Best Universal Remote for less than $1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-25-2011, 09:29 AM - Thread Starter
Football Dad's Avatar
I am looking for a very good universal remote control for my home theater. I don't need RF at the moment but will in the near future. I have an iPad if that is helpful. Thanks in advance.
Football Dad is offline
post #2 of 9 Old 10-25-2011, 11:38 AM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 986
There are lots of very good remotes in that price range. Any specific requirements to narrow it down a bit? Do you plan to program it yourself? Do you mind dedicating your iPad to your home theater and risk it being dropped, sat on, scratched or knocked off a table or chair?
mdavej is online now
post #3 of 9 Old 10-25-2011, 02:42 PM - Thread Starter
I don't mind some basic programming, but I don't want to make it a second career. I like the concept of downloading the codes, so I was attracted to the Harmony 1100 but it was a real dog so I returned it. I am willing to dedicate my iPad to the theater if that's the best choice. thanks
post #4 of 9 Old 10-27-2011, 09:46 AM
Neurorad's Avatar
Quoted: 231 Post(s)
Liked: 145
How often do you change your equipment, in the HT room? If you don't foresee any upgrades in the next few years, a professionally installed URC or RTI/ProRemotes unit would be a good option.
Call a few local installers, get a ballpark price. Look for online reviews of specific URC RCs. Remotecentral.com might be a good forum to search.
I hate that iPad 'slide to unlock'.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #5 of 9 Old 11-20-2011, 03:35 PM
spidermaker's Avatar
URC RFS-200 bundle. Amazon for around $80.
spidermaker is offline
post #6 of 9 Old 11-21-2011, 12:42 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
Seriously? The OP's budget is ONE THOUSAND DOLLARS.
I'd look at URC's offerings such as the MX-980, MX-780, or MX-5000.
At $1000, you are in the neighborhood of an entry level automation system, such as Control4, which would start off as a universal remote for your theater. Then down the road you could add functions such as lighting control or security system integration. Just a thought.
cshepard is offline
post #7 of 9 Old 11-21-2011, 12:47 PM
ccotenj's Avatar
Liked: 101
imo, the urc mx-5000... i like wand remotes personally, and it has the best ergo of any remote i've ever touched (and i've touched them all )....
programming it isn't rocket science... all depends on how far you want to go with it... you can be basic, or you can take it to great lengths...
- chris
ccotenj is offline
post #8 of 9 Old 11-21-2011, 01:17 PM
cshepard's Avatar
Quoted: 21 Post(s)
Liked: 38
The MX-5000 is one sexy remote. I got the MX-980 right before the 5000 came out. While sitting at the URC booth at CEDIA, the guy immediately to my left and the guy immediately to my right each won a 5000. I got a keychain.
cshepard is offline
post #9 of 9 Old 11-21-2011, 01:30 PM
ccotenj's Avatar
Liked: 101
man, talk about poor luck...
yea, i had (still have, it's used in my secondary setup) a mx-980, and i really liked it... once i picked up the 5000 though, the 980 felt like a brick in my hand...
it's not cheap, but i look at it this way... it's something i use a lot, so ergo really matters... and you can do all kinds of things with the touchscreen if you are the type who likes to fiddle...
- chris
ccotenj is offline
Reply Remote Control Area
