a scene from Demopad, works every time.
awake33 is offline
post #461 of 466 Old 03-22-2013, 12:12 PM
ecoladns's Avatar
Hello everyone,
I am a newbie to the forum as well as to Demopad and have spent 4-5 hours on the Demopad designer trying to create a simple remote for my home theater. I have read through this entire thread soaking up as much info as I could from everyone but I am still having trouble creating the remote that I want and was wondering if anyone would mind sharing a phone file or pad file that has some of the extra bells an whistles programmed into it so I can play around with a completed project to really understand how everything works ?
I understand that building these are very time consuming and I don't want to steal anyones hard work, I really just want to see how a proper file is built so I can try to build one of my own. I love this software and am blown away by some of the remotes that people in this thread have created.
Cheers
ecoladns is offline
post #462 of 466 Old 03-23-2013, 05:47 AM
mborner's Avatar
Quoted: 59 Post(s)
Liked: 26
Originally Posted by ecoladns View Post
Hello everyone,
Cheers
I would highly recommend downloading a couple of the sample projects from Demopad's web site. I cannot stress enough how valuable they are in helping a new user "see the light". The sample projects give you the opportunity to dissect the layout and visually see how things are put together. In my opinion, they are the most valuable training tool there is.
mborner is offline
post #463 of 466 Old 03-24-2013, 09:31 AM
ecoladns's Avatar
Thanks mborner,
I downloaded one of the sample projects already but didn't know that there were others available, Ill go back and try downloading another.
ecoladns is offline
post #464 of 466 Old 07-16-2013, 06:56 AM
Trevorsplace's Avatar
Just looked in on this thread again afer a year.
Looks like we are all neighbors, I live in Auburn also....
Trevorsplace is offline
post #465 of 466 Old 08-20-2013, 04:23 AM
mborner's Avatar
Quoted: 59 Post(s)
Liked: 26
Always working on mu UI. This is what I'm currently working on. This is my DirecTv page. Although it is slightly modeled after the DirecTv App remote, all of the graphics are designed and created by me in Photoshop.
mborner is offline
post #466 of 466 Old 11-13-2013, 12:02 AM
ginie66's Avatar
Hi i have just started creating my project and learning on the fly. I am awaiting my IR to IP box to complete my DemoPAD
Would love to have a look at some peoples .PAD setups im having a few issues with inputing video and creating a Dim switch for my lights
If anyone would like to email me there .PAD for me to have a look at that would be great
im also looking for some plex buttons if anyone could help :)
Cheers Phill
Email: Ginie66@Hotmial.com
ginie66 is offline
Reply Remote Control Area
Irule
