Onkyo TX SR608 IR problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-15-2012, 06:39 PM - Thread Starter
CAStechnician's Avatar
I installed a IR repeater system and everything works through it except the Onkyo reciever. I can not get the remote to work through the repeater, it is a Xantech system. How can I get it to work?
CAStechnician is offline
post #2 of 6 Old 08-15-2012, 08:43 PM
senormano's Avatar
I'm using a Xantech system with the 607 with no issues ... Are you sure your it blaster is working and is mounted over the "sweet spot" on your Onkyo?
There's a circle to the left of the LCD display. Hit it with a flashlight and you shod be able to make out where it is.
senormano is offline
post #3 of 6 Old 08-15-2012, 08:56 PM - Thread Starter
Yep, I placed the emitter over that and covered it, it still does not work.
post #4 of 6 Old 08-17-2012, 02:32 AM
senormano's Avatar
Do your blasters include the visible red confirmation light? If so, do they flash in response to the remote? Or o you see or activity (view through a phone camera and IR should show up).
Any other devices being controlled by the blasters? Do they work?
post #5 of 6 Old 08-17-2012, 02:36 AM
senormano's Avatar
Sorry ... Intended to ask whether that blaster was confirmed working with another device.
post #6 of 6 Old 08-17-2012, 05:30 AM - Thread Starter
It has a confirmation light that lights up when you use the remote. A cable box and a blue ray player are on the same block and both of those work. Yes I confirmed that the blaster works.
Reply Remote Control Area
Onkyo , Onkyo Tx Sr608 Receiver , Displays , Lcd Hdtv , Onkyo Tx Sr607 Receiver
