Aton DLA4 to iTach Hardwired - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-09-2012, 07:31 PM - Thread Starter
superfreq's Avatar
I am trying to follow the instructions for hard wiring the IR listed on the Aton site here: http://atonhome.com/xTras/Downloads/...lustration.pdf
But I am not getting any success with it. I am using iRule to transmit the signal. Has anyone tried this?
superfreq is offline
post #2 of 4 Old 05-18-2012, 02:57 PM
hd54321's Avatar
If I am not mistaken, I think the Aton takes a Xantech type of IR input. Meaning a 12V, Signal, and Ground. It may need to be rewired.
I purchased a Global Cache GC-CGX cable that I will be using to connect my iTach to a Xantech block. Then the Xantech block to an Aton.
Hope this helps...
hd54321 is offline
post #3 of 4 Old 05-19-2012, 12:34 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Yep, you need the compatibility cable - ran into the same issue. It's not a matter of re-wiring, the GC outputs are a different voltage level than the Xantech "standard", unfortunately... Hopefully any future products from GC will be directly compatible.
Jeff
jautor is online now
post #4 of 4 Old 05-22-2012, 10:12 AM
hd54321's Avatar
FYI - I purchased my cable from ASIHome. They offer free shipping to Cocoon members....
hd54321 is offline
Reply Remote Control Area
