help with winlirc and ir toy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-28-2012, 01:57 PM - Thread Starter
mchahn's Avatar
If there is a better forum on the web for support of winlirc and ir toy let me know.
I am having trouble configuring winlirc with ir toy. I fire up winlirc and start the configuration everything goes okgo into setup. The irtoy plugin setup goes fine. When I am back in the winlirc setup there is a field called "Remote Configs", a Browse button, and a Create Config button. I don't understand what I am supposed to do here. When I click on Create it puts "..\config.cf" in the field.
Anyway, not matter what I do with the Remote Configs field when I hit ok on the dialog I get the message "Error loading config file". Is there some file I am supposed to create or download for this?
Is it asking for a config file for the winlirc program or for a remote, like a standard lirc config file. I am confused.
Any help would be appreciated...
mchahn is offline
post #2 of 3 Old 07-28-2012, 02:20 PM
jrwhite's Avatar
Hi mchahn,
The Dangerous Prototypes forum - irtoy sub-forum is where you should look for support. The WinLirc developer hangs out there.
Jonathan
jrwhite is offline
post #3 of 3 Old 07-28-2012, 02:48 PM - Thread Starter
mchahn's Avatar
thanks
mchahn is offline
Reply Remote Control Area
