'Watch TV' with Harmony 510 and Panasonic TC-P50ST50 doesn't change TV input - AVS Forum | Home Theater Discussions And Reviews
Old 07-31-2012, 08:15 AM - Thread Starter
ForeverSilent004's Avatar
I have a simple Watch TV activity set up: TV needs to be on Ant/Cable and AV receiver needs to go to AV4. Except when I select Watch TV, the TV looks like it never gets a command. If I hit "Media Center" which is a HTPC plugged into HDMI1, the TV will switch right to it.
The remote does not have built in Ant/Cable, HDMI1, HDMI2, HDMI3, Composite, etc buttons, but the ability is there for it to send direct commands to specific inputs. I'm thinking the Ant/Cable command just isn't correct. Any ideas on what to do?
TV: Panasonic 50" ST50 1080p Plasma
Audio: Yamaha Aventage A710 / Polk Audio RM510 5.1
Remote: Logitech Harmony 510 / Logitech MX Air mouse / Lenovo N5902
HTPC: Silverstone SG06 / Intel i7-3770S / XFX 7870 DD / 840 Pro 256GB / Windows 8 Pro / Synology DS413 + 4x3TB WD Red RAID5
Build: http://pcpartpi...
ForeverSilent004 is offline
Old 07-31-2012, 10:46 PM
mdavej's Avatar
Quoted: 2128 Post(s)
Liked: 940
If you have an old cable or radio shack remote, you can teach your harmony the ant/cable discrete codes. Use CBL setup code 0701 (00701) and EFC 00149 for Ant/Cbl following the manual programming instructions in the Wiki link in my signature.
Alternately, some tv's will switch to ant/cable if you press ch+ or ch-. If that works, just add that to the beginning of your activity or change the input list to use it.
mdavej is online now
Old 07-31-2012, 11:47 PM - Thread Starter
Thank you for the reply. I have no old remotes, is there any other way to make this work?
Old 08-01-2012, 06:50 AM
mdavej's Avatar
Liked: 940
Pronto hex import. See my tips sticky thread for the procedure.
Old 08-01-2012, 07:50 AM - Thread Starter
Great, thanks! I am unsure though how to get the Input Aux/Cable code for the TV though.
Old 08-01-2012, 12:31 PM
mdavej's Avatar
Liked: 940
I can't be 100% certain, but here's the most likely code for ant/cable:
Protocol=panasonic Device=128.2 Function=48
Code:
0000 0070 0000 0032 0080 0040 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0030 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0010 0030 0010 0030 0010 0010 0010 0010 0010 0010 0010 0030 0010 0010 0010 0010 0010 0030 0010 0030 0010 0010 0010 0030 0010 0ACE
Since you only need one code, the easiest way to import it is through the members.harmonyremote.com website.
Or you can learn it from a cable remote as I posted before. Since you don't have one, you can get one on ebay for around $3. I also have a ton of these remotes I'm always looking to get rid of. PM me if you are interested. I can pre-program it with every possible discrete for your tv if you want.
Panasonic Viera Tc P50st50 Plasma Tv
