Need help with remote selection for multi tv/theater setup in a basement. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-10-2012, 09:03 AM - Thread Starter
wbtuttle's Avatar
There will be 3 tv's on the wall in my basement with all components, including the directv boxes, run to one closet. Off of the basement will be a separate theater/golf simulator room with another directv box, ps3, computer for simulator, two projectors, surround and other components run to a different closet. We will also have 3 other hidden box locations upstairs. I can't figure out what kind of remotes to get so that I can control everything separately. I want to make sure that changing one box doesn't end up changing them all. Are there enough RF frequencies so that I can have separate control for all of the tv's? Is RF the way to go or should I get IR blasters? Given the expense of the harmony type remotes out there, will I have to get a new remote for each tv? I know that directv has the rf remotes, but will I be able to have all of the boxes controlled separately? Any help would really be appreciated.
wbtuttle is offline
post #2 of 6 Old 06-11-2012, 01:34 PM
mdavej's Avatar
Quoted: 2223 Post(s)
Liked: 972
DirecTV RF remotes will be able to control each box seperately. Go into the remote setup on the DirecTV box itself and change the address of box 2 and box 3 so they are all different. You can control all from 1 remote or several, it's your choice. To control all from 1, DirecTV mode can be address 1, AV1 can be address 2 and AV2 can be address 3. Just move the slider to control a different box.
While the DirecTV boxes aren't a problem, your 3 TVs are. If they are all the same make, then you'll need some sort of addressable IR or RF system, which isn't cheap. If they are all different makes, then you'll have no problem.
mdavej is offline
post #3 of 6 Old 06-11-2012, 01:50 PM - Thread Starter
wbtuttle's Avatar
Thanks. To be clear, there are enough directv rf channels to run 3 in the basement and 3 upstairs without interfering with each other?
What about the theater room with all of the other equipment? Any suggestions for a remote that won't interfere with the other 6 rf signals?
wbtuttle is offline
post #4 of 6 Old 06-11-2012, 03:14 PM
jautor's Avatar
Quoted: 1307 Post(s)
Liked: 836
Are you sure that will work? It certainly will for IR, but I've never seen any solution for controlling multiple D* receivers from a single DirecTV RF remote. I don't think the RF remote will send anything via RF for AV1 / AV2... Is there an RF-compatible 3rd party remote that could do it?
Happy to be wrong about that, but I couldn't get it to work. But if he's going to have any sort of IR repeating anyway, just using the selectable addresses for the D* boxes means he doesn't really have to go RF.
FYI for the OP - DirecTV receivers are also easily controllable via RS232 or HTTP.
Jeff
NOTE: I am fixing photo links in my theater thread - if you find dead photo links elsewhere, please PM me and I will fix it.
jautor is offline
post #5 of 6 Old 06-11-2012, 08:05 PM
mdavej's Avatar
Liked: 972
Yes, there are 8 possible addresses, depending on your DVR models. Some older ones only have 3, but newer ones have 8. So use 1-3 on your old boxes and 4-6 on your newer ones. FYI, same frequency is used by all, but header has 1 byte with the address. So like a lock and key, only the DVR set to that particular code will respond. Sounds like you only need an upstairs remote and a downstairs remote.
Yes. HERE's how (thanks to Edmund).
mdavej is offline
post #6 of 6 Old 06-12-2012, 08:22 AM
jautor's Avatar
Liked: 836
Very cool! Glad they have a solution for this. So, yes, that's absolutely the way to go if the only components out of sight are the D* boxes...
Thanks for the link,
Jeff
jautor is offline
Reply Remote Control Area
