JVC RS45 controlled by rear IR input jack--won't power on!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-29-2012, 11:32 AM - Thread Starter
nchen's Avatar
Anyone out there sending IR commands to their JVC projector using a 3.5 mm jack into the rear "remote control" IR jack? I'm using iRule with an iTach WF2IR gateway. I have a 25 foot stereo cable, 3.5 mm, going from IR output #1 of the iTach into the rear IR input jack of my RS45. Every command works perfectly--except for power on!! I've tried the iRule database codes, the JVC long hex format IR code, and learning the power on code directly from the remote. I've tried repeating the code once, 3 times, and 5 times. I updated the firmware on the projector. Nothing works. If I use an IR emitter, it works, so the iRule/iTach system is set up correctly. However, no power on via the 3.5 mm cable (all other commands work--power off, lens control, menu, back, cursors, picture mode changes). What am I missing?
Anyone have a solution before I give up and just run an emitter to the projector? Using the rear IR jack just seems like a much more elegant solution to me.
nchen is offline
post #2 of 7 Old 05-29-2012, 02:28 PM
pauleyc's Avatar
Liked: 24
You might need a GC to Xantech converter cable GC-CGX
http://iruleathome.com/the-hardware/...l-cache-gc-cgx
Apparently the GC puts out 5V and this works fine with the emitters but direct plug IR devices sometimes expect 12V (or something like that)...
pauleyc is offline
post #3 of 7 Old 05-29-2012, 02:55 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
The compatibility cable would be my guess as well. Other question - with the power already on, do other IR codes work using the connection?
I used RS232 for my RS50 from a GC-100, controlled by iRule...
Jeff
jautor is offline
post #4 of 7 Old 05-29-2012, 05:41 PM - Thread Starter
nchen's Avatar
Thanks for the suggestions. Jeff, the other projector codes all work perfectly using the same connection once the projector is on. There just seems to be something about the "power on" code in particular that doesn't work. Plus, I have my Anthem receiver hooked up the same way and it works perfectly.
I think I will go ahead and try that compatibility cable, although I'd hate to spend 32 bucks to find that it doesn't work! I need a 25 foot length, so I might need to either cut and splice it or use an extension cable.
nchen is offline
post #5 of 7 Old 05-30-2012, 10:30 AM
jautor's Avatar
Liked: 777
It could be the IR voltage that would be fixed by the compatibility cable (with the PJ in standby it may have different characteristics...), but hard to be certain about that.
Don't cut that cable, use a 3.5mm extension cable or coupler to get the length you need. If it doesn't help, cutting it means you can't return it or sell it!
If the emitter works, I would be inclined to just use that - especially since it's not 100% certain the cable will fix it... But I fully understand the desire to use the hard-wired solution.
Jeff
jautor is offline
post #6 of 7 Old 05-30-2012, 10:56 AM - Thread Starter
nchen's Avatar
Maybe I should just go with the emitter...choices...
Thanks again Jeff, and BTW I love your theater and thread.
Norm
nchen is offline
post #7 of 7 Old 12-15-2012, 01:49 PM
obie_fl's Avatar
Liked: 33
Sorry to resurrect an old thread but did you ever get this resolved? I'm having the exact same issue.
obie_fl is offline
Reply Remote Control Area
