Official URC R40 Thread - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #301 of 313 Old 08-20-2015, 07:53 AM
Stanton's Avatar
Quoted: 1550 Post(s)
Liked: 798
Originally Posted by AJCxZ0 View Post
This one makes six.
I set the screen brightness at around 60% when I first got my new (direct from URC with new firmware) R40, but now it's at 100% and it difficult to see clearly in daylight.
My MX-500 remains in active duty. though the buttons are worn and some require a firmer press than others.
Guess I'm number seven...my R40 screen is so dim it's only useful at night; to make things worse, you can't change the (blue) background color of the keys INSIDE devices! I haven't checked this thread in awhile but I need to investigate some of the replacement/suggestions. I really don't know why they discontinued this remote
Yamaha RX-A2050 AVR (5.0.2)
(4) Polk Monitor 10B's (R/L F/R), (2) Polk Monitor 4's (TM), Polk CS300 center channel
Analog: B&O TX2 Turntable, Nakamichi Cassette Deck 1
Digital: Pioneer CLD-99 Elite LD, Panasonic DMP-UB900 UHD Blu-Ray
LG 65EF9500 4K OLED
Stanton is offline
post #302 of 313 Old 08-20-2015, 03:27 PM - Thread Starter
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 527 Post(s)
Liked: 782
URC has been moving away from the lowly Do-It-Yourselfer market in the past few years, choosing to focus instead on it's network of Authorized Custom Installers to install and program their higher end remotes, and the OEM market (cable companies etc). URC used to be the best source for good DIY remotes but as of a few years ago they no longer make any user-programmable remotes. That pretty much leaves the DIYer with Harmony. URC still sells the MX-450 but they consider that a Pro remote, but it's user-programmable. I have one but it's nowhere near as configurable as the R40.
The place where i bought my last R40 still shows about a half dozen left in stock and that's the last i've been able to find. I expect the OLED screens on all R40s and pro MX-780s to eventually dim to the point that the remote is no longer usable. I wish they would have used LCD screens in these things.
Aside from the MX-450, the only other user-programmable remotes are the Harmony remotes and the discontinued Nevo C2 or C3.
__________________________
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #303 of 313 Old 08-20-2015, 04:18 PM
Stanton's Avatar
Liked: 798
I do too, which is why I'm seriously considering the MX-450. To me, it looks like an R40 with a (bigger) LCD screen. I don't use macros much anymore, so I think it will do the job for me.
LG 65EF9500 4K OLED
Stanton is offline
post #304 of 313 Old 11-03-2015, 07:56 PM
nlpearman's Avatar
Quoted: 31 Post(s)
Liked: 27
This is a shame. As a former MX-500 and then MX-350 user, I love URC remotes!
So what remote are you guys recommending now?
Upgraditis Anonymous
nlpearman is offline
post #305 of 313 Old 11-04-2015, 08:33 PM
Mikejl's Avatar
Quoted: 23 Post(s)
The most popular URC remotes now are the MX-780 and MX-890 Professional models. They require URC proprietary programming software which is only legally available from an authorized URC dealer.
I own both of these remotes and they are fantastic. The MX-890 is my favorite.
There is also a soon to be released new URC MX-990 remote. It looks like its going to be another great remote.
Mike
Mikejl is offline
post #306 of 313 Old 11-08-2015, 06:37 AM
dboff01's Avatar
Sadly, my trusted URC R50 started to become flaky after 4 yrs of daily use, with the select button becoming inconsistent. My wife managed to finish the remote off with an accidental drop on tile floor, which resulted in an explosion of plastic.
I was dissapointed to find URC hasn't maintained a product line in the consumer space and went instead with a Harmony Home Control. This system uses a remote communicating with a hub via RF, the hub then transmits IR/Bluetooth to all devices in the system. So far, working fairly well. The Harmony configuration software is definitely a slicker/faster process than the manual macro building required for the R50. But with Harmony I always worry about the build quality as I had multiple units fail within a year or so before I went to the URC.
dboff01 is offline
post #307 of 313 Old 11-09-2015, 06:40 AM
benlwong's Avatar
Same Dim Problem
Mine makes eight. I had mine for almost 3 years but thought it would last longer than that. I contacted support via email and will see if they get back to me. As another poster has mentioned, URC is focusing their business to the high end market (custom installers). I don't blame them since going toe-to-toe against Logitech isn't a good business strategy. Oh well, it is time to move on. I am looking at the Logitech Harmony 650. I don't need a lot of fancy features and it looks to be the best value remote out there.
Ben
benlwong is offline
post #308 of 313 Old 11-09-2015, 07:47 AM
mdavej's Avatar
Quoted: 2277 Post(s)
Liked: 992
The Nevo C2 at $16 is actually the best value remote at the moment. See my Harmony comparison here:
http://www.hifi-remote.com/wiki/inde...t_and_Nevo#FAQ
mdavej is offline
post #309 of 313 Old 11-29-2015, 06:28 AM
William K's Avatar
Is the Nevo C2 a good device oriented remote? I had a Harmony once and don't really care for an activity based remote. I have a URC R40 and can't hardly read the screen anymore
William K is offline
post #310 of 313 Old 12-09-2015, 01:08 PM
wward's Avatar
Programming URC R40
Hello I have an ADA Suite 7.1 processor which uses remote model RC-40BA/H. I have been trying to program the URC 40 to control the Suite 7.1 and have had no success.
I tried the built in codes and using the URC 40's learn feature. When I use the learn feature it appears to learn the functionality of the key presses and saves them without an error message. However nothing works. I tried contacting support for both companies, I never received an answer from ADA and URC via email asked me to call their support line, which I haven't done yet.
Wondering if anyone has had experience with ADA remotes or has any technical suggestions? I have run out of ideas. BTW the RC-40BA/H is an IR remote.
Will
wward is offline
post #311 of 313 Old 12-14-2015, 01:40 PM
Stanton's Avatar
Liked: 798
A better replacement for the R40 is the MX-450, especially if you like URC remotes. They have a very similar layout and the (defective) OLED screen has been replaced with the old LCD screen. Checkout the MX-450 thread for more info.
LG 65EF9500 4K OLED
Stanton is offline
post #312 of 313 Old 12-14-2015, 05:25 PM
William K's Avatar
I just bought an R50 yesterday. It's supposed to be very similar to the MX 450 and also has the LCD screen. Hopefully everything works out.
post #313 of 313 Old 08-05-2017, 11:00 AM
Liked: 0
Hi. Newbie here. I just bought a used R40. The comments here about programming are spot on — a real PITA. I have managed to get it programmed for ALL my oddball collection of devices. I’m just picking up a few buttons I missed as I use the remote. And only 49% memory used. This is the first remote I’ve tried that has enough memory to learn as many buttons as I need.
My only real complaint may have to do with the previous comments about dim displays, but I only have trouble with the sub-menus. The MAIN display is just fine, but the sub-menus are a very dim blue and I can’t find any way to change them like the MAIN screen.
Has anyone worked out a solution to this?
Bill Vogel is offline
Reply Remote Control Area
Urc R40 My Favorite Remote Advanced Universal Remote Control For Up To 18 A V Components , Remotes And Controllers , Mx 780 Universal Remote Control , Panasonic
