Any roku 2 XD remote codes for my RCA RCRPO5B remote ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-01-2012, 08:29 AM - Thread Starter
mattg3's Avatar
Quoted: 264 Post(s)
Liked: 169
About to buy a Roku 2 XD and wondered if any codes existed for this device on my RCA remote or do i just have to program them using learning feature? thanks
Matt
mattg3 is offline
post #2 of 5 Old 06-01-2012, 09:03 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Sorry, no Roku 2 XD codes are built in to your remote. Learning may not work either if that's the model that comes with an RF remote. But all Roku codes appear to be the same, so any other Roku IR remote should work for learning.
mdavej is online now
post #3 of 5 Old 06-01-2012, 09:30 AM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
The XD comes with a IR remote, its the XS that's RF.
Edmund is offline
post #4 of 5 Old 06-01-2012, 09:35 AM
3FingeredGlove's Avatar
Quoted: 22 Post(s)
Liked: 39
I don't know anything about Roku equipment, but JP1-Master-1.09 lists three possible device numbers for various Roku components. The 2 XD isn't listed, but the possibilities are-
HD1100: NEC2 190.239 (Cable 2371)
HD 1000: NEC1 111 (Audio 1828 can be modified to work)
LT, XDS, 2XS: NEC1 234.194 (I don't see a corresponding setup code).
Probably the 2 XD uses NEC 234.194. If you do try to learn the codes from a remote which isn't supplied with your Roku, try to find a remote from one of the newer models.
3FingeredGlove is offline
post #5 of 5 Old 06-01-2012, 09:59 AM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Cable 2371 works fine on my XS Roku using an URC-8820N.
If 3FG or mdavej can list the efc's for missing commands like:
netflix
panadora
crackle
search
back
It would help future XS owners who only have Rf remotes.
Edmund is offline
Reply Remote Control Area
