HTM MX-800-> Media Center - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-02-2012, 05:47 PM - Thread Starter
Ewingr's Avatar
Quoted: 62 Post(s)
I had my HTM-800 working long time ago. Since then have upgraded to Win7. Have had issues, and now finally trying to fix. I use in conjunction with Girder.
I have learned the codes from a MS Remote. I initially had problems with repeating keys, but then in Girder, I set the anti-repeat slow.
Works, except...when I press the Fast Forward, it only fast forwards at 4X. With some experimentation, I have found that in order to get it to FF faster, I need anti-repeat to work, which then screws up just about everything else.
Has anyone solved such a problem as this?
[EDIT]
Also, I am finding that I need the remote to alternate between 2 different codes if I want to repeat a command. For example if I push the left button, on my learned remote, it only works once, becuase it only learns one of the 2 alternating codes put out by the MS remote.
Any ideas on this one?
(I don't know how I had it working before, assumning it works the same now in the system).
Ewingr is offline
post #2 of 2 Old 05-02-2012, 11:18 PM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
do a internet search mce and debounce.
Edmund is online now
Reply Remote Control Area
