Next Generation Remote Extender won't stop sending commands - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-12-2012, 09:21 AM - Thread Starter
mullet34's Avatar
I used to love this unit until it started doing this crap with my HK AVR-254. At random times when I hit the Volume Up or Volume Down buttons on my remote, the Next Gen extender keeps sending a up or down command. The only way I can stop it is to unplug the power from the unit. Has anyone else run into this? It's driving me crazy and I don't know whether the unit has gone bad or it's just some quirk with my setup.
mullet34 is offline
post #2 of 6 Old 07-12-2012, 01:35 PM
Joxer's Avatar
I've started to get this effect recently as well using it with my cable DVR.
It worked fine for a couple years at least.
Joxer is offline
post #3 of 6 Old 07-12-2012, 05:26 PM - Thread Starter
mullet34's Avatar
Have you found any fix for it? I've only had this thing for 7 months.
mullet34 is offline
post #4 of 6 Old 07-12-2012, 05:56 PM
Joxer's Avatar
Not so far, just reset it (power off/on) every day or so.
Joxer is offline
post #5 of 6 Old 07-13-2012, 06:51 AM
Vin
Vin's Avatar
Quoted: 12 Post(s)
It might be that the signal is too strong > http://www.nextgen.us/Articles.asp?ID=136
If you determine that it's defective you should be able to get it replaced under warranty.
Vin
Vin is offline
post #6 of 6 Old 07-13-2012, 08:58 AM - Thread Starter
mullet34's Avatar
Yeah, I saw that article, but I've actually found this happens when the battery is low. When I swap it out with a freshly charged one from the unit, the behavior stops (I'm using the remote from the same spot before and after).
mullet34 is offline
Reply Remote Control Area
