Can I use the Harmony 1100 with IR extender AND RF repeater at the same time? - AVS Forum | Home Theater Discussions And Reviews
Old 01-03-2012, 02:40 PM - Thread Starter
basementdweller1's Avatar
I would like to use a Harmony 1100 with the IR repeater to help control the projector and Lutron Grafik Eye lighting panel both over my shoulder on the back wall while pointing the remote forward. At the same time I would like to control an in wall av rack located in a hallway 12' ft away using the RF extender. I know I can set the Harmony by device if it uses the RF extender or not, but do the IR functions work with the repeater at the same time?
Can I use BOTH at the same time depending on device?
basementdweller1 is offline
Old 01-07-2012, 01:47 PM - Thread Starter
Is the harmony IR extender passive, ie. it repeats an systems IR?
Old 01-07-2012, 04:48 PM
bryansj's Avatar
Quoted: 1134 Post(s)
Liked: 560
Yes. IR in to IR out.
bryansj is online now
Harmony 1100 Remcontrol
