URC MX-5000 problems powering on Panasonic TX-P42C11 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-16-2012, 01:26 AM - Thread Starter
Raptorial's Avatar
I am programming a URC MX-5000, everything works fine, also on the TV if I turn it on with the Panasonic remote.
The only thing is, I can't turn it on... the Panasonic remote turns it on if you press any button for 2 or 3 seconds.
Things I tried:
- Repeat the power on signal with a macro
- Learn 1st and 2nd code My feeling is the code changes every moment you keep it pushed down. Now I tried to learn code 1 and then point the remote away and after 3 seconds point at the learning module again to try and capture the last code. I was able to do this, but it didn't solve the problem.
- If I keep the original remote pressed the light flickers all the time I press the button, if I do this with the URC one it only flickers once.
- Other Panasonic TVs are in the database so I tried those, the TV light flickers once a well, I noticed two power commands in the database, both did not turn it on (sames result as the learned code).
My Harmony 1100 is able to turn it on though, capturing this code did not work either.
Anybody any thoughts on this?
Thanks in advance.
Raptorial is offline
post #2 of 2 Old 08-18-2012, 11:39 AM
BizarroTerl's Avatar
Quoted: 38 Post(s)
Liked: 46
In CCP you can change the properties of a learned command. Double click on it and then select the "Repeat while button is pressed" box. That may get you there.
BizarroTerl is offline
Reply Remote Control Area
Urc , Universal Remote Control Mx 5000 Remote Control , Panasonic
