Help with RS-232 and Cat5 - AVS Forum | Home Theater Discussions And Reviews
Old 04-16-2012, 04:42 PM - Thread Starter
newHTowner's Avatar
Hi Guys,
I have a Panasonic AE7000U with unterminated Cat5 running from it to my rack. I'm trying to use an ITach to Serial adapter to control the projector via RS-232 with the roomie remote.
How do I terminate both ends from cat5e to serial plug. I've read about DB-9 to RJ45 connectors but they all come "unpin". I really don't know how to do the pin out or should I do it another way?
newHTowner is offline
Old 04-17-2012, 08:05 PM - Thread Starter
newHTowner's Avatar
anyone?????
Old 04-17-2012, 10:45 PM
Andrew Wolfe's Avatar
1) You definitely want RJ45-DB9 adapters. Something like this one
2) The pinout depends on each device. Most devices can use the Null Modem without handshaking cable shown here
Andrew Wolfe is offline
Cat5 Rack 1u
