Harmony one with Onkyo TX-NR609 trouble - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-15-2012, 08:21 PM - Thread Starter
icemanls2's Avatar
I have a diiferent problem i havn't saw with this combo. When i turn everything on hitting the watch tv activity, everything turns on and sets to the proper inputs but about 5 seconds later the 609 switches to tv/cd input. Hit help and it fixes it and doesn,t happen again until you turn everything off then turn back on using the watch tv activity button. I called logitech support with no avail. I have tried learning all inputs from the stock remote, changing the order in which everything turns on, reprogrammed after deleting tv/cd input from the input list. I have tried everything i know. I have been using Harmony remotes for about 10 years and currently have 3 ones and a 650 so im not a newb. Fyi everything works fine with stock remote.
icemanls2 is offline
post #2 of 4 Old 01-15-2012, 08:37 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
I would try creating a "Generic Activity" and see if the problem persists. If it works out you will have to map each button manually because the generic activity is completely blank.
Dropkick Murphy is offline
post #3 of 4 Old 01-15-2012, 08:44 PM - Thread Starter
icemanls2's Avatar
I didn,t think of that. Alot of work but i'll try that. This one is for my father in law and hes about ready to return the onkyo for a Denon. I have probably 15 hours into trying to fix this issue and it's on my last nerve, lol.
post #4 of 4 Old 01-16-2012, 10:28 AM
bryansj's Avatar
Quoted: 1142 Post(s)
Liked: 562
You probably have HDMI CEC Link enabled. Turn it off.
bryansj is offline
Reply Remote Control Area
Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver
