Bringing everything together with the right remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-17-2012, 12:31 AM - Thread Starter
phoreverphantom's Avatar
Hello everyone, been doing a lot of reading around these parts in regards to finding the right remote for my setup (Denon 1712, Comcast RNG150, and an HTPC with usb ir receiver) and I think that I narrowed it down to the following:
Refurb Logitech Harmony 650 - $49
Acoustic Research ARRX18G XSight - $70 New or $50 Used
Refurb Logitech Harmony 700 - $64
Let me know some of your thoughts on these, or any others that you may recommend. Thanks for any suggestions.
phoreverphantom is offline
post #2 of 6 Old 03-17-2012, 11:35 AM
mdavej's Avatar
Quoted: 2128 Post(s)
Liked: 940
The 650 is plenty and will be easier to setup and use than the Xsight, especially since you have a cable box with no discrete power commands. Go for the 700 if you think you'll be getting more devices in the future.
mdavej is offline
post #3 of 6 Old 03-19-2012, 09:30 AM - Thread Starter
Thank you for your suggestion!
post #4 of 6 Old 03-20-2012, 07:27 PM - Thread Starter
Actually went with a brand new harmony one for $100 after a 50% discount. Figured it is worth the extra minimal investment.
post #5 of 6 Old 03-21-2012, 08:51 PM
Digitally challe's Avatar
Liked: 31
Where did you buy it?
Digitally challe is offline
post #6 of 6 Old 03-22-2012, 10:55 AM - Thread Starter
Direct from the logitech website. Had an old harmony 520 that has a broken screen so I called logitech and after a brief troubleshooting stint they sent me a 50% off coupon for any harmony remote (no refurbished or clearance). Should be arriving today.
Reply Remote Control Area
