Struggling to set up volume control.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-10-2012, 11:26 AM - Thread Starter
houghton19's Avatar
I have the Watch tv macro set up so it turns tv on, PVR on, Amp (always on).
yet when i put my xbox media center on it wont control my amp volume, how can i set it so that no matter what device is selected my amp is ALWAYS main volume ???
Thanks in advance
TIm.
houghton19 is offline
post #2 of 6 Old 08-11-2012, 05:40 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
What remote are you talking about?
Dropkick Murphy is offline
post #3 of 6 Old 08-12-2012, 02:30 AM - Thread Starter
houghton19's Avatar
Sorry about that, its a logitech harmony one.
post #4 of 6 Old 08-12-2012, 09:52 AM
Quoted: 71 Post(s)
Liked: 89
When you do your activity setup one of the first questions asked is "how do you control the volume". You check the line that says "I use my (whatever device you choose) to control the volume"
post #5 of 6 Old 08-12-2012, 10:27 AM - Thread Starter
houghton19's Avatar
I done that, it only works if I select the amp under devices.any ideas what's wrong ?
post #6 of 6 Old 08-13-2012, 08:42 AM
mdavej's Avatar
Quoted: 2130 Post(s)
Liked: 941
Volume punch thru (always using amp for vol) only works on activites, not devices. If you added an xbox, you must make a "Play Xbox" activity to set the volume device. If you add another device in the future, it will need its own activity as well. You're probably used to other remotest that have a global volume punch thru. Harmony doesn't work like that. If you want it to work in device mode, just learn your amp's vol/mute buttons for every device. But using activities is much easier.
mdavej is offline
Reply Remote Control Area
