IR Remote through a wall - novice needs advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-11-2012, 09:04 PM - Thread Starter
Darren72's Avatar
Hi - I have a Samsung 40" LED (UN40D6000). The tv is mounted on the wall. The cable box is behind the wall, in a closet, so the HDMI cord runs from the cable box, through, the wall, to the tv.
Since the cable box is in the closet, the cable remote doesn't reach it. I would like help understanding my options. I understand I can buy something like these:
Next Generation Remote Control Extender
Cables To Go Impact Acoustics 40430 Infrared (IR) Remote Control Repeater Kit
I have two questions:
1. Are these the best way to solve this problem?
2. If so, what product do people recommend?
Darren72 is offline
post #2 of 6 Old 01-12-2012, 01:16 AM
xfett's Avatar
Yep an IR repeater is what your gonna need. As far as brands I don't have much experience with either of those you mentioned but I imagine if you did a Google search for IR repeater you might find something.
"Man, I told you we shouldn't have shot Niedermeyer"
xfett is offline
post #3 of 6 Old 01-12-2012, 09:44 AM
FlyOnTheWall's Avatar
Quoted: 92 Post(s)
Next Gen works great.
Would easily solve your problem, as long as your cable box remote uses AA or AAA batteries.
FlyOnTheWall is offline
post #4 of 6 Old 01-12-2012, 03:46 PM - Thread Starter
Darren72's Avatar
Thanks. I just ordered the Next Gen. The price was right ($40) and I like that I won't have to stick a receptor on the front of the tv.
Darren72 is offline
post #5 of 6 Old 01-12-2012, 07:29 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
Dropkick Murphy is offline
post #6 of 6 Old 01-13-2012, 07:39 AM - Thread Starter
Darren72's Avatar
That's a cool product.
It's seems like the logical solution is to enable tv's to pass through IR signals. There's already an IR receiver on the tv. There should be an "IR out" terminal on the back that you can then connect to an emitter or an "IR in" terminal on a cable box, blu-ray player, etc.
Do any tvs have this? (Not that I'm going to buy a new tv just to solve this problem!)
Darren72 is offline
Reply Remote Control Area
