Acoustic Research ARRX18G XSight - Unable to repeat a key? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-22-2011, 07:19 AM - Thread Starter
electrotype's Avatar
I just bought a Acoustic Research ARRX18G XSight. I'm unable to make it repeat the same command twice!
For example, I'm trying to controle XBMC on my htpc and I made the remote learn the "arrow up" key. When I press the arrow up key on the remote, the signal is sent and it works: the focus moves up in the XBMC menu. But if I click the button again nothing happens!! The command is not sent a second time. Why?
Also, I would also like to be able to hold the button for the signal to be sent repeatedly, non stop. Is that possible?
Thanks in advance!
electrotype is offline
post #2 of 9 Old 12-14-2011, 03:55 PM
flyaway718's Avatar
Same problem. I purchased a cheap windows media center remote control with USB dongle. I used XSight to send RF to IR to the dongle and the PC recognizes the command, but each button only works once and not consecutively....any help on this?
flyaway718 is offline
post #3 of 9 Old 12-14-2011, 04:08 PM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Do a google search for MCE and Debounce, to off of the toggle bit that prevents repeat commands.
Edmund is offline
post #4 of 9 Old 12-14-2011, 04:29 PM - Thread Starter
Here was my fix (on the remote):
post #5 of 9 Old 12-14-2011, 04:43 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
XBMC protocol is nearly impossible for any remote to learn, much less get repeats to work. So it's not all Xsight's fault. I would have gladly taken it off your hands.
mdavej is online now
post #6 of 9 Old 12-14-2011, 04:51 PM - Thread Starter
My Harmony 670 works perfectly with XBMC.
But I'm missing a rechargeable battery + dock.
post #7 of 9 Old 12-14-2011, 05:44 PM
mdavej's Avatar
Liked: 940
I'm guessing you never had to learn it on harmony. My other UEI remotes (maker of Xsight) work fine too because the protocol was built in. The key is not to learn it. The problem is the protocol has a toggle bit in it that learning would have no clue about. The remote has to know to toggle that bit with each press. If you learn it, and it knows nothing about the toggle, the command will work the first time when the bit is in the right state and fail the second time when the bit is in the wrong state.
These are the XBMC device codes you should try on the Xsight: Y0522, Y1972
post #8 of 9 Old 12-21-2011, 09:41 AM
flyaway718's Avatar
I did some searches as suggested. This seems to be the problem that I am experienced. Will give it a try - thanks for the useful info.
post #9 of 9 Old 01-11-2012, 03:26 PM
jontyrees's Avatar
Liked: 38
Just wanted to give kudos to Audiovox customer service. I called the number they supply in their manual when I ran into an issue programming the Touch for my Scientific Atlanta Cable/DVR box, and not only did they pick up almost immediately, but the rep was in the US, and was able to solve my issue quickly. The problem was just with the Power on/off not working in an activity routine but working as a hard button in the Device mode. Rep was able to direct me to an additional set of instruction options in the menu for that device (had to select "PWR", not "Power On/Off"). Anyway, they were very helpful.
Remote is working fine now, although I haven't added to the favorites section yet. It's a nice remote. My system is pretty simple (TV, Receiver, Cable/DVR, BD, ROKU), so TBH, the $17 learning RCA I also got does the job just as well, maybe a little easier, but I could see the Xsight really working well in a more complex situation. Programming it is a breeze once you figure out that there are more options than first appear on the setup screen. Plus I like the backlighting and so far I have yet to see even one bar of battery life drop, even when the remote is out of the charging cradle for 2-3 days.
jontyrees is offline
Reply Remote Control Area
Acoustic Research Arrx18g Xsight 18 Device Universal Learning Remote Control With Touchscreen Color
