Verizon Philips P144v2 remote not working with Yamaha RX-V3800 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-26-2012, 07:07 PM - Thread Starter
Thunderduck's Avatar
Quoted: 54 Post(s)
Liked: 25
Trying to get tv sound through my RX-V3800 using the Verizon remote to control the tv, dvr, and 3800. I can control the tv and dvr fine, but the 3800 will not turn on.
Using the provided codes for the remote, none will turn the 3800 on. Several will turn the 3800 off and work other controls, but none can power the 3800 on.
My mother cannot see the keys on my Harmony one so that is why I am trying to get the Philips remote to work. She is comfortable with using it, not the Harmony.
Any help/advice will be much appreciated.
Tks,
Steve
Edit: Remote is also identified as the Philips RC144 Phase 2.
Thunderduck is offline
post #2 of 3 Old 04-27-2012, 02:51 PM
mdavej's Avatar
Quoted: 2277 Post(s)
Liked: 992
Sorry, Duck, but there's nothing you can do with that remote. You can, however, get an Atlas OCAP for $8 on ebay that looks just like it and program it anyway you like. If you go that route, search this forum for yamaha EFC and you'll find the relevant codes and programming instructions. Do that search before you buy to confirm you get the right model with the right codes. You can even buy or build an interface cable quite cheaply for the Atlas and program it from your PC/Mac/Linux like Harmony.
You'll get even better advice (about the Atlas, not the VZ remote) at JP1 forums at hifi-remote.com.
Good luck
mdavej is offline
post #3 of 3 Old 04-27-2012, 07:34 PM - Thread Starter
Quoted: 54 Post(s)
Liked: 25
Thank you very much!!
Reply Remote Control Area
Yamaha Rx V3800bl Receiver
