X10 IR 543/ Global Cache Codes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-04-2011, 11:31 AM - Thread Starter
gp56's Avatar
I am having a hard time getting working X10 IR 543 codes in Global Cache Format. I converted the hex codes I had in my Pronto 9600 and no response at all. I also downloaded many X10 hex codes from various websites to no avail. I am using the Demopad/Itach interface. Anyone out there have these codes that actually work in GC format? Thanks.
gp56 is offline
post #2 of 2 Old 06-27-2012, 12:15 PM
djfunkster's Avatar
Not sure if you're still having problems, but I did and came up with a couple of solutions
1. Mine would only accept the "A" house code
2. My LD11 modules would only accept direct commands "1-ON" as opposed to "1" then "ON"
I am still hunting for an extended command solution (that's what brought me here via google)
The demopad helpdesk suggested changing the repeat interval to 5 when importing the commands but nothing yet
djfunkster is offline
Reply Remote Control Area
