Onkyo TX-NR809 Compatible Codes for MX-950? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-25-2012, 10:12 PM - Thread Starter
NoFear's Avatar
Hey guys -
Not to date myself here, but I still have and love my MX-950. Unfortunately, the poor guy's lifecycle is all but over and it hasn't been updated in a couple years. I'm wondering if anybody has suggestions for getting my MX-950 to play nice with my new Onkyo TX-NR809.
I could manually use the learning functions from the other remote, but I seem to have troubles getting my MX-950 to handle long key presses well when using the learning feature, and the remote included with the TX-NR809 doesn't have a discreet off button for easy device manipulation.
Thanks in advance.
NoFear is offline
post #2 of 10 Old 05-26-2012, 12:58 PM - Thread Starter
NoFear's Avatar
Is there any chance somebody might be able to provide me with the pronto code ccf file or URC MX-950 compatible code file for the TX-NR809 or the RC-810M remote?
NoFear is offline
post #3 of 10 Old 05-26-2012, 01:33 PM
bcg27's Avatar
Google is your friend. Also try the database at Remote Central.
bcg27 is offline
post #4 of 10 Old 05-26-2012, 04:39 PM - Thread Starter
NoFear's Avatar
I have spent days searching. :-/
Remote Central is great, but is lacking CCF (or other MX-950 compatible) files for the TX-NR809.
NoFear is offline
post #5 of 10 Old 05-26-2012, 05:51 PM
bcg27's Avatar
You sure about that?
Discrete Onkyo IR codes: http://files.remotecentral.com/libra...kyo/index.html
Link in the second post has a very large database of IR codes, including the 809: http://www.remotecentral.com/cgi-bin...hread.cgi?6268
bcg27 is offline
post #6 of 10 Old 05-26-2012, 08:03 PM - Thread Starter
NoFear's Avatar
Woh! w00t! Thank you so much! Now I just need to figure out how to convert these into a ccf file so that I can import them with the universal browser, which unfortunately does not accept pasted pronto codes.
Out of curiosity, how did you manage that so quickly? I hunted left and right on Remote Central and just about everywhere else under the sun. Were you just searching for Onkyo codes generically? Those links didn't specifically mention the TX-NR809, which might be why I didn't find them.
NoFear is offline
post #7 of 10 Old 05-26-2012, 09:10 PM
bcg27's Avatar
You can copy and paste hex codes directly using the universal browser, assuming you're using CCP.
Regarding finding the codes, for the first link I just browsed the discrete database on Remote Central. The second one I found by googling for Onkyo generically, or maybe it was Integra since they seem to use the same codes. It can be tough to find individual models since there are so many of them but they pretty much all use the same codes as far as I can tell.
bcg27 is offline
post #8 of 10 Old 05-26-2012, 09:29 PM - Thread Starter
NoFear's Avatar
CCP doesn't support the MX-950 (unless you have a great workaround for that, too!), and the version of the Universal Browser that I have with the MX-950 editor doesn't support pasting hex codes. I've heard earlier versions did, and apparently CCP does, but not the MX-950 editor.
It would be great if I could import these codes en mass and export them to CCF since it would take a pretty hefty chunk of time to manually copy over all the supported codes into [a ccf editor here], export them to CCF, and then manually configure my MX-950 for 3 zones in the Universal Browser.
Do you have any software recommendations or preferences for CCF creation/editing?
Also, thank you tremendously for your help.
NoFear is offline
post #9 of 10 Old 05-27-2012, 06:59 AM
bcg27's Avatar
Sorry I've never used a 950. I'm actually pretty new to CCP and URC stuff in general just learning the ropes, but URC seems to keep their stuff pretty well locked down so I doubt there is a way to hack CCP to allow the 950.
There is an onkyo 805 ccf file from Remote Central here: http://www.remotecentral.com/cgi-bin...=&au=&le=&pg=2
I opened it up with the ccf extractor editor in the wiki here http://www.etcwiki.org/wiki/Open_CCF_Files and it seems it will display the commands present in the file as well as let you edit the hex values. Looks like there are a bunch of other tools linked from that wiki that might be more advanced. I think your best bet would be to find a pre made ccf file from remote central that has all the commands you need then edit them with your onkyo commands, hopefully that 805 file works but they have lots of others.
bcg27 is offline
post #10 of 10 Old 06-01-2012, 02:42 AM - Thread Starter
NoFear's Avatar
Thanks for the tips! I'll see what I can pull together.
NoFear is offline
Reply Remote Control Area
Onkyo Tx Nr809
