Harmony 600/Panasonic GT25 Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-28-2011, 07:16 PM - Thread Starter
Rob-Houston's Avatar
Quoted: 126 Post(s)
Liked: 73
I have a Panasonic GT25 Plasma and a new Harmony 600 remote. Everything works fine except the Harmony InputTuner command does not select the Tv input. It functions the same as the InputNext command. All of the HDMI, Video, Component and PC discrete commands work fine they all go directly to the correct input. Any ideas?
Rob-Houston is offline
post #2 of 5 Old 12-29-2011, 05:28 AM
BPlayer's Avatar
You may need to increase the "Power on delay" found in Devices, Settings, Adjust the delays. Values as high a 15000 are not uncommon.
BPlayer is offline
post #3 of 5 Old 03-09-2012, 11:57 AM
sinecure's Avatar
Same issue, different Panasonic TV and Harmony remote.
I've got the Panasonic ST30, and a harmony remote. Like the OP I can get the PS3/HDMI to come on, but if I select watch TV it never switches to Ant input. I can sit in the help screen on the harmony and hit no did not fix over and over and over and it never goes to Ant input.
suggestions?
sinecure is offline
post #4 of 5 Old 03-09-2012, 02:27 PM - Thread Starter
Quoted: 126 Post(s)
Liked: 73
suggestions?
The problem was resolved using VT-25 Solution
"This method allows you to bring up the input menu but you do NOT need to navigate through it. Under the device settings for your TV select "adjust inputs" (next). Then select "Method 4" (next). Hit next again. Where it says "remote button displays source inputs menu" select the remote command that draws up your input menu (on my VT25 it is "InputNext." Where it says "remote button confirms the source input" put "-None-". Then, for each input put the corresponding number button (1 to 0) for each input as seen in your TV's input menu. Your Panasonic assigns a number (1, 2, 3 up to 0) to each input with "TV" being 1, "HDMI "1 being 2, up to "PC" which is 0."
I did not change each input as indicated just input 1. This worked fine. I re-subscribed to DirecTV after a 4 year absence. The TV source is no longer used.
post #5 of 5 Old 03-09-2012, 03:02 PM
bryansj's Avatar
Quoted: 1419 Post(s)
Liked: 645
I think you can also simply hit Ch+ or Ch- and it will change over to the TV tuner.
bryansj is offline
Reply Remote Control Area
