URC MX-880 and Popcorn hour 200 help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-08-2012, 05:08 PM - Thread Starter
pterpm's Avatar
I have the MX-880 remote but seem it can not learn the code from PCH 200 , anyone can help me with this, or anyone have a hex code for this please share
thank you
pterpm is offline
post #2 of 6 Old 05-09-2012, 08:55 AM
adk highlander's Avatar
If you are using CCP to program the 880 you will find the codes for the Popcorn hour under AUX - SYABAS - Popcornhour C-200.
Also, just to make sure you do have the IR kit for the C-200 correct? The OEM remote is RF.
adk highlander is offline
post #3 of 6 Old 03-11-2013, 11:53 PM
sandstones's Avatar
I know this is pretty old, but I am also trying to program an MX800 for a old Popcorn Hour with CCP.
I just don't see SYABAS as a brand under AUX (or anything else for that matter). CCP is fully updated.
Any other ideas?
sandstones is offline
post #4 of 6 Old 03-12-2013, 12:24 AM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
You can not use ccp to program mx-800 remote.
Edmund is offline
post #5 of 6 Old 03-12-2013, 09:12 AM
bryansj's Avatar
Quoted: 1128 Post(s)
Liked: 558
Any other ideas?
Assuming you meant MX-880 then just learn the codes from the PH remote into CCP.
bryansj is online now
post #6 of 6 Old 03-12-2013, 09:14 AM
As Edmund has said you cannot program an MX-800 with CCP. If you made a typo and are using a MX-880 the codes are definitely there. Make sure you are looking under the IR Database and not Serial or IP.
Reply Remote Control Area
Urc Mx 880 48 Device Ir Rf Remote With Color Lcd , Popcorn Hour C 200 Networked Media Tank Black
