comcast remote ok/select lg blu ray please help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 02-27-2012, 09:55 AM - Thread Starter
wage's Avatar
Can someone help me out?
I programmed my Comcast remote for my lg blu ray player and it works but it won't allow me to select OK/select button to play a movie???
I'm using a lg blu ray player bd611
A platinum Comcast remote with red OK/select button
The code I used is 20741
Any help please?
wage is offline
post #2 of 11 Old 02-27-2012, 10:54 AM - Thread Starter
wage's Avatar
Bump
Can anyone help or point me in the direction please
wage is offline
post #3 of 11 Old 02-27-2012, 11:12 AM - Thread Starter
wage's Avatar
75 views with no reply
wage is offline
post #4 of 11 Old 02-27-2012, 11:29 AM - Thread Starter
wage's Avatar
Bump
wage is offline
post #5 of 11 Old 02-27-2012, 01:23 PM
3FingeredGlove's Avatar
Quoted: 22 Post(s)
Liked: 39
Try assigning 00229 to the OK Select button in AUX mode using the 994 command.
3FingeredGlove is offline
post #6 of 11 Old 08-27-2012, 11:43 AM
dking paul's Avatar
This instruction worked ...perfect .. The ok button on my comcast remote now will work for my lg blue ray player..
Just folloe the link that this guy put on..and go to section 994.here is what i did.
Assign Effective Function Code (EFC) from another device
1. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
2. TAP 9 - 9 - 4.
3. TAP the "from" DEVICE button (eg, TV)
4. TAP the SETUP button
5. TYPE the 3 or 5 digit EFC code (aka "advanced code)
6. TAP the "to" DEVICE button (eg, VCR)
7. TAP the "to" regular button (eg, VOL+) - two Blinks
Thanks...five digit code i used was the one he gave. !! it worked perfect...
dking paul is offline
post #7 of 11 Old 08-27-2012, 11:45 AM
dking paul's Avatar
code used was 00229
post #8 of 11 Old 10-07-2012, 04:09 PM
Sjordan125's Avatar
ok so iam having the same problem but when i try that it still does not work!!!
Sjordan125 is offline
post #9 of 11 Old 07-07-2013, 12:28 AM
s4forum18's Avatar
So I have the same problem but with a Panasonic BR player (BD-65). It was given to me without the BR remote. I got the platinum remote to do everything but the select button. I can get the 9-9-4 thing to work. Using a Vizio TV if that matters.
thanks
(hopefully some see this thread I know its old).
s4forum18 is offline
post #10 of 11 Old 07-07-2013, 12:47 AM
s4forum18's Avatar
Ok so I did the 994 install. Now the select button works BUT it turns off the Blu Ray instead of "select". anyone see this?
post #11 of 11 Old 07-07-2013, 10:51 AM
Quoted: 22 Post(s)
Liked: 39
The EFC number depends on the setup code being used. So instructions for a LG Blu-ray won't work with a Panasonic. Here's exact instructions. Note that the instructions posted earlier by dking paul are different--those only worked by coincidence.
Assuming you're using setup code 20490 (use the setup code blink back instructions if you're not sure:
1) Press AUX
2) Press Setup until 2 blinks
3) Enter 994 (2 blinks)
4) Tap Setup (don't hold it)
5) Enter 00191
6) Press OK/Select
The remote should blink twice to indicate the procedure worked.
Reply Remote Control Area
Blu Ray Players , Lg Bd611 Blu Ray Disc Player
