ATT U-verse remote with Mitsubishi 82" DLP volume doesn't work. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-09-2012, 10:39 AM - Thread Starter
diernosaj's Avatar
Hello
I recently bought an 82" Mitsubishi DLP tv and I have it hooked up to ATT U-Verse. When I turned everything on at first, the ATT U-verse remote would control the volume but not turn the tv on and off. I tried programming the remote with the Mitsubishi codes by pressing tv and ok for 3 seconds, it blinks twice, enter the codes, then the tv mode button should blink 3 times for a correct entry but I went through all the codes and none of them worked. I only got 1 solid blink instead of 3.
Now the volume doesn't work between the ATT U-verse remote and the tv. Then I tried using the 955 code to program the volume to work on the tv and it does the same thing.
I don't have a receiver or surround sound yet. The TV's remote volume works and is maxed out all the way and the tv is barely at a sound level to be able to watch tv and hear whats going on.
I reset the Att Uverse box and it didn't help either.
Can anybody help me out with this.
Jason
diernosaj is offline
Reply Remote Control Area
