Reprogram Onkyo TX-NR807 remote - AVS Forum | Home Theater Discussions And Reviews
Old 07-27-2012, 03:12 PM - Thread Starter
jrmtz85's Avatar
Hi everyone,
My Onkyo TX-NR807 recently died and I got a Yamaha RX-V673. I was wondering, since the Onkyo remote has button by button programming, if I could program the "Receiver" functions of the Onkyo Remote to work with the Yamaha receiver.
I have my TV, cable box, popcorn hour and xbox fully programmed into the Onkyo remote, and I don't think the Yamaha remote allows this much control over other devices (unless someone knows otherwise). I'd hate to start using multiple remotes again because of this new receiver.
jrmtz85 is offline
Old 07-27-2012, 11:28 PM
3FingeredGlove's Avatar
Quoted: 22 Post(s)
Liked: 39
I'm familiar with JP1 remotes, and the possibility to program buttons individually using the 994 command. What procedure is used with the Onkyo remote?
3FingeredGlove is offline
Old 07-30-2012, 12:26 PM - Thread Starter
jrmtz85's Avatar
Hi, and thanks for the response. Sorry for my late reply, I was out of town over the weekend.
To program individual buttons, i used the procedure in the manual, which was:
1) While holding down the mode button (TV, DVD, etc), push power for 3 seconds.
2) On, the Onkyo, push the button you want to learn a command
3) aim the 2 remotes at each other, and on the other remote, puch the button you want the Onkyo remote to learn
That's it. It was quite easy to set it up to learn all my other devices.
What I was thinking I might do, is use an unassigned mode to lears the commands from the Yamaha. Thta might get me some menus and the like, but i don't think full control over the device (input select, audio decoding switching, etc).
Any ideas?
jrmtz85 is offline
Onkyo Tx Nr807
