PC utility to decode IR remote codes? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-13-2012, 08:41 AM - Thread Starter
Blaq's Avatar
I have a monoprice HDX-401E HDMI switcher. I want to unearth the IR codes used by its dedicated remote, to integrate them into one of my learning remotes. I can't find any codes online, so I figure I'll have to find them myself.
I have a Dell XPS9100 with built-in IR receiver. Is there a utility I can download that reports received IR data? The plan would be to see what data is logged when I use the switcher's remote in front of my PC, and perhaps extrapolate device codes to use in my learning remote.
Blaq is offline
post #2 of 9 Old 03-13-2012, 09:00 AM
3FingeredGlove's Avatar
Quoted: 13 Post(s)
Liked: 31
Don't know about a utility, other than lots of people hope that one exists, but for the Monoprice HDX-401E, the IR protocol is:
NEC1 35.69
function function number
1 3
2 37
3 7
4 9
Power 1
Ch+ 19
Ch- 17
Can you use this format, or do you need Pronto Hex?
3FingeredGlove is offline
post #3 of 9 Old 03-13-2012, 09:56 AM
mdavej's Avatar
Quoted: 1325 Post(s)
Liked: 665
Why can't you just learn from the mono price remote directly? Isn't that what learning remotes do?
mdavej is offline
post #4 of 9 Old 03-13-2012, 06:57 PM - Thread Starter
Blaq's Avatar
Brain fart I meant a programmable remote.
Originally Posted by 3FingeredGlove View Post
the IR protocol is:
NEC1 35.69 [...]
Actually, I was hoping for a device number to punch into my programmable remote. I can't make use of IR protocol or Pronto data. My main goal is to map the HDMI switch's on/off function to the remote; input selection is gravy.
Thanks for helping this noob!
Blaq is offline
post #5 of 9 Old 03-13-2012, 07:09 PM
mdavej's Avatar
Liked: 665
So you just want a setup code? No remote has a setup code for that switch, but Harmony or any learning remote will work. You should be able to find a learning remote for less than $20.
But I have to ask why bother ever turning it off? I imagine it uses an insignificant amount of power when idle. I had one of these monoprice switches and found the LEDs quite annoying. But rather than turning it on and off, I just covered them with electrical tape. I've since gotten even cheaper auto switches that don't need external power at all.
mdavej is offline
post #6 of 9 Old 10-01-2013, 03:49 AM
mwan's Avatar
NEC1 35.69
1 3
2 37
3 7
4 9
Power 1
Ch+ 19
Ch- 17
digging up an old thread. I could sure use this in pronto Hex if it is not to much trouble. I tried hexmaker but could not make head or tail of it...
thanks
Miles
mwan is offline
post #7 of 9 Old 10-01-2013, 06:25 AM
mdavej's Avatar
Liked: 665
Here you go. You'll have to match function number to function:
Code:
Protocol=nec1 Device=35.69
Device Code: 35.69 Function: 1
0000 006D 0022 0002 0157 00AC 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
Device Code: 35.69 Function: 3
0000 006D 0022 0002 0157 00AC 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
Device Code: 35.69 Function: 7
0000 006D 0022 0002 0157 00AC 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
Device Code: 35.69 Function: 9
0000 006D 0022 0002 0157 00AC 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
Device Code: 35.69 Function: 17
0000 006D 0022 0002 0157 00AC 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
Device Code: 35.69 Function: 19
0000 006D 0022 0002 0157 00AC 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
Device Code: 35.69 Function: 37
0000 006D 0022 0002 0157 00AC 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
I used makehex and makehex GUI. Took about 30 seconds.
mwan likes this.
mdavej is offline
post #8 of 9 Old 10-01-2013, 09:28 AM
mwan's Avatar
Code:
Much appreciated!
mwan is offline
post #9 of 9 Old Today, 01:40 PM
altcool's Avatar
Thanks all for the info and HEX codes I have use the above codes to create a Control4 Driver for the HDX-401E HDMI switcher. I have attached the Driver below!
DHC-80.2; SR8500; TX-SR606; BDP-51FD; DVP-CX995V; PS3; JBLStudio7.1; SmartH1; OuyaKodi; NUCKodi; HC800; (3)HC300; HC250; (4)SR250; SlingBoxProHD; HLP-5685w; TC-P50S60; HLS-4676S; SK-32H240S; LTV-32w6; GW2750; FP222WH; LTV-19w6; UnRaid; DS411+; XT1095; XT1034; Nexus7
altcool is online now
Reply Remote Control Area
Monoprice
