recommend an IR distribution block - AVS Forum | Home Theater Discussions And Reviews
Old 05-03-2012, 12:05 PM - Thread Starter
MKaram's Avatar
I have an iTach to control my IR devices.
Each of the 8 IR devices I own has a wired IR input. I want to hardwire each of them.
So I want to take a wired out from the iTach to a wired input on a distribution block, then wire the block to all of my devices.
So the question is: which distribution block do you recommend?
Thanks in advance!
MKaram is offline
Old 05-03-2012, 05:03 PM
scl23enn4m3's Avatar
I personally use a Xantech 3 zone block. But there really isn't much in IR distribution that can go wrong. It's essentially just amplifying and combining signals. I'd just go with the cheapest one that suits your needs.
scl23enn4m3 is offline
