Unable to Get RCA RCRP05B to do Anything - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-23-2012, 10:41 AM - Thread Starter
JamesJoey's Avatar
Just purchased an RCA RCRP05B and so far I'm batting a thousand. Trying to get my Direct D10-300 receiver coded into the RCA but none of the codes work ans searching for the code didn't work either. Tried learning that didn't work either. When learning I assume I went through the proper procedure but when I hold down the directv remote the mode button on the rca does nothing.
Any help will be appreciated,
James
JamesJoey is offline
post #2 of 8 Old 01-23-2012, 11:13 AM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
With Directv receiver set to default codeset 00001, the code in the RCA remote that would work is SAT 1377.
Edmund is online now
post #3 of 8 Old 01-23-2012, 11:33 AM - Thread Starter
JamesJoey's Avatar
Not sure how to set the Directv default to that. Can you please elaborate?
James
post #4 of 8 Old 01-23-2012, 11:49 AM - Thread Starter
JamesJoey's Avatar
I put the code in that you suggested and it worked. I was able to learn all the other commands on the direct remote I just couldn't get it to power on or off.
That code worked.
post #5 of 8 Old 01-23-2012, 11:55 AM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
with code 1377 there should be a toggle command mapped to the power key, which will do both on & off of the receiver.
post #6 of 8 Old 01-23-2012, 12:17 PM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 989
No need to learn any DirecTV commands as most should already be there. Here they all are. Program any missing codes as Advanced Codes per the Manual instructions at the Wiki link in my signature.
In case you're not aware, you can program the RCA from a PC like a harmony if you buy or build a JP1.3 interface cable for it.
0 00138
1 00010
2 00034
3 00026
4 00242
5 00234
6 00002
7 00250
8 00082
9 00074
channel up 00042
channel down 00066
power 00146
menu 00019
guide 00083
info 00067
exit 00003
up arrow 00011
down arrow 00035
left arrow 00027
right arrow 00243
select 00235
enter 00154
last/prev ch 00058
play 00147
pause 00163
rewind 00155
fast fwd 00115
stop 00139
record 00107
f.fwd/next track 00123
replay 00131
dash 00162
active 00075
back 00251
list 00099
red 00008
green 00024
yellow 00032
blue 00240
discrete on 00014
discrete off 00006
format 00153
clear NVRAM 00085
factory test 00093
play (slomo) 00227
fwd (skip fwd to tick) 00171
rew (skip back to tick) 00179
30s slip (jump to end) 00211
skip back (jump to start) 00187
mdavej is online now
post #7 of 8 Old 01-23-2012, 01:00 PM - Thread Starter
JamesJoey's Avatar
Got it.
post #8 of 8 Old 01-24-2012, 05:26 AM - Thread Starter
JamesJoey's Avatar
I got the power key to turn on the tv and the receiver... great.
James
Reply Remote Control Area
Audiovox Corp Rca One For All Audiovox Universal Remote Control Rcrp05b
