NextGen RF extender and PS3: Can it be done? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-13-2012, 11:04 AM - Thread Starter
radchad3's Avatar
Hello all! i have the NextGen RF extender and have been relatively happy with the product so far. I am currently using it to run a cable box and receiver placed in a closet. I just bought a PS3 and want to be able to run this as well. Does anyone have a solution? Thank you for your time! Chad
radchad3 is offline
post #2 of 9 Old 02-13-2012, 12:06 PM
Vin
Vin's Avatar
Quoted: 12 Post(s)
I don't own this but it sounds like what you're looking for > http://www.remoteshoppe.com/p-281-sc...station-3.aspx
Vin
Vin is offline
post #3 of 9 Old 02-13-2012, 12:30 PM
mdavej's Avatar
Quoted: 2129 Post(s)
Liked: 940
Vin's suggestion is a good one. There are many options around that price from logitech, one-for-all, toothfairy, RE-BL, etc. If you want something cheaper you could simply enable HDMI-CEC (bravia sync) for free or get a $2 Auvio adapter. Nyko makes a similar adapter for $15. The Nyko and Auvio won't do power on, and power off requires a macro. Bravia sync will typically do power on/off and all transport, nav and menu controls, depending on the HDMI-CEC capabilities of your TV. The more expensive adapters will give you full control.
mdavej is offline
post #4 of 9 Old 02-13-2012, 12:40 PM - Thread Starter
radchad3's Avatar
Thanks for the replies! If I used the USB IR adaptor, how do I know which codes to program into my remote so they work? Sorry if this is a dumb question!
radchad3 is offline
post #5 of 9 Old 02-13-2012, 01:35 PM
mdavej's Avatar
Liked: 940
It will tell you in the instructions. Most of them use sony DVD codes. Some (like Nyko) come with remotes you can learn from if necessary (Nyko also uses sony DVD codes).
mdavej is offline
post #6 of 9 Old 02-13-2012, 01:46 PM - Thread Starter
radchad3's Avatar
Will look into these options! Thank you!
radchad3 is offline
post #7 of 9 Old 02-13-2012, 11:01 PM
Nimblor's Avatar
It worked fine for me with the Next gen extender and the Logitech ps3 adapter.
Nimblor is offline
post #8 of 9 Old 02-14-2012, 09:00 AM
mdavej's Avatar
Liked: 940
How did you get the logitech codes into your remote? It uses an unusual protocol, so you'd need the pronto hex, JP1 upgrade, or learn from a harmony remote.
mdavej is offline
post #9 of 9 Old 02-14-2012, 10:55 AM
Nimblor's Avatar
Well.. Back when Logitech made good and affordable remotes... I was using the Logitech xbox360 remote with the next gen remote extender. The battery transmitter worked awesome with all of my devices including the Logitech ps3 adapter. Actually it still works for me but the screen died on my remote so I don't use it.. I haven't replaced it yet because the newer harmony remotes have less features and cost more than my old one.
Nimblor is offline
Reply Remote Control Area
